2023 Dbl Cab ladder racks
Discussion in '3rd Gen Tundras (2022+)' started by NHTundraman, Feb 19, 2023.
  1. Feb 19, 2023 at 2:13 PM
    NHTundraman
    NHTundraman [OP] New Member
    Ben
    New Hampton, NH 03256
    2023 Army Green Tundra Limited Dbl Cab 6.5
    Hi, I did a search but didn't come up with much. I took a Trac Rac off a 2010 Tundra. It mounted via the stake body pockets. There is a plastic cover on top of my bed rails. It looks like it might be removable, but I don't want to break anything. I would really like to use the rack I already own on my new 2023 Tundra. The nice thing about the Trac Rac; you could slide the rear upright/crossbar forward when you needed to load something tall. Does anyone know what is under the bed rail covers? Are they removable? Does anyone know of a similar rack that would fit the new Tundras?
  2. Feb 19, 2023 at 2:31 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have some TracRacs on mine but I installed them into my bed cover. I still need to cut them down so they are closer to the top of the cab.
    I could have made them adjustable forward and back but I just mounted them to the cover so they don't move.
    In the photo you can see how much I need to trim down to make them line up with the top of the cab. I got some 1"x3" aluminum blocks to put under the bases so they would sit correctly. Those need to be painted as well.IMG_7346.jpg
    =JSG= likes this.
