  1. Feb 12, 2023 at 7:13 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    We have a new build DQ in town with a drive thru & pull in spots.
  2. Feb 12, 2023 at 7:15 AM
    Mine hasn’t changed since it was built in the 80s. Sorta like the Burger King that still has that 70s retro look but they had to cut a hole in the side window glass to make a drive though. Really weird if you see it.
    NUDRAT[QUOTED][OP] likes this.
  3. Feb 12, 2023 at 7:22 AM
    daveeasa
    Pantry. A cart style island with wheels may happen but there will also be a table behind the stools. And if we are using our crappy stools from San Diego, we only have 2. Counter is for weekday breakfasts mostly, we only have 2 monsters, the designer just drew 4 stools for a size guide I think. We also don’t have random cake in the corner :)
    A photo from a week ago before the tile and additional drywall demo.
  4. Feb 12, 2023 at 7:28 AM
    daveeasa
    We have a rather large crawlspace. More like a walk space. So plumbing isn’t as hard as it would be for a slab where you’d come in from above on supply and have to trench for drain. If I push anything other than the washer dryer hookup right now I’m sure to get a negative response. The formal answer is no to any fourth bathroom plan.
    we also could use some extra closet space and we have this strange wet bar in the center of the structure so lots more can be done to shuffle.
    Honestly, the ideal setup for me would be a shop off the side (garage and kitchen share the wall where the gas range is) with a tiny half bath. Even if it were only one car wide, though 2 would be sick. I’m holding onto that as a dream for now.
    txagg and NUDRAT[QUOTED][OP] like this.
  5. Feb 12, 2023 at 7:30 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Shouldn't be terribly hard to do a digital gauge. Just tee off of the factory sensor, hardest part would be figuring out what the factory thread is.
  6. Feb 12, 2023 at 8:20 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    If that's true, it's not a fail for the kids, it's a fail for the adults who failed to teach them how to safely use the thing.
    We have a big problem, in that the older generations don't want to own up to the fact they did a shit job of bringing up their kids, and are now suffering with the 'ineptitude wrinkle' they themselves helped create. Someone taught a generation they could get seriously hurt because they were never taught how to handle something.
    Sadly, for some of that older generation, instead of owning up and trying to correct it, the typical go-to (it seems) is to be snarky about how the lame/weak/dumb/fragile younger generations are and collectively laugh ... as the failure sits square on their own shoulders, not the younger generations or their parents.
    We can all do better. I started by teaching my kids to safely use knives and hatchets. If I hadn't, my father damn sure would've. It all starts somewhere, or we end up where we are today.
    I mean, to be fair, it wasn't always this way. I've had 20 years to get it where it is today, you can see what the kitchen was and what it is now, and you save at least 25-50% doing the brunt of the work yourself. And it wasn't entirely my hands, Dad is always here to throw in an extra pair so I'm not going it alone.
    It's always the same pattern though - We sock away money, then every couple years, we pull the trigger on something else, and it snowballs. Helps to have a partner that pulls in more money than I do. She makes the extra money, I have the extra skills. Oh, and her mom is an interior designer, which saves $$$ to get quality outcome.
    Believe me, if I hadn't married who I did, which was totally "marrying up(ward)", I probably wouldn't still be in this house. Who the hell knows where I'd be.
    Sunnier and NUDRAT[QUOTED][OP] like this.
  7. Feb 12, 2023 at 8:28 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    So, shift cables in our trucks (or any Toyota with a column shifter) they’re important.. our parts truck at work did what mine did. Sitting in park, it popped into reverse. So, if your shifter feels weird… keep that in mind
  8. Feb 12, 2023 at 8:30 AM
    empty_lord
    05 rollover special
  9. Feb 12, 2023 at 8:40 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'm wondering if this is what happened to my truck too. I was parked on an obstacle to get the truck max flexed, and suddenly the truck rolled back down when my passenger got out. Parking prawl still works and everything, was very odd and hasn't happened since.
  10. Feb 12, 2023 at 8:45 AM
    You need to get vanity tag "ROUGH" for the MR2. Then you've got Rough & Tumble.
    NUDRAT[OP] and CodyP like this.
  11. Feb 12, 2023 at 8:46 AM
    empty_lord
    05 rollover special
    Well since it has a 2GR i was thinking 2GR-8
    bmf4069, txagg, CodyP and 1 other person like this.
  12. Feb 12, 2023 at 8:47 AM
    empty_lord
    05 rollover special
    After replacing my cable, I never noticed how fucked it really was lol, I’m going to buy a spare since I think I’ll have this truck for a LONG time
  13. Feb 12, 2023 at 9:04 AM
    How hard are they to replace?
    FirstGenVol and des2mtn like this.
  14. Feb 12, 2023 at 9:05 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    what happened on dyno day?
    RUSTYNUTS likes this.
  15. Feb 12, 2023 at 9:09 AM
    Triple D
    Dan’s Dyno Day
    bmf4069 likes this.
  16. Feb 12, 2023 at 9:09 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Mr2gr8
  17. Feb 12, 2023 at 9:15 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    since your old and new memory sticks are a different speed the newer faster stuff would slow down to meet the old RAM. I don’t think any thing you have Installed would utilize more than 32GB but I may be wrong. You probably wouldn’t notice a difference if you threw the old stuff back in I bet. Also unless your MB is a quad-channel then it really won’t make a difference and possibly run slower.
    I would just leave er be….throw it in a dumpster and get a Mac
    I hate working on windows.
    bmf4069[QUOTED] and txagg like this.
  18. Feb 12, 2023 at 9:23 AM
    empty_lord
    05 rollover special
    Not terrible. 2 brackets and a nut. Inside is a clip and grommet
  19. Feb 12, 2023 at 9:30 AM
    NUDRAT
    SW CT
    TUMBLE. :rofl:
    shifty` and Sunnier like this.
  20. Feb 12, 2023 at 9:45 AM
    Sunnier
    Sunny
    San Diego, CA
    Do have the part number handy, as I guess we’re all considering this now-?
    Hmmn, but is it the same for all three cab styles, all 1st gen years….
  21. Feb 12, 2023 at 9:46 AM
    empty_lord
    05 rollover special
    Access and reg cab should be the same, but 05-06 likely are different. Double cabs? I don’t know
  22. Feb 12, 2023 at 9:46 AM
    I looked it up briefly but it’s a 150-180$ part in case you were curious
    Sunnier[QUOTED] likes this.
  23. Feb 12, 2023 at 9:49 AM
  24. Feb 12, 2023 at 9:51 AM
    NUDRAT
    SW CT
    My generation & their kids are who i poke fun at. I was lucky to have older parents than most of my peers. You'd think I was raised in the 1930's.
    but yeah, I had a buddies wife struggle with my spinning their kid around. You know when you hold the kids wrists & the kid holds your wrists & you spin around in circles & the kid ends up flying through the air? She was sure I was gonna break the kid. Never dropped him, never broke him, his wrists still work fine as an adult. Up to her his training wheels never would have come off. I tried where i could, but if you don't own them - only so much you can do.
    I will say, with all the social media, I think there's something hugely different that we are just beginning to see the effects of. There seems to be a certain hopelessness of young adults, like they are being fed a tidal wave of success that they feel they have no possibility of measuring up to.
    I have had a couple 20somethings report to me & for the most part feel they've moved on better equipped to be independent adults.
    I don't know, no easy answers. I just remind myself "it takes a village" & try to do my part.
    shifty`[QUOTED] and txagg like this.
  25. Feb 12, 2023 at 9:57 AM
    Spinning my kids is my favorite!!!!
    NUDRAT[QUOTED][OP] and shifty` like this.
  26. Feb 12, 2023 at 10:12 AM
    daveeasa
    I’d really like to know more about how to diagnose this one as far as urgency goes. Mine feels fine but I’m nervous idling in park now and with how little I drive it, I need to give the engine time to turn over. Definitely not idling in the driveway anymore. I should get more wheel chocks.
  27. Feb 12, 2023 at 10:35 AM
    empty_lord
    05 rollover special
    If the column doesn’t make a positive click into park, reverse, neutral and drive, somethings up
    txagg, Sunnier and FrenchToasty like this.
  28. Feb 12, 2023 at 10:43 AM
  29. Feb 12, 2023 at 10:48 AM
    bfunke
    bfunke Tundra Curmudgeon
    The parking pawl engages notches on the tranny’s output shaft to hold the vehicle. If the vehicle is on an incline there can be considerable force on the pawl making it difficult to move out of park. I’ve not seen them fail unless severely abused. The pawl should be able to hold your truck on most any incline
  30. Feb 12, 2023 at 10:59 AM
    daveeasa
    My truck creeps back a bit after park w parking brake on. Maybe parking brake needs adjustment? My driveway is steep. Going to change up the parking blocks to wider ones for my big tires but for now I’m parking the AT on the flatter grass.
    shifty` likes this.
