Old man emu leaf springs
Discussion in 'Suspension' started by Tundra18overland, Feb 19, 2023.
  1. Feb 19, 2023 at 12:20 PM
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    To anybody with Old Man Emu leaf springs on their 07-21:
    Are you using poly bushings or OE rubber bushings?
    I went with poly for the “added performance” but I’m tired of the squeaks (yes they were installed correctly)
    I can quiet them with silicon spray but they squeak again in a week
    Thinking about swapping to the OE bushings, do they fit the Emu spring eyelets?
  2. Feb 19, 2023 at 2:16 PM
    Wallygator
    You don't have the OME greasable bushings/shackle kit? An example below is for a Tacoma but pretty sure they make them for the Tundra Need the bushings also
  3. Feb 19, 2023 at 5:44 PM
    Tundra18overland
    Jesse
    GA
    Had em, removed them cause I put on Toytec lift shackles and those pins were no longer compatible. Bushings still squeaked with the greasable pins.
    Wallygator[QUOTED] likes this.
  4. Feb 19, 2023 at 6:22 PM
    Wallygator
    Weird. Had OME once and then Ironman on another vehicle, never had any squeaking issues with the springs and greasable bushings. Hope you can find a solution
  5. Feb 19, 2023 at 7:20 PM
    centex
    centex New Member
    Pull em out, clean the snot out of them and the shackle, reassemble with lithium grease. I’ve got plenty of poly bushings on my blazer and those are the one thing that don’t squeak on that truck. Had poly on the lowering shackles on the 2020 Silverado and after 3 years still no squeaks and I never added grease past the initial install.
  6. Feb 21, 2023 at 8:00 AM
    Tundra18overland
    Jesse
    GA
    Update…
    ARB gave me an ID measurement of 40mm on the dakar leaf spring eyelets, but I can’t find the OD measurement of Toyota’s bushing. Part guy at my local toyota didn’t have one to measure either. If anyone has this measurement it would be extremely helpful…
  7. Feb 21, 2023 at 8:06 AM
    2mchfun
    Are you sure it's not the leaf pack squeaking as the springs flex? I know you said silicone spray helped, but was any sprayed on the springs, maybe over spray? Just an idea because I have seen several people complain about the springs themselves squeaking.
    Wallygator likes this.
  8. Feb 21, 2023 at 8:10 AM
    Tundra18overland
    Jesse
    GA
    good thought, however, when I listen with an automotive stethoscope, all the squeaking is coming from the rear leaf spring bushing where it marries to shackle. The dakar leaf springs are notorious for squeaking though. When I added the aal to this pack I slathered the pack with marine grease between all the leafs and this seemed to help.
    Wallygator and 2mchfun[QUOTED] like this.
  9. Feb 21, 2023 at 8:25 AM
    Tundra18overland
    Jesse
    GA
    Also, if anyone could provide the inner diameter measurement of factory leaf spring eyelets (07-21) that would tell me right away if the stock bushings would be compatible with my dakar springs…
