Warped front rotors need replaced.
Discussion in '2.5 Gen Tundras (2014-2021)' started by awq735, Feb 14, 2023.
  1. Feb 14, 2023 at 5:25 PM
    awq735
    awq735 [OP] New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    My 2019 Double cab has 42k miles on it and my front rotors are starting to warp. I tow a 6k camper 5-7 times a year. Most trips are a few hours each direction. What is everyone replacing their factory rotors with? Brake pads still have plenty of material on them, over 50%, but considering changing pads as well.
    I've had power stop z36 pads and rotors on my F-150, but after having them for 40k miles they were starting to get small cracks at most of the drilled holes.
  2. Feb 14, 2023 at 7:05 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Are you down shifting/engine braking? That’s early for brake warping unless it’s like continuous steep descending with the trailer. I think most people recommend the OEM or going to a big brake kit with all new setup if needed.
  3. Feb 14, 2023 at 7:05 PM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    Centric/Stoptech Cyro treated rotors are where it’s at. They are hard to find right now, but hopefully will be back in stock in the next few months.
  4. Feb 15, 2023 at 2:08 AM
    awq735
    Anthony
    Ohio
    I do downshift when towing down steep garages, and make sure I'm not riding the brakes all the way down the hill. I only noticed them being warped after being away for work for a month. My wife drove the truck to work and back 2-3 times in my absence, which is less than a mile away, so I can't imagine it was anything she did
  5. Feb 15, 2023 at 2:48 AM
    StopTech Sport cryo treated and slotted only. I bought mine from AutoAnything.
    Bprose and Adam like this.
  6. Feb 15, 2023 at 3:17 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    EBC slotted rotors on mine..
  7. Feb 15, 2023 at 4:32 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I am running the Z36 Powerstop rotors and pads on my 2017 Tundra. Have towed a heavy camper (7800 lbs) about 8,500 miles and they are doing fine. Important to measure and minimize lateral runout on rotors during install. I use the Permatex #80653 on all brake related locations where lubricant is required - good for rubber & metal contact. Agree with others that important to manage speed, downshift and avoid riding brakes descending long/steep grades. FYI - agree that you should change the pads if you change the rotors.
    https://www.tundras.com/threads/power-stop-z36-install.103380/#post-2759282
  8. Feb 15, 2023 at 11:52 AM
    Rocko9999
    Rocko9999 New Member
    Pull the rotors and have them resurfaced. Put them back on and get another 42K out out of them.
    Terndrerrr and 17inferno like this.
  9. Feb 23, 2023 at 4:42 PM
    awq735
    Anthony
    Ohio
    So I ended up going with EBC smooth rotors and EBC yellow stuff brake pads. Do the front brakes use the metal slide clips? This kit didn't come with any.
    Rocko9999 likes this.
  10. Feb 24, 2023 at 3:52 AM
    agrestic1
    2016 CrewMax
  11. Feb 24, 2023 at 5:27 AM
    awq735
    Anthony
    Ohio
    I guess I did know that the front calipers were different than a single piston caliper, but haven't really been up close and personal with them enough to know what hardware is used/needed. Now to call the local dealer to see if they have a shim kit, and a anti-rattle clips in case mine decide to be stubborn! Thanks for the video, it will surely speed up my installation time!
