Hello, Inherited 2008 Tundra with 2,445 miles
Discussion in 'New Member Introductions' started by mtucker, Feb 12, 2023.
  1. Feb 12, 2023 at 9:08 AM
    mtucker
    mtucker [OP] New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    I inherited this 2008 Tundra from my Dad. It was only driven a few times a year which is why it has 2,445 miles on it. I am currently driving a 2003 Tacoma with 240K miles that I have had for 13 years. I am looking forward to more room and a V8. I have to repair two wires that go to the power steering sensor that were chewed by critters. OBDII shows everything else OK (including emissions readiness). That will get it ready to go through the smogging/registration process.
    I have a long list of things I want to do. First up will be some attention to the paint (clay bar, compound, wax). I don't think it was ever waxed. Then replace the original tires (lots of sidewall cracks). New wheels at the same time.
    Then Android head unit, sub and amplifiers, different grille, Bilstein 5100 up front to level.....
    As she sits now
    Odometer
    When she was new at the dealer
  2. Feb 12, 2023 at 9:10 AM
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
    Thats some damm LOW miles .Great for you
  3. Feb 12, 2023 at 9:11 AM
    Retired...finally
    Hats off to you and your Dad. Nice truck.
    Tripleconpanna, Mater and Taco-Spike like this.
  4. Feb 12, 2023 at 9:11 AM
    Welcome from NY.
    Taco-Spike likes this.
  5. Feb 12, 2023 at 9:15 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    If it’s been sitting for awhile, before you do the other mods you need to change the oil, diffs, transfer case, transmission, coolant, check radiator hoses, check the belt- it may not be high enough mileage to change those fluids, but they only last X amount of years, and the rubber just breaks down with age (just like tires being dry rot)
  6. Feb 12, 2023 at 9:17 AM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    Wow that’s a gem!
  7. Feb 12, 2023 at 9:56 AM
    mtucker
    Escondido CA.
    2008 Double Cab
    Yes, oil for sure. It was last changed about 1000 miles ago, but that was in 2011 :) Will also do a drain and fill on the transmission fluid.... I do that every year on my Tacoma. Coolant looked good, but it wouldn't hurt to change it. I might change the spark plug wires and spark plugs too after I drive it a bit so I can see how the spark plugs look (healthy running engine or not). The belts look good too, but after I drive it for a few weeks I'll recheck and see if they are cracking. Thanks for the suggestions.
  8. Feb 12, 2023 at 10:31 AM
    Sergicalmaneuver
    Sergicalmaneuver New Member
    So Cal
    2019 Platinum Crewmax
    Wow. Some low miles.
  9. Feb 12, 2023 at 10:37 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Keeping an eye on/ prioritizing belts makes sense, spark plugs though are probably the least likely thing to degrade without use. I might be inclined to pull them to make sure they haven't corroded into their ports and to make future removal easier but if they look good on the thread and the bits that are on the outside of the engine then they should be fine - otherwise they need plenty of heat to degrade which is the one thing they haven't been getting.
    The usual consumable parts to replace will not apply to something that has had almost no use but is older. Sure, fluids out but it's anything rubber based that is going to play up, if it does. Belts and tires are reasonably easy to eyeball, seals and 'o' rings are the things that would concern me and some of them are a right beggar to get to.
    IsaiahCanada and dondino like this.
  10. Feb 12, 2023 at 10:47 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    X2
    joseph_womack[QUOTED] likes this.
  11. Feb 12, 2023 at 11:01 AM
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    Probably a good idea to do a brake fluid flush too. Hard to know if water has absorbed into the system since the brakes have been applied so few times, but it will avoid any worry about corrosion in the caliper cylinders. And congratulations on being the beneficiary of this gift - what a great deal.
    Also, if this is one of the 'interference' engines, a timing belt replacement is probably due based on the original's age.
  12. Feb 12, 2023 at 11:06 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Wow! Great color.
    I echo what the others have said above. Mine has 130k and is rolling strong.
    Tundrastruck91 and ATV25 like this.
  13. Feb 12, 2023 at 11:07 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Congrats and welcome from the Rust Belt....Pennsylvania. Some good old fashioned maintenance on her and you'll probably be good to go.
  14. Feb 12, 2023 at 1:56 PM
    TheBrit
    Mark
    I think both the 4.6L and 5.7L 2nd gen both have chains and that looks to me like a 5.7L.
    IsaiahCanada and joseph_womack like this.
  15. Feb 12, 2023 at 2:07 PM
    NWPirate
    Zach
    WA
    12 year old oil!? :eek2: Makes my eye twitch
    Congrats on the new truck
  16. Feb 12, 2023 at 2:21 PM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    So I'm curious, what did he actually do with it? haha
  17. Feb 12, 2023 at 3:19 PM
    mtucker
    Escondido CA.
    2008 Double Cab
    Good call on flushing the brake fluid. We are low humidity here, but it did sit outside. It has a 5.7L so no timing belt. Hooray!
    He drove it more when it was new, but for the last 10 years he mostly used it to take some 100# propane tanks to get filled two or three times a year.
    Thanks everyone for the input. I will be looking for leaks (valve covers and other places where gaskets or seals are). I don't mind putting some money into it. I will keep my Tacoma for a few months before I think about selling to make sure all goes well with the Tundra.
    Jack87 and JLS in WA like this.
  18. Feb 12, 2023 at 3:41 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Please see signature!
    Beautiful truck, but this is one of many reasons I hate California. Here in Pennsylvania, driving less than 5,000 miles a year exempts you from emissions testing!
    IsaiahCanada and FrenchToasty like this.
  19. Feb 12, 2023 at 4:32 PM
    2mchfun
    Very cool! Since mice have been eating on it, I would check out the fresh air intake for the HVAC system and make sure don't have any droppings in the system that could make you sick.
    kajones02, mtucker[OP] and JLS in WA like this.
  20. Feb 12, 2023 at 5:26 PM
    GatorBodine
    GatorBodine New Member
    You're gonna have to polish (buff) that white paint to get any shine back. It is single stage white, a clay bar and wax is not gonna cut it. You gotta remove the oxidation. As you buff, you'll see white chalkiness paint transferring onto the polishing pad.
    Edit...I re-read your post, you did mention compound. You got your work cut out for you. Congrats on the truck :thumbsup:
    mtucker[OP] likes this.
  21. Feb 12, 2023 at 6:00 PM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Hell yea!
  22. Feb 12, 2023 at 6:32 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    You are also going to need new tires. Those current tires are now 15 years old and while they look new, they are a hazard.
    Congrats on the truck!
    Sorry i saw that you mentioned tires already. When you do get tires, get some good ones!
    Jack87 likes this.
  23. Feb 12, 2023 at 6:49 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC. Sorry for your loss and prayers to you and your family!
    Mr Badwrench likes this.
  24. Feb 12, 2023 at 7:53 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Wow, that is amazing. Sorry for your loss though.
  25. Apr 17, 2023 at 10:35 PM
    mtucker
    Escondido CA.
    2008 Double Cab
    I have been busy working on her the last two months and she is up to 3,222 miles!. I have a build thread, but I wanted to give an update to the people that were welcoming and made suggestions in my introduction thread two months ago.
  26. Apr 18, 2023 at 2:50 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Holy jezzy…. What a transformation..!!! That’s one nice looking rig ! I commend you for your vision and outcome. And your father also for keeping it despite the minimal use. Looks perfect now, I wouldn’t change a thing…
  27. Apr 18, 2023 at 5:04 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Nice, keep it clean. It looks better than newer Tundras out there.
  28. Apr 18, 2023 at 10:51 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Wow, welcome
  29. Apr 19, 2023 at 4:57 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Nice looking truck! Congrats and welcome from Pennsylvania.
  30. Apr 19, 2023 at 5:14 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Deadly! :muscleflexing: Fastest colour too !
