Add grille lights to fog light switch
Discussion in 'Lighting' started by skidwiler527, Dec 16, 2022.
  1. Dec 16, 2022 at 2:56 PM
    skidwiler527
    skidwiler527 [OP] New Member
    2006 Toyota Tundra Crew Cab
    2.5" Leveling kit. TRD 17" Wheels
    Was wondering if I could hook up my grille lights to my fog light switch on a 2006 tundra double cab...and if so where should I hook it up. Can I splice right into the (pink) fog light wires?
  2. Dec 16, 2022 at 2:59 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    What kind of grille lights? Do you know by chance how hitch draw they pull? There’s a chance you could tap right in.
    Also, are these accent lights? Like “raptor” lights? If so, don’t forget if you tap directly into fog light wires they’ll go out in conditions where the fogs won’t illuminate. Ex - high beams
  3. Dec 16, 2022 at 3:24 PM
    skidwiler527
    LED Raptor lights (4) no can do on the brand. Came with "TRD" Honeycomb grill from the Goodmatchup.com site. About the only after market grill that is listed to fit the crew cab. No wiring connection either. Just raw ends Blk/Red. Yes I realize that they'll go off on high beams, just thought the on/off switch of the fog lights would come in handy.
  4. Feb 23, 2023 at 12:58 PM
    Emwve
    Emwve New Member
    Turk
    2006 Toyota Tundra Double Cab SR5 4x2 V8
    I am in the same boat, would also like to know how you wired under the hood
