  1. Feb 19, 2023 at 6:35 PM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    I sanded my roof in preparation to put some paint on it tomorrow.
  2. Feb 19, 2023 at 7:09 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    To be fair, the brakes on our trucks are not great for stopping, especially carrying alot of weight or in towing. Thus the reason brake upgrade is such a common mod for 1st gens. Perhaps you were unaware, but that would've been the time to do it, rather than buying new stock calipers. :notsure:
  3. Feb 19, 2023 at 7:10 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Oh I know about the brakes, I tow a fair bit.
    I have the 13WL calipers, so not a lot to be done unless I went all out.
    RUSTYNUTS likes this.
  4. Feb 19, 2023 at 8:02 PM
    daveeasa
    I did 6200 lbs to the transfer station yesterday and have no complaints about my brakes. I actually kinda like them.
  5. Feb 19, 2023 at 9:00 PM
    Erik1989
    Erik1989 New Member
    Erik
    2003 White Tundra
    in the market myself. which brand did you get? HD?
  6. Feb 19, 2023 at 9:00 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yes this is normal. I don't like it but that's just the way they are. The OEM reman CV axles seem nice but no one was aware of them when I did my axles a while back.
  7. Feb 20, 2023 at 3:39 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Huddled up at an old Noah past time. Added a new stain. The paint corrections guys are gonna lose their minds :rofl:
    Jack McCarthy, txagg and JasonC. like this.
  8. Feb 20, 2023 at 4:14 AM
    Found a little mud hole while dropping of a few games with my buddy at the sports complex. Sent it just a little.
  9. Feb 20, 2023 at 7:58 AM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    went with Archive MD springs. I have a shell and a platform in the back so maybe 300lbs of constant weight. Eric at archive is super nice and helpful, he can help you decide which ones to get. Solid wait times for these, ordered back in November. I will update my build page with official lift numbers after install
  10. Feb 20, 2023 at 1:17 PM
    Greased all of the driveshaft zerks but the front 4wd driveshaft. Forgot I needed my needle fitting to get it in there.
    Also changed the rear differential. Didn’t get time to do the front or transfer case.
    Clean:
    Dirty:
    bmf4069, RUSTYNUTS, Tundra2 and 7 others like this.
  11. Feb 20, 2023 at 6:48 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Saw the picture & my first thought as my skin crawled was Erik @FirstGenVol gonna cringe. Then I read the post - self awareness is important. :)
  12. Feb 20, 2023 at 6:50 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    How's paint going?
  13. Feb 21, 2023 at 4:26 AM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    7C03A23D-D99D-4BF8-A709-B43267CF61B9.jpg I grabbed this pic when I had it sanded down but it didn’t attach. It was a duplicolor spray can job but I thought it looked about as good as I can do myself. I painted it yesterday so I will grab a picture today. Thanks!
  14. Feb 21, 2023 at 11:36 AM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    76940ABA-4E6F-4805-AE4C-EC8097CE4069.jpg Finished painting the cab roof. It looks a lot better than it did before!
  15. Feb 21, 2023 at 5:20 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    definitely more better.
    dbittle[QUOTED] likes this.
  16. Feb 22, 2023 at 9:14 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 52k mi
    Bill what'd you decide on for propeller shaft lube? Service Manual recommends two different but very similar kinds of grease (everything but double cardan joint gets lithium-based, but double cardan joint gets moly disulphide lithium) but I'm always interested to see what "works".
    txagg and oscardog86 like this.
  17. Feb 22, 2023 at 9:48 AM
    oscardog86
    oscardog86 New Member
    Southern California
    I had the same concern awhile back and I believe the consensus was that using the same grease for all zerks including the double cardan was perfectly fine. At least thats what ive been doing the past 2 times ive done it! Hopefully this is correct.
  18. Feb 22, 2023 at 12:01 PM
    I've always been doing synthetic moly for both since I didn't want two grease guns. Probably not the best approach since you're not supposed to use moly for the prop shaft and this is maybe the reason I'm now have some intermittent vibration at 65mph and 75-80 mph. Probably one of the U-joints going out prematurely but it's either that or not greasing it often enough. I would hope the latter.
    The only synthetic non-moly lithium grease I can find is Super Lube and that stuff is 3-4x more expensive. Amsoil makes some as well that's affordable but it's not lithium based. They use some calcium-sulfonate compound instead. Not sure if that's acceptable or not.
    I used the Valvoline synthetic multi-purpose grease rated NLGI #2/GC-LB. You can pick it up at Napa for ~$12. Autozone states they have it but all the ones around me are just dented/punctured cartridges like they're not restocking anymore.
  19. Feb 22, 2023 at 2:40 PM
    daveeasa
    How many of each of these suckers and the cowl fasteners? 4-5 or 6-10?
  20. Feb 22, 2023 at 2:53 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Hope to have my flowmaster drone fixed by this time tomorrow afternoon :fingerscrossed:
    shifty`, NUDRAT, oscardog86 and 10 others like this.
  21. Feb 22, 2023 at 3:26 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
  22. Feb 22, 2023 at 6:38 PM
    robabeatle
    AZ
    Finished up getting my new amp, distribution block, and wiring for future 3 way in place tonight. I need to clean up the install and chase down some buzzing (ground loop?) but everything is working otherwise.
    CodyP, oscardog86, JasonC. and 2 others like this.
  23. Feb 22, 2023 at 8:43 PM
    NickB_01TRD
    KY
    Is that all OEM stuff? I got the rear section (part with the muffler) aftermarket for somewhere around $150. I can tell it wouldn't last too long if I drove in the salt. Bet that OEM stuff is a bit better.
  24. Feb 23, 2023 at 3:18 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    It is indeed OEM from stealer. While talking with Keith at DD’s about his 12 holes, I was further convinced going back OEM was what I wanted to do.
  25. Feb 23, 2023 at 3:27 AM
    My man chopped his door panels in the name of sound. Cringe. And respect.
  26. Feb 23, 2023 at 3:31 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    How much did that run you? I've considered OEM for crackie all the way through. Painting it all blaaaaaaaack or maybe light blue like everything else.
    Also considered aftermarket.
    Haven't done proper cost evaluation
  27. Feb 23, 2023 at 3:42 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    After discount $730....$480 muffler/$250 resonator
    NUDRAT likes this.
  28. Feb 23, 2023 at 6:11 AM
    Interesting. My 02 Tundra has both the muffler and resonator as one connected unit with exhaust piping that sells for $650 (or was the 10 years ago I bought it).
    BubbaW[QUOTED] likes this.
  29. Feb 23, 2023 at 8:19 AM
    danmurphymn
    danmurphymn New Member
    Minneapolis, MN
    Black 2004 DC TRD
    I'll have time a bit later to look into this but I figured I'd post here briefly.
    Yesterday my headlights quit working. Hi's & lows. I do have the bigger gauge wire/relay mod & higher wattage bulbs.
    I did a quick check on fuses & didnt see any blown. Figured I'd posty posty to the smarties before I get more time to dig in later...
  30. Feb 23, 2023 at 8:29 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I about to add the bigger headlight harness with relays and 100W/90W Osram halogens. Maybe the relay(s) failed?
    KNABORES likes this.
