Power steering flush. ATF
Discussion in '2.5 Gen Tundras (2014-2021)' started by Brownsfanhere, Feb 10, 2023.
  1. Feb 10, 2023 at 10:29 AM
    Brownsfanhere
    Brownsfanhere [OP] New Member
    2015 Crew Max
    Manual says use atf. Went ahead and did it that way but after seeing Car Care Nut video he discouraged it because of possible issues with seals long term. Should I change it again to power steering fluid? Noticed when it’s very cold it feels different. Otherwise feels fine .
  2. Feb 10, 2023 at 10:36 AM
    Rocko9999
    Rocko9999 New Member
    I have had good luck with Maxlife ATF for power steering. I don't see it causing issues.
  3. Feb 10, 2023 at 12:29 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I used exactly what my owners manual said, the color at least matched lol.
  4. Feb 10, 2023 at 12:46 PM
    Rocko9999
    Which is why Maxlife ATF works great-it's Dex II, III and more, compatible.
    RustyShackle323 and FrenchToasty like this.
  5. Feb 10, 2023 at 12:50 PM
    matictundra
    Franco
    AZ
    I used STP Dex III.
  6. Feb 10, 2023 at 1:18 PM
    737fixer
    737fixer New Member
    Or just stick with the Toyota recommended fluid. P/N 00718-ATF0020210807_102222_4760655d96d967ce720c8cfb0ec2ee2c14c019a4 (2).jpg
    This is the new bottle. The old bottle just says automatic transmission fluid. Both are same P/N.
  7. Feb 10, 2023 at 1:28 PM
    matictundra
    Franco
    AZ
    I'm not that rich, lol. Especially Toyota tells you exactly what spec they use.
    Rocko9999 likes this.
  8. Feb 10, 2023 at 1:51 PM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    I use Amsoil signature series ATF. No matter how cold it is I've never heard a groan from any of my vehicles over many years. I vacuum out the reservoir at least every second oil change (simpler to do than the cabin air filter and cheap).
    I'll have problems but power steering isn't going to be one.
  9. Feb 10, 2023 at 2:34 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    It's not that expensive. Check different Toyota dealers across the country that have free shipping too.
    Joe333x and Brownsfanhere[OP] like this.
  10. Feb 10, 2023 at 4:40 PM
    Brownsfanhere
    2015 Crew Max
    Thanks for all the responses. Went with Toyota atf. Guess I’m good for awhile
  11. Feb 10, 2023 at 9:33 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    If the color matched, then someone must have done it before you, the stuff that comes stock is clear and not red.
    Rocko9999 and AZBoatHauler like this.
  12. Feb 13, 2023 at 7:43 AM
    matictundra
    Franco
    AZ
    Nope bought the truck new. It was red when I checked every time I changed oil. I do my own maintenance and work. I have trust issues, lol. At the end of the day I used Dex III ( red color) like the owners manual says.
    Joe333x[QUOTED], coldcanuk and Piki like this.
  13. Feb 13, 2023 at 9:43 AM
    Joe333x
    Joe333x Member
    Boston
    Wow, every other report I've seen from people here is that thier fluid was clear. Mine definitely was clear since new, which was why I went down a rabbit hole trying to figure out the correct fluid, ended up going with the Toyota Dex II+III fluid 00718-ATF00.
  14. Feb 13, 2023 at 9:55 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Mine was clear when I changed it. Owners manual calls for DexIII, red it is…
    AZBoatHauler likes this.
  15. Mar 12, 2023 at 11:05 AM
    Chip_Tundra
    Chip_Tundra New Member
    Thanks for this thread.
    Just got finished with my first power steering flush. I used castrol synthetic multivehicle. Looked up the spec sheet and it complies with current Toyota standards. Used about 1.3 qts to flush.
    A fluid evacuator hooked up to the return line made quick and clean work out of it.
