Which replacement for stock 2019 headlights
Discussion in 'Lighting' started by IowaGuy, Feb 18, 2023.
  1. Feb 18, 2023 at 5:49 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I have the 2019 stock halogen headlights with the LED DRL strip below them. I would like to replace them as they are a bit scratched and hazed up on the top lip and there is a recall on them. I don't want to have the recall done to wire in the relays.
    Can anyone recommend a set of lights that wont break the bank and don't require rewiring. I cannot afford a $1200 set and I don't do a lot of driving after dark. The factory LED's are @ $300 each but I am wondering if there are decent aftermarket lights that are well sealed and work well. I would also like ones in black housings (?)
    Thanks
  2. Feb 18, 2023 at 6:12 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    Factory led are as good as you will get for the money. They are greAt!
    ATV25 and WFD473 like this.
  3. Feb 18, 2023 at 6:46 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Yup. Those with the @iHacker harness and you'll be good to go.
    ATV25 likes this.
  4. Feb 18, 2023 at 4:54 PM
    IowaGuy
    In Process
    Ok, factory it is then.
    WFD473 likes this.
