  1. Feb 11, 2023 at 2:19 PM
    Casper421
    In the woods
    06 DC
    Yeah, what @shifty` said.
    shifty`[QUOTED] likes this.
  2. Feb 11, 2023 at 3:00 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Changed the oil in both the truck and the beater
    bmf4069, 805Tundra, txagg and 2 others like this.
  3. Feb 11, 2023 at 4:09 PM
  4. Feb 11, 2023 at 4:23 PM
    I might be able to disassemble and reassemble a x20 like Forrest Gump now!!!
    @shifty` i happened to find 4 tubes of super lube looking for a 4mm Allen!
    call me crazy but I wanted less of a wire mess with my winch, so I turned the winch 180 to have the motor terminals closer to my battery and solenoid box, I wanted the terminals facing towards the radiator but the casing had a dowel pin and only two positions to seat into, so this is where I’m at now. I also realize forward will be reverse when I click the controller, I think I can just swap two leads if I can’t remember that little detail….. 6492D2CF-1B16-4662-B407-94A9151AF927.jpg6DC764B7-85FA-4D4C-9AE1-6921117990BC.jpg
    bmf4069, des2mtn, 805Tundra and 4 others like this.
  5. Feb 11, 2023 at 5:33 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Feels so good to cruise at night in the V6 again. :)
    bmf4069, NUDRAT, abcinv and 3 others like this.
  6. Feb 11, 2023 at 5:51 PM
    I was like "QT night? wtf is that?"
    Then I realized A and Q are next to each other on the 'ol keyboard, and ... ah. Cruising AT night.
  7. Feb 11, 2023 at 5:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes... "AT"
  8. Feb 11, 2023 at 5:57 PM
    I wasn’t going to question it. Thnx.
  9. Feb 11, 2023 at 6:07 PM
    Yes, indeed, it does feel good to cruise Automatic Transmission at night... :rofl:
    (just giving you shit, bro)
    (It also feels good to ride QTs at night, too)
  10. Feb 11, 2023 at 6:08 PM
    oscardog86
    oscardog86 New Member
    Southern California
    So I ended up buying the Addco rear sway bar. Got that installed and removed the front sway bar. Went camping for a few days afterwards and gotta say it felt really good on the windy highway out to the desert. The rear end felt planted unlike before especially with all the weight back there. The front sway bar being gone didnt feel bad at all and dare I say it felt more stable with my rear sway bar only setup now.
    But removing the front sway bar or adding 33s or combination of the two definitely had me rub my fender a couple times coming down a little drop off with decent speed when i was offroading. So I got bored back at camp and removed my bolt on factory fender flares. Wasnt sure how Id like it but i much prefer the clean look of them removed!
    IMG_20230205_145105711_HDR.jpg IMG_20230205_145128399_HDR.jpg IMG_20230209_162441833_HDR.jpg IMG_20230210_155932342_HDR.jpg
  11. Feb 11, 2023 at 6:08 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You for sure can just swap the wires at the solenoid.
  12. Feb 11, 2023 at 6:09 PM
    Pretty sure it’s C and D but I will verify
  13. Feb 11, 2023 at 6:10 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    It's been a while since I've messed with a winch but it's for sure not the big chonky boy wires :rofl:
  14. Feb 11, 2023 at 6:13 PM
    oscardog86
    Southern California
    IMG_20230208_104401115_HDR.jpgIMG_20230208_132737738_HDR.jpgIMG_20230208_104344525_HDR.jpgIMG_20230209_142347939_HDR.jpgIMG_20230209_123944160_HDR.jpgIMG_20230209_094340728_HDR.jpg
    Oh yea and heres some pictures of the camping trip. Went to Anza Borrego state park. Camped with the 15 year old pup for 3 nights.
    Voss, bmf4069, Mustanley and 9 others like this.
  15. Feb 11, 2023 at 6:45 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Decided to build a platform in the bed with some wood lying around the garage. Primarily to put boards under so they can stay protected and cool in the summer. Very simple design, not the strongest but it can hold probably around 200-250lbs before breaking/falling apart.
    C37A1736-1F03-4A5B-ADDE-4D7DF1EA5441.jpg 95BA4DF9-91CD-4B2D-AF73-642A189BF474.jpg F368B10A-BA20-4C24-B53D-F6182B7C9DCE.jpg
    Voss, bmf4069, RUSTYNUTS and 6 others like this.
  16. Feb 11, 2023 at 7:28 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Timing belt/water pump job almost done. Next is all fluids, filter, and lube. Does this throttle body housing look a little crummy to you? Only pic I have for now.
    Voss, bmf4069, NUDRAT and 2 others like this.
  17. Feb 11, 2023 at 7:34 PM
    Casper421
    In the woods
    06 DC
    Yes, some TB/carb cleaner and a toothbrush will make quick work.
    bmf4069, NUDRAT, 805Tundra and 3 others like this.
  18. Feb 11, 2023 at 8:09 PM
    Definitely this. You can see cake where the butterfly rests.
  19. Feb 11, 2023 at 8:56 PM
    Erik1989
    Erik1989 New Member
    Erik
    2003 White Tundra
    New rotors, pads, and plugs today. Put in 5100's in the rear a few days ago. Thinking sumosprings soon to help with the sway. Got to finally test the 4wd in Tahoe last weekend. She crusssshed it
    Voss, bmf4069, oscardog86 and 5 others like this.
  20. Feb 11, 2023 at 8:58 PM
    Sweet camper thing!!!
    Tundra2 and Erik1989[QUOTED] like this.
  21. Feb 11, 2023 at 9:01 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Took the words out of my brain! Did @Erik1989 build that himself? It looks really good+
  22. Feb 11, 2023 at 9:04 PM
    I’d like one!
  23. Feb 11, 2023 at 9:04 PM
    Erik1989
    Erik1989 New Member
    Erik
    2003 White Tundra
  24. Feb 11, 2023 at 9:05 PM
  25. Feb 11, 2023 at 9:28 PM
    Casper421
    In the woods
    06 DC
    Finally had some time to throw out the Xmas tree and some limbs that fell last storm. Can’t wait till I can have a burn pile!!
    Voss, bmf4069, oscardog86 and 4 others like this.
  26. Feb 11, 2023 at 9:30 PM
    I don’t know about @Mr.bee but that looks good enough burn pile to me!
    Casper421[QUOTED] likes this.
  27. Feb 11, 2023 at 9:33 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    skip the vvti and get some kelford cams. Grind it out for thick bearings.
    KingSequioa007 likes this.
  28. Feb 11, 2023 at 9:35 PM
    Casper421
    In the woods
    06 DC
    If I could only have one here. The hoa would have the FD here in 30 seconds! Planning to buy some real property this spring/fall and can burn all I want. :bananadead::rasta:
    lsaami, bmf4069, oscardog86 and 2 others like this.
  29. Feb 11, 2023 at 9:36 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    green wood gets loud.
    oh, and i learned how to make gifs, so thats a thing.
    RUSTYNUTS, NUDRAT and FrenchToasty like this.
  30. Feb 11, 2023 at 9:44 PM
    I wouldn’t have guessed you were in a HOA there. Is all of Cali a HOA? Hahah
    We have some here, mainly in the newer track homes, and trailerhoods. We don’t usually get a tree because of climate beliefs(I’m full of shit hahha) but my neighbors do! And I snagged a smaller/ish one and burnt it in the bum barrel, I thought my next door neighbor had to of seen it, but he didn’t. The next time he saw me he’s like you should have taken ours!!!
