  1. Feb 13, 2023 at 3:44 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I'm running full sythetic valvoline "squeeze pouches" 75w90 in all my diffs and TC. Though to be fair I'm almost certain I don't have the LSD. No issues at all for me.
  2. Feb 13, 2023 at 5:27 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Why not just pick up some additive & dump it in before you go tossing out the new fluid?
    What Does a Limited-Slip Additive Do? - AMSOIL Blog
    However, depending on the differential’s friction material and degree of clutch wear, chatter can still sometimes occur. The addition of AMSOIL Slip Lock will eliminate chatter in mechanically sound differentials.
    FrenchToasty and KNABORES like this.
  3. Feb 13, 2023 at 6:09 PM
    I was always taught you shouldn't put additives into lubricants with a lubricant additive package already included. "It's not wise to double-up on lubricants..."
    I wouldn't do it without the blessing of someone who was a hell of a lot more familiar with lubricants than I am.
    Mobil1's "LS" lubricants already have an additive package rolled in.
  4. Feb 13, 2023 at 6:11 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    i'll ask a chemist. my thought is you're going to throw it away anyhow, but I'll ask the chemist.
    RUSTYNUTS likes this.
  5. Feb 13, 2023 at 6:30 PM
    I mean, from my side, I'm happy to just drop $70-80 and 20 minutes on a fluid that won't chatter, then not think about it again.
    But if you hear something interesting, I'm curious. I know Redline and others sell (specifically) slip-only friction modifier package.
    NUDRAT likes this.
  6. Feb 13, 2023 at 6:33 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    in retirement he studies motor oil properties for fun. We'll see what he has to say.
  7. Feb 13, 2023 at 7:55 PM
    Okaaaay…even as an engineer, I find that strange.
    NUDRAT[QUOTED] likes this.
  8. Feb 13, 2023 at 7:59 PM
    Translation: Bro likes the lube.
  9. Feb 13, 2023 at 8:11 PM
    Casper421
    In the woods
    06 DC
    Mall crawler mode…engaged!!
    0238E56C-15BA-4055-B4D0-784A21C36C89.jpg 0C439857-8D20-46A4-9F2F-DBEEFB3CCF04.jpg
    NUDRAT, bmf4069, sportbike37 and 3 others like this.
  10. Feb 13, 2023 at 9:25 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  11. Feb 14, 2023 at 3:22 AM
    That corrected or at the wheels HP? Either way that thing is gonna be a rocket!! Like 911 Turbo power to weight territory
  12. Feb 14, 2023 at 5:49 AM
    DOH!
    empty_lord[QUOTED] likes this.
  13. Feb 14, 2023 at 6:11 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    $115 to renew registration for the car and truck. I love going into the clerks office right after they open. In, and out. Inside less than 3 minutes.
    Squared away for another year.
  14. Feb 14, 2023 at 7:42 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    Refurbished/rebuilt an old hi lift jack made by Jackall from Canada. A DIY bed rack design is in the works as well.
    snoope, txagg, bmf4069 and 7 others like this.
  15. Feb 14, 2023 at 9:21 AM
    empty_lord
    05 rollover special
    Wheel
    And I’m going to shoot for more lol
    RUSTYNUTS, txagg and bmf4069 like this.
  16. Feb 14, 2023 at 9:23 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Guy finished up my timing belt/water pump/etc. job. He was trying to diagnose why the passenger inner CV axle boot is slangin’ grease like an abuelita making tacos dorados and couldn’t find any tears or loose clamp or anything. Any thoughts?
    He also noted a click coming from the driver side inner tie rod so he’s going to do all 4 when he does the LBJs. Pics of TRE and lower ball joints below.
    oscardog86 likes this.
  17. Feb 14, 2023 at 10:58 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    That thing sounds like it doesn't want to stop revving, Crazy!
  18. Feb 14, 2023 at 1:20 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Working on replacing my Flowmaster, it was fun while it lasted.
    While getting parts at my go to Toyota parts guy in Jackson, TN, he looked up my 04 Cats. There are 20 ea driver side available in the system around the Country. There is not a single Passenger side 04 available.
    Will be looking at MagnaFlow 24406 as a replacement if I decide to replace passenger.
    Anyone know much about aftermarket Cats such as Magnaflow ?
    MagnaFlow 24406 Direct-Fit Catalytic Converter 00-04 Toyota Tundra 4.7 – Modern Day Muffler
  19. Feb 14, 2023 at 1:30 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    WOW, I ordered that same one from scAmazon in 2018 for $195. It been problem free for 5 years but I just recently got a P0430 code (in addition to an intermittent P0420 I've been getting for the last 2 years) so I'm about to replace both downstream O2 sensors before I pass judgement on this Magnaflow cat.
  20. Feb 14, 2023 at 2:02 PM
    empty_lord
    05 rollover special
    Cams will happen. Just not sure if they’re going in this engine, or my “rev2” I’ve got a really clean set of heads just waiting for port work and all… I’ll likely be putting another together to try and reach for 400hp
  21. Feb 14, 2023 at 2:08 PM
    Can't say anything with direct experience, just that we haven't yet heard about Magnaflow, Walker, or the Summit Racing store brand cats throwing a code. Other brands, yes. I looked thru Walker's stuff and they're supposed to make a direct-fit part, but trying to make heads or tails of what should go on my truck specifically was a pain in the ass.
    BubbaW[QUOTED] likes this.
  22. Feb 14, 2023 at 4:54 PM
    NickB_01TRD
    KY
    I was the first one in the door last month. Yup about 5 minutes or so and done.
    bmf4069, NUDRAT and FrenchToasty like this.
  23. Feb 14, 2023 at 5:41 PM
    Over here, we just walk into the grocery store and use a digital kiosk to renew. Takes about 2 minutes. But you need to go to an emissions test place 48-72 hours in advance and pass or it won't let you.
  24. Feb 14, 2023 at 5:42 PM
    I do it online. Takes 10 minutes to do.
    NUDRAT, FrenchToasty and oscardog86 like this.
  25. Feb 14, 2023 at 5:43 PM
    oscardog86
    oscardog86 New Member
    Southern California
    If that, doing it online is so easy
  26. Feb 14, 2023 at 5:44 PM
    It’s when I haven’t had my :pccoffee:
  27. Feb 14, 2023 at 6:44 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Where did you get that fairlead? I’ve been looking all over for a gold anodized one to go with my overall gold/black color scheme. Looks sharp.
  28. Feb 14, 2023 at 7:01 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Probably Subaru glass. :rofl:
  29. Feb 14, 2023 at 7:08 PM
    Casper421
    In the woods
    06 DC
    You too can have this gold fairlead if you buy a certain black one from Amazon and let the sun turn it this gold color.
    YaeKoo 10 inch Billet Polished Glossy Aluminum Bolt-Pattern Hawse Fairlead Mount Synthetic Winch 8000-15000 LBs for ATV/UTV Rope Cable (Anodized Black, 10'') https://www.amazon.com/dp/B07VQ6VNMH
    FirstGenVol, bmf4069, JasonC. and 2 others like this.
  30. Feb 14, 2023 at 7:46 PM
    empty_lord
    05 rollover special
    Lol, poor tundra survives a rollover with the original window. A pebble decides to remove it from existence
