Switch panel accessory wire question
Discussion in 'General Tundra Discussion' started by jokerftn1018, Nov 16, 2020.
  1. Nov 16, 2020 at 6:33 AM
    jokerftn1018
    jokerftn1018 [OP] New Member
    Daniel
    Virginia Beach
    2016 mgm sr5
    So this weekend i am going to be installing a auxbeam switch panel just something to run the ditch lights and bumper lightbar. I have a question for the underhood fuse box where would I connect the accessories dimmable wire. its obvious where the power and ground are going but under the hood fuse box is a little different from the inside fuse box. If anyone has a picture of whatfuse i should tap into this would be amazing thank you.
  2. Jan 11, 2023 at 5:00 PM
    eowade
    eowade Restore The Republic!
    Eric
    2019 Voodoo Blue Tundra TRD Pro
    Smittybuilt 10klb winch, 295/70/18 Recon Grapplers, Remote Start, WeBoost, Mifi, Philosin 13.3 inch rotatable HU, Center Console wireless charger, Nilight hood, ditch, and bumper lights on 8-gang switch
    Over two years later, and still no response? How did you finally end up connecting the ACC wire?
  3. Jan 12, 2023 at 5:35 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Post in the electrical section with details of exactly what you want to do.
  4. Feb 23, 2023 at 7:27 PM
    MrJimmyPenguin
    MrJimmyPenguin Penguined
    Jimmy
    2021 Black Crewmax Toyota Tundra TRD Off Road Premium 4x4
    I ordered the 8 Gang switch panel and will be doing this once it arrives on my 2021, so if I can remember I'll update where I tapped into for 12v accessory power.
  5. Feb 24, 2023 at 8:00 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Yeah, he commented in 2.5 Gen thread he created along with this thread.
    https://www.tundras.com/threads/auxbeam-6-gang-switch-panel-install-question.78176/#post-2167246
