Timing Chain Kit- Cheaper than Dealership
Discussion in '2nd Gen Tundras (2007-2013)' started by Ollie97, Feb 15, 2023.
  1. Feb 15, 2023 at 8:01 AM
    Ollie97
    Ollie97 [OP] New Member
    Hey All,
    I have had the slap sound at idle coming from my 5.7l for some time, that I suspect is the timing chain tensioner. Talk to my mechanic and they said parts are $3100 CAD from Toyota and on back order. Wondering if anyone knows of any decent aftermarket kits that aren't going to bankrupt me, but still of decent quality?
  2. Feb 16, 2023 at 7:52 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'd go online at said stealership and check out their price there... usually it is 50% cheaper than at the parts counter. I got an OEM radiator at the stealership for $225 at the stealership, and it was $480 at the parts counter, if you're closer to the border, see if its cheaper on the U.S. side and pick it up, since shipping will probably be through the roof and negate any savings. Hope this helps
  3. Feb 19, 2023 at 9:03 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    If you suspect the tensioner, there are inspection ports and your mechanic can look at them if not done so already. They have A LOT of adjustment unless stuck.
  4. Feb 20, 2023 at 4:29 PM
    chrisf111
    chrisf111 New Member
    I suspect my tensioner! Are you talking about looking through the oil fill tube?
  5. Feb 20, 2023 at 5:58 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    No, there are inspection ports on the timing cover right in front of each main tensioner.
  6. Feb 20, 2023 at 6:01 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Go to rockauto.com the aisin parts are the same as oem toyota.
