  1. Feb 13, 2023 at 7:09 PM
    Sunnier
    Sunny
    San Diego, CA
    Yep!
  2. Feb 13, 2023 at 7:28 PM
    Noice! Plan to keep it two tone or eventually paint the fenders and rear quarter panels?
  3. Feb 13, 2023 at 7:30 PM
    Sunnier
    Sunny
    San Diego, CA
    Wrap it in a Hulk-like green.
    bmf4069, PenderBen, shifty` and 2 others like this.
  4. Feb 13, 2023 at 8:22 PM
    Needs big hulk smash fists wrap for the front fenders and angry green halo projector headlamps
    Sunnier[QUOTED], shifty` and GODZILLA like this.
  5. Feb 13, 2023 at 8:26 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  6. Feb 13, 2023 at 8:33 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  7. Feb 13, 2023 at 8:38 PM
    18" TRD Off Road Wheels
  8. Feb 14, 2023 at 6:02 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I don't know much about wood working or floor supports. Asking here before going to pops.
    In the camper the wiring for the trailer lights, and 12V from batteries comes up through the flood under where the dinette used to be.
    I'd like to move this hole forward so I can hide it until the trim. Any ideas other than just drilling a hole? Is it that simple? Lol
    Found a comb and some loose supports for that open portion of the cabinets thing directly above the trim panel that's removed
  9. Feb 14, 2023 at 6:03 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Also my vise came in.
    That's a 6 inch pocket scale leaned up on it
    NUDRAT[OP], bmf4069, txagg and 3 others like this.
  10. Feb 14, 2023 at 6:15 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    I was about to say, "Damn, they left you a hairbrush AND a bunch of matching fasteners! Win! They really wanted you to screw a lot, and look good doing it!!!"
    In all seriousness though, I'm not a mobile home builder (but one of my former teammates and a friend back home both built them and I could ask if you get nothing here). Still, I'm pretty sure the flooring in most mobile homes is just a sheet of heavy lumber fastened to supports, amirite?
    If so, as long as there's not something support-oriented underneath the place you want to drill, I can't understand why there'd be an issue with doing something nicer, like drilling the void in the linoleum beneath where the brush was. BUT two points to make: 1) You need to make sure that grommet relocates with the wiring, and 2) It'd be wise to use a galvanized nail plate to protect anything or anyone from running a fastener through the wood and into that wire bundle.
    EDIT: Oh, and as if I need to say this, plug up the old hole as good as possible (rodents). And know, those little bastards will chew right through foaming insulation if they know there's something good on the other side.
  11. Feb 14, 2023 at 7:01 AM
    Chris the Ogre
    Chris the Ogre Beer fixer
    Santa Barbara
    2003 4X4 AC Tundra TRD
    We moved into our all electric condo in 2012. The stovetop was killing me. I bought a blackstone griddle with a burner on the side. Started doing most of the cooking outside. Absolutely love it. Take it with us on large group camping trips. Whenever I win the lotto and can afford my forever home. An outdoor kitchen with gas it on the list
    shifty`[QUOTED] likes this.
  12. Feb 14, 2023 at 7:09 AM
    Sunnier
    Sunny
    San Diego, CA
    I used to spend a fair bit of time under mobile homes and trailers (TV cable installation and repair) and often there was a lot of free space, and insulation (or not) between two slabs of board material. Much of the wiring and piping hangs in that space, loosely supported by hanging metal or plastic fasteners. I'd strongly suggest you crawl under and do a visual check, try to figure out what is below that hide-y space-- but probably it will be clear OR attached in such a way that you can move it aside and secure it with zip ties or what not while you drill. The two floor set up may mean you'll have to remove a portion of the bottom "floor" to see all this, and to pretty up your wiring path. What I don't know (@shifty`probably has advice) is how to replace whatever panel you cut out. I used to encounter missing sections all the time, which made my job easier, but probably also more accessible to varmints. And fire.
    Edit: thinking more about this... even the laziest trailer constructoids can't have located that grommet waaaay out in the middle of the floor without some justification <eye roll>, so it's possible there's a sewage exit pipe or some such in the way. We're back to, you'll hafta crawl under and check it out.
    NUDRAT[OP] likes this.
  13. Feb 14, 2023 at 7:33 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'll do some thinking on it. Still have to get this son of a bitch inspected so I can transfer the title. I'm so fucking sick of the God damn phone tag with the rv inspector for the state
    There used to be a built in dinette there when the camper was new. It was removed before I bought it which is why the wiring "appears" to be in the middle of the floor. It didn't used to be.
  14. Feb 14, 2023 at 8:48 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  15. Feb 14, 2023 at 8:57 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Ordered one of these to clean up my new to me wall mount , and finish off my battery storage. https://www.amazon.com/dp/B095C3G4CC
    Trying to sell some more of my M12 shizznit at work. Besides my 3/8 impact I really don't give a shit about my m12 stuff. If any one is curious what else I got, all you gotta do is ask. Night fuckers
  16. Feb 14, 2023 at 9:05 AM
    bfunke
    bfunke Tundra Curmudgeon
    @NUDRAT - I’m guessing the payload suspension lines on the Chicom spy balloon are not compatible with the grabber apparatus. Bad enough we have to use quarter million dollar AIM-9X missile but I’d hate to lose a multimillion dollar MC-130 because the pilots got a facefull of nylon on the windscreen.
    NUDRAT[OP] and Jack McCarthy like this.
  17. Feb 14, 2023 at 10:19 AM
  18. Feb 14, 2023 at 10:54 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Nice!
    But I’ve gotta be honest….my pocket scale is much bigger
    Sunnier likes this.
  19. Feb 14, 2023 at 11:15 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Broke in the new toolbox at work today.
  20. Feb 14, 2023 at 11:32 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    my mobile vise table is going places. Tall wheels in the cubby cause i was working on a slope, but square buckets full of dies and forms and 1/2"drive socket sets and prybars and pickleforks and all the everything fits underneath. Put the arm on and roll it where you need it.
  21. Feb 14, 2023 at 11:40 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Saw this-thought of you
  22. Feb 14, 2023 at 11:47 AM
    10 inches or gtfo
    CodyP[QUOTED] likes this.
  23. Feb 14, 2023 at 11:59 AM
    I like this idea! Didn't want a workbench in my living room (even though I have a 6' rack with chemicals, oils and tools in it)
  24. Feb 14, 2023 at 12:02 PM
    The million dollar logistics of taking down a weather balloon. Didn't know it was an AIM-9X. Wow.
  25. Feb 14, 2023 at 12:16 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    My balloons will be insured, and if i fly em low enough someone will shoot it within 30 days or whatever. Lemme know if you want ad space.
    Jack McCarthy and Sunnier like this.
  26. Feb 14, 2023 at 1:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I looked at those. The entire set up. Think those were somewhere around $150 or so total for everything I'd need
  27. Feb 14, 2023 at 4:51 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Thought we lived in KY where they don't care about inspecting anything with wheels. What all do they look at?
  28. Feb 14, 2023 at 5:17 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It's a fire Marshall inspection. Looking for fire extinguishers, exposed wiring, leaking/exposed plumbing, carbon monoxide detectors, smoke detectors, no busted windows. Etc....
  29. Feb 14, 2023 at 5:17 PM
    Azblue
    The Dirty T ( ^_^)_且
    TWSS
    bmf4069 and FrenchToasty like this.
  30. Feb 14, 2023 at 5:17 PM
    I knew you’d show up sooner or later
    Sunnier and Azblue[QUOTED] like this.
