  1. Feb 19, 2023 at 6:09 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    In the process of installing a Kohler home back up generator.
    I did a lot of research and estimates but decided to purchase the unit and ATS through Lowes and hire my electrician and plumber. Gas is connected and the electrician is coming at the end of the month.
    The power last year went out at least 5 times and it always seemed to go out around 8 pm to 1 am. The last power outage happened while watching the Elvis movie and I missed the last 15 minutes. Power outage inconvenience days are soon coming to an end.
    Update:
    Start up on 3/6
  2. Feb 19, 2023 at 7:39 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I built our house with the panel setup to get one. Put it in a year later. Purchased the generator (generac) during a tax free sale and saved about $600. Electrician and plumber weren't bad since most was set up. EXTREMELY happy I got it. It goes out during bad times. Went out during Christmas eve and Christmas, but didn't stop the family from going forward as normal. We got a 22kw and it runs the entire house, even with both units running. Congrats man, you'll enjoy it.
    I'm actually thinking about buying the wifi wireless remote that allows me to turn it on and off as well as monitor it since I've had a couple times it would have been nice to have
  3. Feb 19, 2023 at 9:44 AM
  4. Feb 19, 2023 at 10:14 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
  5. Feb 19, 2023 at 10:16 AM
    What does the surfactant do? Kill existing growth?
    TaquitoBandito and T-Rex266 like this.
  6. Feb 19, 2023 at 10:18 AM
    MadMaxCanon
    The surfactant only makes it stick really well to what you spray on, so it doesn't just drip off or rinse away.
  7. Feb 19, 2023 at 10:22 AM
    Oh ok, since I have the pre emergent done every year, I really don’t have squat for any weeds or other standing grass, I usually just spot treat thru out the year for those.
    I know my uncle usually likes to spray before a rain storm(usually unlikely) to get the chemical to soak down into the ground better. If not I have to go out and wet the ground pretty well to get the same effect.
  8. Feb 19, 2023 at 10:35 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    We use prodiamine, dimension, treflan and surflan. I prefer granular and yes it needs to be watered in like your uncle does, trying to apply it before a rainstorm is ideal
  9. Feb 19, 2023 at 10:39 AM
    This stuff?
    https://www.amazon.com/gp/aw/d/B08GXYS3S1?ie=UTF8&sp_csd=d2lkZ2V0TmFtZT1zcF9waG9uZV9kZXRhaWwp13NParams
    Are the others you listed for specific species being targeted? Or just other options for the same chemicals?
  10. Feb 19, 2023 at 11:01 AM
    MadMaxCanon
    Good point, when I do the yearly treatment of the entire lawn I don't use the surfactant for that reason. You definitely dont need surfactant when you spray the lawn. I have alot of shady spots so I get those viney, pine needle like weeds, not sure the name but they need to have the surfactant for sure just cause the small surface area stuff just comes right off.
  11. Feb 19, 2023 at 5:18 PM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    Other options, different chems. Prodiamine and Dimension do not stop as many varieties as Treflan and Surflan. If you are using on turf I would stay away from the last two.
  12. Feb 20, 2023 at 10:04 AM
    Does anyone know if I can replace this old style can light without getting in the attic? We have more modern replacements we're hoping to install.
    TaquitoBandito likes this.
  13. Feb 20, 2023 at 10:06 AM
    MadMaxCanon
  14. Feb 20, 2023 at 10:07 AM
  15. Feb 20, 2023 at 10:09 AM
    MadMaxCanon
    Oh I gotcha. I have never worked with those rotating style ones, but I imagine you can take the whole can out, or maybe take off those side brass looking pins or something? Can you pull it down from the sides at all?
  16. Feb 20, 2023 at 10:11 AM
    Actually I got it. Just had to hit it with my purse.
    We'll have to see if the new lights I bought are compatible.
  17. Feb 20, 2023 at 10:28 AM
    MadMaxCanon
    They will definitely function, but it looks like you may have an issue with installing it as the ones that I have with the spring clips needs something for those springs to be installed on. Hard to make out from the pic but i think worst case you can just use double sided tape to get it on there. Those retrofit LEDs dont weigh much.
  18. Feb 20, 2023 at 11:24 AM
    snoope
    snoope The Old Man
    Getting there;
    Re-hung bedroom door for privacy once again ;)
    Re-installed the Barn Door for the master bathroom and hung Con's New pendant lights...:cool:
    Still need to pick-up and install new backsplash IF & when my bride decides what we want o_O :hattip:barn door back in.jpg pendant lights up.jpg
  19. Feb 20, 2023 at 11:25 AM
    Interesting spot for that light switch…..
  20. Feb 20, 2023 at 11:32 AM
    snoope
    snoope The Old Man
    That switch will disappear ; the old hot water tank is behind that right hand wall with access to it through the master bath closet...BUT that
    breaker/GFI actually runs that whole side of the house :rolleyes:
    When we RENO the 2nd bathroom that all will be ripped out to fit a full size soaker tub and remove old tank with all of its mechanical's.;)
    I have to relocate one of the 3 water filter systems as well....Not sure what the previous owners plans were BUT they never used the same people
    or materials twice :annoyed::annoyed::annoyed:
  21. Feb 20, 2023 at 11:47 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    I did this in the fall with an overseed. Soil temps are in the high 40s here now, grass is starting to green up and grow already. Time to throw down some weed n feed soon. Then wait a month and do the tenacity bath again. Or would you guys do it the other way around. Tenacity first and weed n feed or just straight fert later?
    TaquitoBandito and FrenchToasty like this.
  22. Feb 20, 2023 at 1:34 PM
    MadMaxCanon
    Great question, but I know for sure. I would imagine do it before so that it gets into the base soil before anything gets on top of it. It probably wouldnt hurt to do it after as well. On the other hand it probably doesnt matter either way since in the future you would always be applying it on the very top of everything.
  23. Feb 20, 2023 at 2:44 PM
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Had to work
    TaquitoBandito and snoope like this.
  24. Feb 20, 2023 at 5:56 PM
    TaquitoBandito
    Joel (AKA Bif)
    I love those lights - nice! Does that barn door lock? :eek:
    Hate to get walked in on.
    ColoradoTJ, NWPirate, Fotnot and 2 others like this.
  25. Feb 20, 2023 at 5:58 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I like the lights too but the issue I think you’ll run into is they will cast big shadows on your face when trying to shave, pluck eyebrows, put on mascara, you know….
    snoope[QUOTED] likes this.
  26. Feb 20, 2023 at 7:23 PM
    snoope
    snoope The Old Man
    They all know better. Lock is on bedroom door if really needed.
  27. Feb 20, 2023 at 7:25 PM
    TaquitoBandito
    Joel (AKA Bif)
    Excellent - it's looking really good. Nice work.
  28. Feb 21, 2023 at 5:00 AM
    snoope
    snoope The Old Man
    That will depend on what my Wife decides to do for a mirror & how BRIGHT :cool: of Led's we put in there , so I was told :notsure:.
    Today is "Final" walk through with the sub contractor; a few touches and we can use the bath room again..:D:D
  29. Feb 21, 2023 at 6:30 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yup, a backlit mirror would fix the prob.
  30. Feb 23, 2023 at 10:39 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Studio above garage needed storage cabinets.. I built them last week and installed yesterday..
