Any Subaru Outback experience
Discussion in 'General Automotive' started by PermaFrostTRD, Feb 6, 2023.
  1. Feb 6, 2023 at 12:13 PM
    PermaFrostTRD
    PermaFrostTRD [OP] Tumescent Member
    Northern NY
    Obviously not a Toyota thread, but just curious if anyone had any experience (good or bad) with Subaru outbacks. Done some research and seems to be a pretty good vehicle with only a 2013 model year to avoid. Sweet spot seems to be 2005-2009 (for older used ones). And anything with 100k or more you're probably looking at head gasket repairs in the future (if it hasn't been fixed/replaced already). AWD/4WD is a big plus (a requirement for me really) with these. Auto tranny. Plan is to test drive a few and since I have no idea about any kind of mechanic stuff, I'm just looking to make sure there's no coolant (foam) in the oil cap (for the head gasket thing), check the belts, tires and visually inspect for rust and gonna see how it sounds with a hard acceleration and hard stop.
    Looking to get one for my daughter. Our initial plan was to give her my wife's 4R, but my wife isn't ready to get rid of the 4R yet, and she's not sure what she wants, etc. etc..
    Obviously with it being my daughter, I'm looking at reliability/safety which Subaru checks the boxes and dont really care for the little Toyota SUVs (and neither does she - she's into the Subie's.)
  2. Feb 6, 2023 at 12:37 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    I had a 2017 Outback 2.5 limited, bought it new and drove it for 2 years, during those time I racked up almost 100k.
    - The AWD was awesome, in winter time was amazing, I had Yoko G015 tires on the car and did +1 for size, it can surprise you where it can go.
    - The CVT was not so good, mine broke the 2nd week I got the car, the belt began slipping in the transmission, they just replaced it under warranty, I believe there's a class action lawsuit for longer warranty now, so keep an eye out https://www.thedrive.com/car-warranty/35585/subaru-cvt-problems
    - MPG, it was not as good as I thought, I get mid 20s in summer, and winter it's horrific, I've gotten as bad as 16mpg.
    - Seats are terrible, it's torture to drive it long distance
    They are decent cars, but depends on price.
    PermaFrostTRD[OP] and WILLINH like this.
  3. Feb 11, 2023 at 5:05 PM
    PermaFrostTRD
    Northern NY
    Here it is after a 3 hour trek through the mountains to bring it home and a hose down to get rid of the salt and mud.
    2009 Outback limited. Great shape. Handled the mountain climbs like a champ.
    Henry1jg, NUDRAT, bulldog93 and 3 others like this.
  4. Feb 11, 2023 at 7:40 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Nice pickup, I got an 05 Outback XT as my daily driver.
  5. Feb 11, 2023 at 7:52 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I have an 06 OBXT manual trans with an Ej257, D25heads and a vf52. It’s a hoot.
  6. Feb 11, 2023 at 8:39 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    Nice, mine is just stock grocery getter and family wagon.
    PermaFrostTRD[OP] likes this.
  7. Feb 11, 2023 at 8:40 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Still a bunch of fun!
    That said, did you remove the banjo filters so you don’t munch the vf40?
  8. Feb 11, 2023 at 10:44 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Timing belt, head gasket. Make sure the idler pulley was replaced with the TB. Bought an 02 Forester that had a cheap idler pulley seize up and break the TB.
    One of my daughters had an 09 Outback. It had a head gasket leak and would drip oil. Had to stay on top of it, but other than that it was a good car.
  9. Feb 12, 2023 at 12:57 AM
    PermaFrostTRD
    Northern NY
    Thanks! This one has had the hg replaced. Belts are in good shape, but have a little age to them.
  10. Feb 12, 2023 at 7:41 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Yeah if there’s no oil under a Subaru there’s no oil in it.
    For the 2005-2009 models, check the lower control arm bushings they are only good for 50-60k and will silently eat your tires. Look for the leaking PS pump (they are pretty much always leaking), it’s located on the top left at the front of the engine. Check the front axle seals (always leaking) and just expect to do the valve cover gaskets (always leaking).
    If you smell burning oil while driving it’s 9/10 times the valve cover gasket leaking onto the header.
    The turbo models aren’t tolerant to extended oil change service intervals.
  11. Feb 12, 2023 at 7:45 AM
    biebs96
    PA
    We have a 2015 forester, not an outback obviously, but it has been turn key and reliable since we got it in 2016.
    Subaru is my second brand to consider after Toyota.
    Henry1jg and PermaFrostTRD[OP] like this.
  12. Feb 12, 2023 at 8:04 AM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Not necessarily an outback, but I considered a Subaru Crosstrek (New) when I was looking for a commuter car at the end of last summer. I just didn't like it overall, the seats were REALLY uncomfortable and I found that unless you upgraded to the leather which must have been totally different as far as padding etc. I didn't like it's handling, and the interior and tech seemed very dated. I read mixed reviews about reliability, and my friend has a Forester that has just under 100K that she bought new, and it needs like 4K in repairs already. Then there are the known oil consumption issues, as well as blown head gaskets. If it were my decision I would steer clear! Overall, it's up to you and your daughter's comfort level, and although Subies kick ass in the snow, I find their reliability questionable.
    I ended up going with a new Honda CRV, there are some CRV years to avoid because they had some oil dilution issues etc, but overall it t think Honda is a more reliable vehicle. The CRV was MUCH more comfortable to drive and the seats were way better, and the interior was much nicer and more modern and mine does great in the snow (although, obviously if its like more than 6 plus inches of snow on the roads, which is rare, I do take the Tundra, although the CRV would probably still do fine). Have you considered a new Honda HRV (that was my first choice, but they had just come out so getting one was not easy, so I went with the CRV), the redesign is awesome, very comfortable and easy to drive vehicle with automatic AWD, just like my CRV, which does fine in the snow. I am like you, in that I really don't like Toyota RAV4 or the Corolla Cross, they are lower quality inside in my opinion and just not nearly as nice as the CRV overall. I would seriously give the new HRV a try, depending on your spending amount, or a Honda CRV.
    Good luck with your decision and let us know what you decide on! (just realized I wrote this for nothing, since you already purchased) Good luck, hope your daughter enjoys it!
  13. Feb 12, 2023 at 8:27 AM
    JLS in WA
    We have a 2012 CRV (115k) and absolutely love it. My oldest daughter has a 2018 HRV and loves it as well. Youngest has an 08 Rav4 (199k) and it’s been an excellent car so far.
  14. Feb 12, 2023 at 8:28 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    The wife's 21' Crosstrek Sport has been a solid performer for the 1.5 yrs of ownership. Regular 550mi one way trips to AZ w/o issue.
    The 2.5l gets 30+mpg and the paddle shifters make the CVT trans less meh.
    We got the extended warranty 100k miles/ 7yrs.
    She's happy with it.
    btw: The AWD is impressive on icy/ snowy roads.
  15. Feb 12, 2023 at 8:38 AM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    2012. Been great. For Subies research the CVT trans (mentioned above in thread) as they have known to have issues. We have had no issues but daughters 2016 forester had CVT issues.
  16. Feb 13, 2023 at 8:14 AM
    PermaFrostTRD
    Northern NY
    Ours is a 2009 so I dont think there's a CVT (just from what i've researched).
    Thanks for all of this info - I will look into these items. Thing drove like a top through some tough terrain. That's kind of the test, imo, but I will look at these issues (have a mechanic look). Thank you.
    ZappBrannigan[QUOTED] likes this.
  17. Feb 13, 2023 at 5:32 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    Banjos have been removed, are you using a cobb accessport on your outback?
  18. Feb 13, 2023 at 5:42 PM
    Odin43
    Odin43 YNWA
    Rich
    NJ
    2021 MGM Platinum, 2015 Lexus LX 570
    We had a 2010 Outback and a 2012 WRX. Great cars both of them. Long gone now.
  19. Feb 13, 2023 at 5:43 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Nah, a friend of mine tuned it for me.
  20. Feb 13, 2023 at 5:52 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Be sure to bring your spreadsheets to the dealer.
    chugs and PermaFrostTRD[OP] like this.
  21. Feb 14, 2023 at 3:19 AM
    PermaFrostTRD
    Northern NY
    It was exactly as depicted in the photos, description, and walk around/through videos he texted me. After we test drove it, I handed him a bankers check for the amount he asked, a couple of hundos for temp plates and the title/registration, and 10 min later we drove it home. "Spreadsheets" would've been fuming mad. :bananadance:
