General Supercharger Thread
  1. Feb 16, 2023 at 3:33 PM
    #5611
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Oh man, I’m gonna miss the Frankintake.
  2. Feb 16, 2023 at 3:48 PM
    #5612
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Is the tube from here?
    https://performancemrp.com/c-1389191-air-intake-components-air-intake-pipe.html
    How do you get it with the MAF mount?
    Saltyhero13[QUOTED] likes this.
  3. Feb 16, 2023 at 3:54 PM
    #5613
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
  4. Feb 16, 2023 at 3:56 PM
    #5614
    e30cabrio
    Thanks, what diameter?
  5. Feb 16, 2023 at 3:59 PM
    #5615
    armyoffoo
    armyoffoo Member
    Cypress, TX
    4.5" to match up with prospeed, but you can run whatever size you want with the appropriate filter and reducer for the throttle body, will require tuning when changing inlet diameter.
    Saltyhero13 and M3Tundra-JK like this.
  6. Feb 16, 2023 at 4:00 PM
    #5616
    Saltyhero13
    Saltyhero13 Throbbing Member
    Yes it was a custom order through MRP. Email them and you tell them your specs like what OD, length, MAF, and screen/no screen they will come back with a quote. Took about two weeks from order to delivery for an order of two. Quality is excellent like their other products.
  7. Feb 16, 2023 at 4:05 PM
    #5617
    Saltyhero13
    It is still a bit of a frankenstillen, pretty ghetto fabrication. I'm still using a roof flashing and a duct coupler to seal the air box hole. For off the shelf products that hole is sealed up pretty good though. Desperate times require desperate measures.
    Silver17[QUOTED] and M3Tundra-JK like this.
  8. Feb 16, 2023 at 4:11 PM
    #5618
    Saltyhero13
  9. Feb 16, 2023 at 4:13 PM
    #5619
    armyoffoo
    armyoffoo Member
    Cypress, TX
    How much do you have to pay for that kind of action?
  10. Feb 16, 2023 at 4:15 PM
    #5620
    Silver17
    Eastern PA
    Lol, that seriously looks so much better though. I’d run it myself if I didn’t have to spend a ton of money to fab up the same thing. I admire your air intake budget, you’ve had all the pricey options as you have been striving to make the perfect one. :thumbsup: That looks perfect between being 4.5”, the honeycomb a few inches before the MAF, and being a true cold air box with a little Ram air action on the front from the stillen box.
  11. Feb 16, 2023 at 4:21 PM
    #5621
    Saltyhero13
    $173 for 8 inch w/MAF or $207 for 8 inch w/MAF + Screen not including S&H.
    In my case 8 inch was just about right falling about 1/2" from mouth of the air box with enough play on the TB end to angle the intake. I made up the rest with some fuckery using a hump coupler and the big filter 6" to 4.5" bellmouth adapter. Roof flashing and duct couple to seal the hole since I don't have fancy shit like a 3D printer. Leaves enough room to change out the filter without too much hassle.
  12. Feb 16, 2023 at 4:25 PM
    #5622
    e30cabrio
    I have an AFE box, just looked, it's pretty big on the box side. I'll be tuning when the SC goes in so if it already has this that'll be fine.
    Hopefully between the huge coupler the AFE came with and something similar at the TB side I'll make it cause I ordered that one :p
    Thanks!
    M3Tundra-JK and Saltyhero13 like this.
  13. Feb 16, 2023 at 4:29 PM
    #5623
    Saltyhero13
    Thanks. I was worried that the length would be off but I am happy with how it came out.
    You are correct, after all is said and done it is not cheaper than the PS :spending:. Stillen is $350-450 + $200 for the tube and the $$ spend on couplers, clamps and fittings. The filter was around $100 too. Shelf looks like a freakin boost catalog. The upside is I'm not seeing high IATs +50 over ambient and my temps drop fairly quickly too.
  14. Feb 16, 2023 at 4:34 PM
    #5624
    Saltyhero13
    Good luck and be patient. There may be some trial and error in getting all the fitment right. I wanted everything reversible just in case I couldn't get it to work hence why I went with the ghetto fabrication using off the shelf parts.
    Post pics when you get it right would love to see this done with other boxes. For what PS charges for it's box it is shamefully fabricated. They easily make double to triple on that box.
    Keep in mind AFE is making a Tundra S/C air box from what has been posted here.
    I'm using this AFE filter:
    SKU: 21-91119
    reywcms and M3Tundra-JK like this.
  15. Feb 16, 2023 at 4:40 PM
    #5625
    e30cabrio
    Saltyhero13 likes this.
  16. Feb 16, 2023 at 4:47 PM
    #5626
    Saltyhero13
  17. Feb 16, 2023 at 4:51 PM
    #5627
    snivilous
    SW UT
    300k+ Supercharged 2008
    Looking through @e30cabrio stock datalogs, the stock 5.7 @ ~1000ft elevation is at nearly 85% injector duty cycle. Not surprising then that a "stage 1 harrop" runs out of fuel, considering there is minimal headroom with the stock injectors and stock engine.
  18. Feb 16, 2023 at 5:20 PM
    #5628
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  19. Feb 16, 2023 at 5:22 PM
    #5629
    Silver17
    Eastern PA
    Airaid supposedly used to make this pretty sweet Intake just for supercharged tundras. I guess they stopped when the demand wasn’t there.
    Jcmf52 likes this.
  20. Feb 16, 2023 at 6:15 PM
    #5630
    Saltyhero13
    That one looks like it would seal up fairly well. Unlike some of the other hot air intakes I've seen of similar design.
    Wish I had room for that giant asymmetrical filter. Never happy this one.
    ZPhilip likes this.
  21. Feb 16, 2023 at 6:21 PM
    #5631
    Saltyhero13
    Mating to the opening will be tricky with the power steering resi in that spot if I am not mistaken. Doable though. He could mock something up if he wanted to replicate the Stillen. Catch cans will be in the way too if he has them.
  22. Feb 17, 2023 at 6:01 AM
    #5632
    ssmokedz
    Shelton CT
    That came out good!
  23. Feb 17, 2023 at 8:59 AM
    #5633
    e30cabrio
    Dusted the MPV!2+ off & connected it to the laptop I use for cars, not seen, tried numerous ports & cables no, eventually it said it needed a firmware update I clicked OK, the green light has been flashing since about 7:25PST created a ticket about 7:27, no phone number is available, happy I'm not.
  24. Feb 17, 2023 at 9:11 AM
    #5634
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Try downloading drivers from Hpt's website?
  25. Feb 17, 2023 at 11:41 AM
    #5635
    e30cabrio
    There was an update to the program, no go, they responded I needed to do a bunch of things that REQUIRE IT COMMUNICATING. Eventually, after numerous reboots I got it to communicate.
    The irritating thing is they made no suggestions outside after you fix the issue send us logs & files you will get when it works. I don't need help after it works.
    M3Tundra-JK likes this.
  26. Feb 17, 2023 at 2:09 PM
    #5636
    Saltyhero13
    Minor update. So the MRP intake is a true 4.25" ID which is smaller than ProSpeed. Prospeed is hard to measure since it is elliptical and not 4.5" across at every point. Not exactly an equivalent substitute since it has about ~11% smaller cross section; probably smaller with the screen installed. Could explain the rich bank codes I saw on very very cold days.
    Truck started fine but had a slightly rough idle. Drove fine. Scheduling a retune to get everything right.
    Silver17 and M3Tundra-JK like this.
  27. Feb 17, 2023 at 2:57 PM
    #5637
    M3Tundra-JK
    Scott
    2005 GX470
    Got the 2.3" griptec pulley installed. Also bought a press!
  28. Feb 17, 2023 at 2:58 PM
    #5638
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Yeeeeehaw! Which press...HF or marginally better?! Time to throw it all on and tape your junk down! You're in for a treat!
    snivilous[OP] and M3Tundra-JK like this.
  29. Feb 17, 2023 at 3:04 PM
    #5639
    e30cabrio
    HulkSmurf14 likes this.
  30. Feb 17, 2023 at 3:13 PM
    #5640
    M3Tundra-JK
    Scott
    2005 GX470
    Ya, HF 20 ton press. Decent price at $230. Getting so close to being finished! The fuel lines/rails com in Monday. Really hoping to hot rod this thing around town next weekend!
    @Fastlane47 what fittings did you use? I've been looking for some 1/2" NPT Male to 3/4" Barbed connectors. One preferably at a 45* angle, the other could be straight. For the bottom connection, between the IC pump and Intercooler, I was going to get two 90* 3/4" Barb connectors to make the necessary 180* turn.
