Well that's not good...
Discussion in '2.5 Gen Tundras (2014-2021)' started by J.D.'s Username, Feb 15, 2023.
  1. Feb 15, 2023 at 6:31 PM
    J.D.'s Username
    J.D.'s Username [OP] New Member
    J.D.
    2012 Tundra 5.7
    Bought this 2014 a few weeks ago from a private seller. Immediately after purchase (of course) the belt started squealing. Faint at first, now constant and louder. I also noticed that the coolant level was a little low, so I topped it off a few days ago.
    I got under it to today, dropped the skid plate and was planning on taking tension off the belt and checking all the rollers and free spinning parts for seizure. When the skid plate came off, I noticed that there was a considerable wet spot under the power steering pump that has been leaking (the belt squeal). Then I hopped up and saw another wet spot on the radiator :(.
    Taking it in to the shop on Tuesday to get checked out. Expecting a new radiator and PS pump :mad:.
    bulldog93 likes this.
  2. Feb 15, 2023 at 6:38 PM
    Replace that oil cap. It has chunks broken off.
    bulldog93, Taco-Spike and MedCityMoto like this.
  3. Feb 15, 2023 at 6:42 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Those pics look like it could be coming from the oil filter housing. If someone installed it incorrectly (as in, put the outer O ring in the wrong spot, which is unfortunately not uncommon), it could be flinging oil everywhere.
    How does your oil level look?
    This happened to me by the way with my old 4runner. The very last time someone else changed my oil.
  4. Feb 15, 2023 at 6:45 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I'd volunteer my old plastic housing, he'll just need to transfer the inner tower over to it.
  5. Feb 15, 2023 at 6:55 PM
    AZBoatHauler
    So.Arizona
  6. Feb 15, 2023 at 7:15 PM
    J.D.'s Username
    J.D.
    2012 Tundra 5.7
    That's actually exactly what it is. Thank you for the input! I would much rather replace the oil filter housing than a power steering pump.
    I am still worried about the radiator...
  7. Feb 15, 2023 at 7:21 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I know people do it all the time on this forum to use the metal housing but this video has some pretty solid information on doing that, considering you're messing with the spring tension of the bypass valve. https://youtu.be/G_vl2AYe7Yg
    rruff, the red and Mike59 like this.
  8. Feb 15, 2023 at 7:34 PM
    Terndrerrr
    Music City
    6UR-FE
    Yeah, definitely make sure where that wet spot is coming from. But if it's from oil spurting out of the oil filter housing, it could be hitting the fan and flinging onto the radiator. That doesn't look like a coolant leak to me.
    Is your oil level low? Did you check the dipstick?
    I also definitely agree with the others who said to replace that filter housing. It doesn't get cracked like that for no reason. Some neanderthal with a torque wrench put way too much pressure on that thing at some point in its life.
  9. Feb 15, 2023 at 7:47 PM
    J.D.'s Username
    J.D.
    2012 Tundra 5.7
    I'll have to check tomorrow. I was scrambling to get some things done tonight. There hasn't been anything leaking out from under the truck where it has been parked, but there is definitely oil coming from that housing. The cross bar under it has a damp spot. I didn't notice anything stained or pooled up in the skid plate either, but I'm sure it has been slinging fluid onto the belt.
  10. Feb 15, 2023 at 7:47 PM
    J.D.'s Username
    J.D.
    2012 Tundra 5.7
    Very kind of you! I might take you up on that.
  11. Feb 16, 2023 at 6:40 AM
    MedCityMoto
    I'm not worried, I moved the spring and everything over so the only difference is in the durability of the material that surrounds the oil filter, but thanks anyway. I'm comfortable giving away my otherwise-intact plastic housing if he wants it.
    Terndrerrr likes this.
  12. Feb 16, 2023 at 6:42 AM
    MedCityMoto
    If you drop me your address I'll throw it in the mail later tonight or tomorrow, no worries
