Blinker won't cancel
Discussion in '2.5 Gen Tundras (2014-2021)' started by thechaderbox23, Feb 13, 2023.
  1. Feb 13, 2023 at 7:47 AM
    thechaderbox23
    thechaderbox23 [OP] New Member
    Chad
    2013 Toyota Tundra
    I have a 2016 and the blinker won't cancel. I've checked the bulbs and they both work. Does anyone know if this is a relay problem or if I have to replace the switch in the steering column?
  2. Feb 13, 2023 at 7:56 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Seem like that would be a switch problem.
    Does it not cancel turning both ways?
  3. Feb 13, 2023 at 7:59 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Check the blinker fluid level.
  4. Feb 13, 2023 at 9:11 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Is it safe to assume the steering wheel is centered while driving straight? Gross misalignment will cause the turn signal cancel to act weird.
    The cancel is achieved mechanically through the turn switch / stalk and is activated by a tab on the bottom of the steering wheel. So either the switch stalk or the tab on the wheel is the cause of it not cancelling. Looking at some pics of Tundra steering wheels, it appears that there are metal tabs that are part of the aluminum hub of the steering wheel. So far more likely that the plastic cancel mechanism of the switch stalk bit the dust.
    You don’t need to pull the steering wheel to replace the stalk. Just the column covers, and the stalk comes out the side.
  5. Feb 13, 2023 at 9:50 AM
    Saltyhero13, landphil and texasrho83 like this.
  6. Feb 13, 2023 at 9:50 AM
    ^^This^^
  7. Feb 13, 2023 at 9:56 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
