Overhead console removal….looking for a little help
Discussion in '1st Gen Tundras (2000-2006)' started by mike's limited, Feb 11, 2023.
  1. Feb 11, 2023 at 4:14 PM
    mike's limited
    mike's limited [OP] New Member
    05' Limited DC 4x4
    Stock
    I have an 05’ Limited DC. I have the overhead console w/compass temperature, homelink, sunglasses storage, etc. I was trying to remove it. I removed the 2 screws inside the sunglasses storage area. As far as I have read, that is all it takes to remove the unit but I pulled twisted and everything else with no luck. I don’t wanna pull too hard and break something. Am I missing something? More fasteners somewhere? Help appreciated!
  2. Feb 11, 2023 at 5:54 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As you can see in below pic, there are 2 small clips that help hold it up and what I'll call a quide clip that is at the windshield end., but they should release relatively easily. After I remove the 2 screws, I just pull down on the rear of the console and it should just come right off.
  3. Feb 11, 2023 at 6:39 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Edit: nevermind, this is for the access cab and I just noticed yours is a DC.
    Leaving this here in case an AC guy ends up needing it.
    If the little plastic clip breaks, here's the part # for a replacement:
    trueblue1981 and shifty` like this.
