Anyone running 35x12.50r18 F ply tires?
Discussion in '3rd Gen Tundras (2022+)' started by Dakota3645, Feb 14, 2023.
  1. Feb 14, 2023 at 3:42 PM
    Dakota3645
    Dakota3645 [OP] New Member
    Dakota
    2022 Tundra SR5 - Army Green
    I'm sure it's been discussed, but with a lot of 35x12.50r18 tires for the big brands being F ply (12 ply), I'm curious to see if anyone has real world experience running them and their thoughts?
    I ordered a set of the new Toyo Open Country R/T Trail in 35x12.50r18. Spec sheet has weight at 66 lbs so still fairly light for that size of tire, they are 12 ply though.
    Post pics and your thoughts below if your running a 12 ply tire on your Tundra!!
  2. Feb 14, 2023 at 5:06 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Don't figure you will get many pictures on this of F ply.
  3. Feb 14, 2023 at 10:35 PM
    GoFast157
    GoFast157 New Member
    35x12.50r18 Ridge graps here, no complaints. Tires feel more stable than factory, less of a jello feel while cornering over bumps. Yet no real increase in the road feel or jarring effect stiff tires can sometimes add. Just did 5k mile+ road trip and averaged 17.4mpg (hand calculated).
  4. Feb 15, 2023 at 9:27 AM
    JoeInMinn
    JoeInMinn New Member
    2022 1794 Trd
    Mine are F ply do to the 20 inch wheel and brand. Remember that load index plays a part so to get the max weight on the tire in that category it needs to be "F" , but the load index would be less than say a comprable 285/75/20 E tire and ride better. I have no complaints they are certainly not as soft as stock but I am not complaining rides fine for me, probably be even better when I take off the wescott and put on Elkas or Dobinsons.
