AZ BS
Discussion in 'Arizona' started by Rextinkleton93, Jan 31, 2018.
  1. Jan 27, 2023 at 8:07 AM
    #2911
    AZBoatHauler
    So.Arizona
    tsinajinii, AT x AT, reywcms and 2 others like this.
  2. Jan 27, 2023 at 8:23 AM
    #2912
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    ZUK is the man if you can do the 3rd member R&R. He did my rear in Oct and is doing an elocker front in a few weeks.
    AZBoatHauler likes this.
  3. Jan 27, 2023 at 9:23 AM
    #2913
    coTony
    Tony
    Montrose, CO
    I had mine done at Arizona Toy Pros near 202 and McKellips in Mesa
    They did both front and rear a few years ago. Good folks there
    mart1nezdaniel likes this.
  4. Jan 27, 2023 at 9:44 AM
    #2914
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Arizona Driveshaft
    (480) 898-1957
    https://maps.app.goo.gl/UwbcyU8CtAF2sqMy9
    These are the guys that can lengthen aluminum driveshafts and balance them for super tall lifts. They have a very good reputation and have been around for a long time. Highy recommended shop.
  5. Jan 27, 2023 at 11:53 AM
    #2915
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    That bored at work eh?
    Why don't you drive over to NM Arizona and program my nanny disabler.
    TRDFerguson[QUOTED] likes this.
  6. Jan 27, 2023 at 12:11 PM
    #2916
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I believe in you. You've got this!
  7. Jan 31, 2023 at 10:26 PM
    #2917
    Goofinator
    Goofinator New Member
    Bernard
    Hey everyone/ anyone when installing a single add a leaf or the icon add a leaf pack will the stock U bolts work or would I need new longer U bolts?
  8. Feb 1, 2023 at 6:04 AM
    #2918
    coTony
    Tony
    Montrose, CO
    The RXT leaf pack came with new U bolts I thought
  9. Feb 1, 2023 at 6:07 AM
    #2919
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    U bolts are single use, so you'd need new ones either way when working on your leaf packs. But to answer your main question, you will need longer than stock U bolts for most add a leaf kits.
    He's not talking about the RXT though - the Icon Expansion Pack does not come with U bolts, as far as I know.
    coTony[QUOTED] and FrenchToasty like this.
  10. Feb 1, 2023 at 6:17 AM
    #2920
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Pretty sure mine came with new ones
    coTony likes this.
  11. Feb 1, 2023 at 6:23 AM
    #2921
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You're right, I just checked their install guide and it lists the U bolt kit in the package contents.
    helidave[QUOTED] and coTony like this.
  12. Feb 1, 2023 at 7:47 AM
    #2922
    Goofinator
    Bernard
    Cool thank you for the replies I might go with the icon add a leaf pack then, yes not the RXT
  13. Feb 6, 2023 at 12:08 PM
    #2923
    coTony
    Tony
    Montrose, CO
    Anyone know a good mechanic shop in the south valley that I can get an axle boot clamp replaced?
  14. Feb 6, 2023 at 12:14 PM
    #2924
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You could try Greulich's at Chandler Heights and Arizona. They seem to be able to handle most things
  15. Feb 6, 2023 at 12:37 PM
    #2925
    Goofinator
    Bernard
    Not sure how South but ORW, and desert rat
  16. Feb 6, 2023 at 12:42 PM
    #2926
    Vizsla
    Vizsla 2 = 2.5
    If it’s the small clamps, these are what I used on mine. Was helpful because it allowed adjusting the boots for clearance as needed. Have the tools for the clamps RCV uses, but the clamps are useless because they pinch the boot when tightened and leak.
    https://www.amazon.com/gp/product/B06Y27RBMV?ie=UTF8
  17. Feb 6, 2023 at 12:59 PM
    #2927
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Just had the FJ worked on at this shop attached. Great work and cool team over there.
    e30cabrio, WBW and AZBoatHauler like this.
  18. Feb 6, 2023 at 1:05 PM
    #2928
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    The OEM uses Oetiker 167 series clamps, 10mm wide x 1mm thick stainless steel. I know the inside boot clamp big side is sized 109mm ID. The outside boot clamp big side is sized 117.5mm ID. The small ones are the same size, but I need to look at it when I get home. I just rebuilt one for spare this last weekend.
    Update: small ones are 38mm ID.
  19. Feb 6, 2023 at 2:00 PM
    #2929
    coTony
    Tony
    Montrose, CO
    I just talked with the guy at RCV and the straps have been redesigned so he is sending me some. I will see what I can get done. Thanks
    reywcms likes this.
  20. Feb 10, 2023 at 12:10 PM
    #2930
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Any input on lug locks for TRD PRO rims would be great, there's lots of data, mostly contradicting it's self.
    Coopers & rims go on in the morning.
  21. Feb 11, 2023 at 3:44 PM
    #2931
    e30cabrio
  22. Feb 17, 2023 at 12:28 PM
    #2932
    coTony
    Tony
    Montrose, CO
    Got parts in from RCV so the clean up starts either later today or in the morning
    reywcms likes this.
  23. Feb 17, 2023 at 2:54 PM
    #2933
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    REGISTRATION IS OPEN!
    Hit the website and get registered for T2S 2023! April 25-30
    Check out the new Overland Detachment option.
    www.tundrastosedona.com
  24. Feb 19, 2023 at 7:03 PM
    #2934
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
  25. Feb 20, 2023 at 11:43 AM
    #2935
    coTony
    Tony
    Montrose, CO
    Well first time I tried this and got it sealed… it appears. I drove it for 50 miles doing 70-80 MPH most of the time then when I turned around I did an intentional 3 point turn around over and over again at full lock. When I got her home she was bone dry.
    The first clamp was too big and the clips would not align as it was designed. They sent me a few of them and I got them all out and to my surprise each was a different size slightly. WTF is that all about RCV? I assumed it would be a set size. They did tell me that it is a new design for them so I assume everything is new. Bottom line is she looks happy!
    reywcms and TucsonTundra1794 like this.
  26. Feb 21, 2023 at 7:17 AM
    #2936
    helidave
    flagstaff
    2015 DC 4x4
    Hey Tucson bros, any recommendations for offroad/dispersed camping spots that are within an hour or two of town? Got a family thing in southeast tuscon and want to come down a couple days early and see the sights.
  27. Feb 21, 2023 at 7:20 AM
    #2937
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I'd say reddington pass or camp Kennedy are both good. Not exactly sure where your staying.
  28. Feb 21, 2023 at 7:21 AM
    #2938
    helidave
    flagstaff
    2015 DC 4x4
    The family thing is near the air and space museum.
  29. Feb 21, 2023 at 7:36 AM
    #2939
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Your closer to Camp Kennedy from there. I know there is more out that way but I haven't done much over there.
    helidave[QUOTED] likes this.
  30. Feb 21, 2023 at 8:08 AM
    #2940
    Azblue
    The Dirty T ( ^_^)_且
    Gardner canyon is about an hour away. Also Parker canyon lake is about 1.5 hours, has forest service campgrounds and some dispersed areas.
