Help me fix/replace the Infotainment system in my 3rd Generation 2022 Tundra!
Discussion in '3rd Gen Tundras (2022+)' started by LoneMoose, Feb 13, 2023.
  1. Feb 13, 2023 at 5:27 PM
    LoneMoose
    LoneMoose [OP] New Member
    2022 Tundra SR5 TRD CREWMAX
    tonneau cover, Backrack, fender flairs, running boards
    I own a 2022 Toyota Tundra SR5 with 8-in Audio Multimedia, with wireless Apple CarPlay & Android Auto capability.
    The nav/multimedia unit is terrible. I had a 2018 Tacoma, and four years later, I found that the infotainment system had taken several steps backward.
    • Voice commands always say, “I don’t understand your request.”
    • Playing music via the in-dash USB port is terribly complicated and limited
    • There is no home screen where I can choose the info displayed.
    I am looking for an aftermarket replacement that supports all the OEM capabilities, like cameras, backup lines, system config, etc., while providing a richer user interface and better features, like
    • An actual home screen where I can choose the display from multiple sources of info, like weather, time, nav, audio, etc.
    • Voice commands that actually work
    • To access music sources other than XM radio, like the in-dash data USB port, by voice command.
    • Use Google Maps or Waze without Android Auto
    • And so on
    It’s been a while; somebody must’ve found something by now.
    If not, how do I use the existing system in a way that doesn’t suck??
  2. Feb 13, 2023 at 8:55 PM
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    Are you using the Google/Apple voice commands or the Toyota ones?
  3. Feb 14, 2023 at 7:12 AM
    LoneMoose
    I'm using the Toyota commands. They worked fine in my 2018 Tacoma. I'm trying to avoid using Android Auto; I can't seem to get it working right. Plus I shouldn't need one multimedia device to be able to use the other.
  4. Feb 14, 2023 at 1:47 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    There are some command in the multimedia manual around page 40, but I have found using "destination" for the navigation system work every time. E.g. "destination walmart" or "destination city state"
