Coastal Off Road Bumper...after a little repair
Discussion in '1st Gen Tundras (2000-2006)' started by MI-FL off roader, Feb 15, 2023.
  1. Feb 15, 2023 at 5:21 PM
    MI-FL off roader
    MI-FL off roader [OP] New Member
    Brett
    Merritt Island, Florida
    03' 4Runner 4.7 and 12' Limited 4Runner
    03' Dirt King LT- CaliFab LT Rear
    My Son purchased this DBL Cab a little over a year ago and recently
    took a pretty good crunch to the hood, drivers fender, and core support.
    So we spent some time disassembling and searching the junk yards.
    Found the replacements in the same color and proceeded to hack shit up with the sawzall.
    Took us awhile to get it all lined up and measured out.
    A little seam sealer and some rivets and everything fit pretty well. On to the bumper...
    1.jpg 2.jpg 3.jpg 4.jpg 5.jpg 6.jpg 7.jpg 8.jpg 9.jpg 10.jpg 11.jpg 12.jpg 13.jpg
    JakeJake, KNABORES, Mustanley and 4 others like this.
  2. Feb 15, 2023 at 5:29 PM
    MI-FL off roader
    Brett
    So now instead of trying to fit plastic back in there we opted for the Coastal kit. Have to say for two knuckleheads who are not fabricators or welders, this kit seems to be perfect for beginners.
    Time will tell how well it looks, but for now it seems to be coming together pretty well.
    JasonC., Mustanley, w666 and 3 others like this.
  3. Feb 16, 2023 at 6:52 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Wow, our trucks are practically going to be twins. I have an '04, but same bumper installed after a front end collision... same cab, same color, same front suspension, trd wheels... your repair work looks better than what my body shop did though. Can't wait to see it once finished.
  4. Feb 16, 2023 at 2:52 PM
    MI-FL off roader
    Brett
    Looking good! I like those color rims. My Son wants to change out his TRD rims, they're faded aftermarkets I had laying around but the width and offset works well with his 285s, so they'll be hanging around for awhile.
    We also had to go about 4 hrs one way to find this color body parts at a salvage yard. They matched up ok.
  5. Feb 16, 2023 at 2:54 PM
    MI-FL off roader
    Brett
    Got quite a bit pieced together today.
  6. Feb 16, 2023 at 4:49 PM
    Icepuddle
    Icepuddle New Member
    Kris
    North Idaho
    03 AC SR5 TRD 4x4
    Any surprises or issues with the bumper? I'm still waiting to hear back from Coastal on a group buy. Your work looks great!
    Jake92 and FrenchToasty like this.
  7. Feb 16, 2023 at 4:55 PM
    @Casper421
    Did you add additional welding/plating behind the 4 bolts back into the frame?
    I’d highly suggest this for @MI-FL off roader, that flat plate welded to the frame that the entire bumper is holding onto, doesn’t seem like the strongest single point attachment.
  8. Feb 17, 2023 at 2:44 AM
    MI-FL off roader
    Brett
    Thank You. Fitting the core support to line up was no joke, lot of mock up trial and error. As far as the Coastal kit, no issues and we feel its really well made. So far we've been impressed with how it's going together. I've learned enough about welding in the last year to allow us to piece it together and tack it in place. Luckily my neighbor is the one with the mig skills. So we prep and tack, and he runs the glue when we have a section ready. Really wish I'd learned to weld when I was younger. As of now, I need LOTS of practice.
    Icepuddle[QUOTED] likes this.
  9. Feb 17, 2023 at 3:24 AM
    MI-FL off roader
    Brett
    Yea I looked at that portion. I was actually surprised how stout those two frame plates are, when we had to pry off the oem bumper. But I agree, if this truck was going to be an offroad rig with lots of recovery action, I would highly recommend reinforcing. I'm curious how a true fabricator would strengthen this up. Reinforce the existing plates or cut them off and fab up some thicker ones.
    My Son isn't really into off roading (Tundra is 2wd), so there won't be a winch installed saving quite a bit of weight. This is basically a way to save the nightmare of trying to aquire/assemble all the oem bumper parts, and the Coastal looks good too.
    He wanted a Shrockworks like I have on my 5th gen 4Runner, but luckily they didn't list one for 1st gen Tundras, or he might have gotten ripped off like several others did when Jim Shrock abruptly shut his doors, screwing over both his customers and employees. Hopefully some restitution is being worked out for those that were affected.
  10. Feb 17, 2023 at 12:33 PM
    MI-FL off roader
    Brett
    @FrenchToasty I was looking over the instructions and remembered they do have side brackets that bolt to the frame at the body mount cradle. So that makes me feel a little better about my Son's application, but anyone doing heavy recovery would do well to reinforce all of it. The end cap fastening points aren't the thickest gauge steel.
    Icepuddle and FrenchToasty like this.
  11. Apr 5, 2023 at 12:30 PM
    MI-FL off roader
    Brett
    Bumper is finally out for powder coating.
  12. Apr 5, 2023 at 12:36 PM
    Mustanley
    Hendersonville, NC
    What notch are those Eibach shocks/springs set at and did you have to change them before install or any point thereafter? Mine do not lift near as much as what you've got there.
  13. Apr 5, 2023 at 3:20 PM
    MI-FL off roader
    Brett
    It's in the middle of the settings (there are 2 more notches above the perch), but the truck is on a bit of a slope, so it might drop a little on level ground.
    Mustanley[QUOTED] and tyr0981 like this.
  14. Apr 5, 2023 at 4:17 PM
    Mustanley
    Hendersonville, NC
    I bought mine pre-assembled from toytech lifts with 2.5" Eibach lift shocks. The perches are set on the bottom notch and that's supposed to give a 2.5 inch lift. I think I need to go up to the middle though. Maybe that lift is attained on a 2wd access cab.
    I'm running 32" skinny tires (255/75/17) and there's not much gap between tire and fender.
    MI-FL off roader[OP] likes this.
  15. Apr 5, 2023 at 4:30 PM
    MI-FL off roader
    Brett
    @Mustanley we took the Eibachs off after the initial install and raised them to the height they're at currently. This was to level it out with the rear and before my Son had his accident and we hadn't even considered a steel bumper. So yea you might want to go up a notch maybe?
    Mustanley likes this.
  16. Apr 7, 2023 at 9:45 AM
    MI-FL off roader
    Brett
    Powder coat guy sent these over this morning. Looks good so far.
    FirstGenVol, FrenchToasty and shifty` like this.
  17. Apr 7, 2023 at 9:55 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Y'all did some damn good work - even better when it's father & son spending time together. My 4 year old already likes to play in the garage with me - stuffs screwdrivers in weird places in my front suspension so I have to go back under and pull everything out before I take a drive...
    MI-FL off roader[OP] and shifty` like this.
  18. Apr 7, 2023 at 1:33 PM
    MI-FL off roader
    Brett
    Thanks!
    The Coastal kit gets all the credit for how well the bumper turned out. The core support and fenders lining up with the doors and hood as well as they did was quite a bit of good luck.
    We had a couple of Father/Son stubborn arguments during the process, but we have a pretty tight relationship.
    Ryan was the same way when he was little, "I fixed it Daddy".
  19. Jan 24, 2025 at 9:43 AM
    MI-FL off roader
    Brett
    UPDATE Finally:
    Ryan finally found the money to have Maaco color match the roof, hood/grill, and fenders.
    Far from perfect, but looks pretty good. We'll see how it holds up.
    Bmktw2, shifty` and KNABORES like this.
  20. Jan 24, 2025 at 9:44 AM
    MI-FL off roader
    Brett
    Next up on the list....probably need to start a build thread now.
    Bmktw2 and JakeJake like this.
  21. Jan 24, 2025 at 9:49 AM
    And the award for “longest circle back around” goes to……
    :rimshot::rimshot::rimshot:
    @MI-FL off roader !!!
    thanks for coming back to share the updates!
    shifty` and MI-FL off roader[OP] like this.
  22. Jan 24, 2025 at 9:51 AM
    MI-FL off roader
    Brett
    LMAO Fuqing life gettin in the way.....
    KNABORES[QUOTED] likes this.
