Longer Canopy Rack
Discussion in 'Tonneau Covers, Caps and Shells' started by zasdds, Feb 22, 2023.
  1. Feb 22, 2023 at 5:45 AM
    zasdds
    zasdds [OP] New Member
    2021 Platinum Crewmax
    Hey, I couldn't find using the search.
    I would like to add a rack to my LEER100XQ with factory installed Thule rails
    Is anyone running a topper rack that extends/overhangs onto a portion of the cab?
    I know most people like the Rhino rack 60 x 54 inches and others around that size, but I found a good deal on a Yakima LocknLoad that is 84 x 62 inches. I think I kind of like the idea of a little overhang, but just wondering if it would look funny.
    Anyone running Yakima LocknLoad in general? Thanks and picture for attention!topper.jpg
    AGTundra likes this.
  2. Feb 22, 2023 at 8:15 AM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    My truck looks a lot like yours. The cap rack doesn't over-hang onto the cab though and it's not something I need anyhow. I built my own rack for the Leer 100 XR with help from @junior. You can get most of the Prinsu style extruded parts from TNUTS.com and the mounting brackets from https://sherpaequipmentco.com/. Based on the ACAD drawings, I had a metal shop build the side rails and powder coat for me. Seems you could simply raise the mounting bracket height and lengthen the rack side plates/add more cross-members if you wanted to over-hang onto the cab a bit. Best of luck.
    AGTundra, junior and zasdds[OP] like this.
  3. Feb 22, 2023 at 7:16 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    I toyed with the idea of 6ft side rails on my custom designed one @Badknees mentioned above! I wanted it low profile and I think the cab needs to flex/rotate independent of the bed in some way. If you extended the rack/basket/whatever over the cab just make sure its up a little bit from the rooflines to allow for some flex between the two halfs of your truck. Good luck!
    Badknees and AGTundra like this.
  4. Jun 24, 2023 at 5:13 PM
    Ilgie
    Ilgie New Member
    British Columbia
    08 DC Limited 5.7 4x4
    Love this idea, looking into doing it myself now. Finished product looks awesome. If you don’t mind me asking where did you get the ACAD drawings for the side rails?
    Badknees[QUOTED] likes this.
  5. Jun 27, 2023 at 4:36 AM
    Badknees
    Badknees New Member
    Sorry for the late reply and thanks for the compliments.
    If you search @junior (very nice member on this site) and DIY Roof Rack I think you will find the drawings you need. If you can't, let me know and I'll send them to you.
    Best.
  6. Jun 27, 2023 at 7:32 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    Yes! Thank you again @Badknees. @Ilgie the link to them is about half way down my first post here. https://www.tundras.com/threads/my-diy-roof-rack.79617/
