Transmission Drain/Fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by pvn.beluga, Feb 12, 2023.
  1. Feb 12, 2023 at 11:07 AM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Been through a bunch of the threads on here about this topic.
    I’m currently doing this and it’s… taking more than 4 quarts (amount that was drained) Is this normal? Or should I just put in what I took out?
  2. Feb 12, 2023 at 11:09 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    If there’s any doubt, slightly overfill and then go through the proper process for adjusting the fluid capacity. There are several recent threads on it
    DZ_ likes this.
  3. Feb 12, 2023 at 11:21 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    The Car Care Nut youtube channel has a good video on this procedure. Worth a watch!
    Pac12AfterDark and WILLINH like this.
  4. Feb 12, 2023 at 11:22 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    When I did mine it was on a lift and level got out 4 1/4 qts. Bring fluid up to temp and to check it.
    There is a video from the car care nut it is Very helpful.
  5. Feb 12, 2023 at 11:45 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Do the check procedure, its not difficult and then you will know it is correct.
    Tigereye and WILLINH like this.
