  1. Feb 13, 2023 at 10:50 AM
    It seems our old dingy fart fan has died. Anything I need to look out for when buying a replacement? I'm not too upset as I was tired of looking at this one.
    And yes, I know the ceiling texture is ugly.
    TaquitoBandito likes this.
  2. Feb 13, 2023 at 11:20 AM
    TaquitoBandito
    Joel (AKA Bif)
    You want to get one that is a "remodel" fan. Basically it allows you to install it from the bottom. You'll also want to measure the housing size to get one that fits. That looks square though so I think you are in good shape.
    I found a couple of Panasonics last month at Lowes in their clearance section for next to nothing - they were pretty easy to install once I figured out what I was doing.
    You also want to pay attention to how many CFM's you want (based on the size of the bathroom and if it has a shower/bath/etc) in it and how loud you want it. They make some now that you won't even hear them when they are on. I prefer not to have people snickering about my fart sounds when I come out of the bathroom so I like something that has a little background noise.
  3. Feb 13, 2023 at 1:00 PM
    Solid work!
  4. Feb 13, 2023 at 1:08 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Not actually a home improvement per se but I did put away all my duck and goose hunting decoys and then cleaned the garage to put them away. I clean that dam garage more times than I care to count.
    RainMan_PNW likes this.
  5. Feb 13, 2023 at 2:18 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I am right there with you man, i just cant get a handle on that damn garage.
    dondino[QUOTED] likes this.
  6. Feb 13, 2023 at 3:56 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Looks damn good.
    What kind of vinyl did you use, and what sort of nosings? How did you attach it? I need to redo my stairs and am back and forth on doing them in solid wood or some alternative (no carpet…never again).
    dondino likes this.
  7. Feb 13, 2023 at 3:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Bathroom fans are one place where something that sounds close to a jet engine is much preferred over “whisper quiet”
  8. Feb 13, 2023 at 8:30 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Exactly. I’m in there to do business and need the background noise haha
  9. Feb 14, 2023 at 5:20 AM
    motoryder
    motoryder ^^ I probably crashed after that pic
    Rancho Cucamonga, CA
    2500HD AT4
    Thanks! The vinyl was Lowe's P/N 2145162 by Shaw floors. The nosing is the same material formed with a heat gun and bent using a jig. They're attached to the treads with Taylor Dynamic adhesive.
  10. Feb 14, 2023 at 6:30 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I’m curious to know what your jig looks like. Any photos of it? :monocle:
  11. Feb 14, 2023 at 7:29 AM
    motoryder
    2500HD AT4
  12. Feb 15, 2023 at 4:14 PM
    The kids school called in a tizzy today, said they had a water leak in the main building, I told them where the shut offs were and they claimed it slowed/stopped. But this was right at noonish and we just got a freak snow storm that laid 2” of snow. I couldn’t get from them where exactly the leak was, but I had a feeling the roof drain had made a ice dam or something.
    Went and turned all the water back on, the meter didn’t budge! Sweet! So I got out the ladder and went on the roof. Roof drains are right above where the water was coming from……
    AE665073-169A-49FB-9E48-1FFED750C827.jpg 9859D328-BFCC-47C0-B8D5-712C90385991.jpg Crisis averted!
  13. Feb 15, 2023 at 7:04 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    When we bought the house I noticed the large crack in the broken tile porch and knew it needed to be taken care of. But for whatever reason in my mind I didn't put it on the seller, said we'll take care of it. I didn't know what it would involve. I should have.
    I didn't get a photo of the crack from the top, got one under.
    Q2rj8UH9QTx7Q4szlCcTmWvpKdPvkzeS5D_KVeWz_b5e4aeb87f3d1b7fb3c25b9c5d13defee06b1610.jpg
    You can see the big shadow of where the slab closer to ya is lower than what's in front.
    QkTqXXvnBP-TzRatdHMv9kDVTpM5COb9cQwMRb18_be590745de89a27cbf64693df6e96c5649ff4a63.jpg
    You can see some of the damage here, there's a crack on the old section from just behind the back post all the way across to the right.
    So after about a year of talking to various contractors we finally got one who gave us a quote for the slab, found another crew who would do the tile so game on.
    M0i6id3MDvaKLEmf_hDYlCw38FgzgFdUc_AhMIE5_0a11cec216e6577a7b30f5694f22565b7d0b4c85.jpg
    Glad they young...This slab was poured about 1938, how we know, they used newspaper to keep concrete from seeping through the wooden slats they used for a platform. It would appear they recovered the wood because there was no trace of any under the house.
    cLr4xh1mAMx_sTwLy1Bl7nnsXWbsj5Wl1AHEv97k_7c56e920e9201fef6587114da5430b18936fbcbb.jpg
    Cleaned up good and they built new block wall around the old brick to support the steal sheets for the new platform.
    tx8psgGD0tXbOpiUHknGrNQJW67aD2WCQmfxYaTh_8de946e0516b7de6902b5f9906995a1d2e6ac92d.jpg
    shxuqCpWhkobx1c7OaCrSF4BKrvTdZ9TKfXzGGdD_9abbe67de23e21ec77decb7a24d5601bd26c5515.jpg
    tzBXAAuKTi_lINk9x6IeHmnNq0QFevuGyJs-gMOi_dbf512281d69e40cc2dd70ac6f98b4f302319e1a.jpg
    I kept bugging them to make sure they had a falling sloop so water didn't pool up at the house. Looked right to me.
    RJPK82okPZQKkVJKry3rCakO4YnCU86GCK4jTaC4_3b90c6e12a2431f5b728e3146e78b18ca5c74045.jpg
    then the tile guys showed up.
    x1pAG0nmR16_Hzmnisqz8aJebfyjB2P2pNuuiB13_e7ae98cdc271bfee474b0fd5dd90e7c30c0e9c98.jpg
    B91CHvHvm5OdJT3lx9jQBa-4YZjLoGAMNgS4Gj-Q_02822e77b36f6ab9e6a6d5c29098f58545fdc895.jpg
    When they busted up the old concrete they found all sorts of metal farm machine parts in the concrete being used in leu of rebar. A gear to something, parts of a plow, framing, pipes. Those ol' farmers didn't waste a thing, I saved some of the interesting things.
    We are really pleased with the outcome, not a 100% match but the tile on the left was laid down in the 50s so what'da gonna do?
  14. Feb 15, 2023 at 7:38 PM
    TaquitoBandito
    Joel (AKA Bif)
    Looks great to me!
    Moon Puppy[QUOTED] likes this.
  15. Feb 16, 2023 at 2:02 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Rebuild the whole deck? :(
  16. Feb 16, 2023 at 4:32 PM
    snoope
    snoope The Old Man
    Life got out in front of me and had to "enlist" a Professional o_O:bowdown:
    He has us totally back on track and we will be done phase one before the grands get here next week..
    Con & I are still "working it" just on a smaller scale.:thumbsup: and when you're married to an artist...let her paint :p:p46 reno Con painting bath.jpg 46 reno mstr floors.jpg 46 reno master bdrm.jpg
  17. Feb 16, 2023 at 4:34 PM
    Love her shirt
  18. Feb 16, 2023 at 4:55 PM
    snoope
    snoope The Old Man
    I told you, married to an artist... :cool:
    She makes her own Tye-dye T-shirts when the "mood" approaches. :p always has , even when she was coaching.
    Whole team would be at our house making one hell of a ruckus but getting it done....
    Fancier schools warm-ups were $$$ but Con's girls proudly wore
    what THEY MADE... Life's lessons :D:D
  19. Feb 16, 2023 at 4:58 PM
    What did she coach? My mom was a tennis coach!
  20. Feb 16, 2023 at 5:10 PM
    snoope
    snoope The Old Man
    We both coached our kids from age 7 ,the "Real Futbol"... soccer until middle school ...We're both licensed
    And then she started coaching high school teams; was Freshman girls coach a couple years and then Varsity for 10+...
    Not sure what other districts have for "Coaching rules" but during the "Off-season" she couldn't coach them BUT guess who could..:rolleyes::rolleyes:
  21. Feb 16, 2023 at 6:41 PM
    Moon Puppy
    Bob
    2020 Tundra Limited
    Dear lord don't tell my wife!!
    CodyP[QUOTED] and TaquitoBandito like this.
  22. Feb 16, 2023 at 6:48 PM
    snoope
    snoope The Old Man
    No pix BUT 1st coat of paint done... fan running like he!! so I can finish coat tonite...
    Need to be outta the way so we can install flooring & vanity tomorrow. :thumbsup:
  23. Feb 17, 2023 at 2:10 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Anyone have experience with Insignia appliances from Best Buy?
    Word on the street is that they are made by Haier. I'm looking at a french door unit to replace my side by side samsung, which will then be the new garage fridge.
  24. Feb 17, 2023 at 7:07 PM
    WAtundra4x4
    Den
    Wet side WA
    I added an outlet , switch and light outside on my shed. I put the light over the center opening doors of the shed. My wife said she likes the design of the shed light vs what is on the house garage…..
    CF1F9420-D951-4581-841E-CC4C0192D3C5.jpg EC81CA62-9841-4E33-A785-8DC8A891C676.jpg 5F4E2C7D-032E-48B4-83E2-89DD9129EFBE.jpg
    Nbab23, ColoradoTJ, saybng and 11 others like this.
  25. Feb 18, 2023 at 11:51 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    What did you put on your ramp to get that sheen?
  26. Feb 18, 2023 at 2:09 PM
    WAtundra4x4
    Den
    Wet side WA
    Well, it was wet but…. Our upper deck in back is cedar along with a pressure treated wood stairs, which I coated with a semitransparent stain that gives it a sheen of sorts. The shed ramp (my design) is pressure treated wood (2x4s) so I used the same stain as I had left overs and I like it. My other previous house shed I painted the ramp but I like this. My other home’s shed ramp was also pressure treated wood and lasted over 25 years. See photo for details.
  27. Feb 18, 2023 at 7:20 PM
    snoope
    snoope The Old Man
    Finally,
    Master is going back together.... Mounted Con's "oily " rack and the floating shelves are back in place...:thumbsup:
    I even stole a 'lil room in the closet for my clothes :p :D:D
    Floors came out Nice :cool: And only need one transition into the hallway.
    Nbab23, ColoradoTJ, KNABORES and 6 others like this.
  28. Feb 18, 2023 at 7:55 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    That's a lot of young living
    Bama and TaquitoBandito like this.
  29. Feb 18, 2023 at 8:38 PM
    snoope
    snoope The Old Man
    Oh-oh... someone else knows his "oils" o_O
    And that is not all of it, I just built another rack for more bottles :rolleyes:...:rolleyes: pus the many diffusers hiding about the house...;);)
  30. Feb 18, 2023 at 8:54 PM
    TaquitoBandito
    Joel (AKA Bif)
    We've got stacks of that stuff stashed all over the place. ;)
    Bama and snoope[QUOTED] like this.
