Transmission drain and full amount
Discussion in '2.5 Gen Tundras (2014-2021)' started by 11bravoz71, Jan 26, 2023.
  1. Feb 2, 2023 at 4:51 PM
    #61
    packfan
    packfan New Member
    2021 Tundra Crewmax 4x4 1794
    Simple, because as long as there is no leak. Measuring exactly the amount you remove and adding back the same amount is foolproof.
    vtl and AZBoatHauler like this.
  2. Feb 2, 2023 at 5:34 PM
    #62
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Nah, it takes to long to do it the right way! There is always a shortcut....
  3. Feb 2, 2023 at 5:45 PM
    #63
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Love All Girls Garage!
    Wallygator likes this.
  4. Feb 3, 2023 at 5:17 AM
    #64
    evanhauer
    evanhauer Snow Chaser
    Erik
    VT
    ‘16 Tundra CM SR5 TRD OR 4x4
    Was just in The Stealership yesterday for 40k interval plus diff and xfer fluid changes (side note: $450 for parts + $200 for labor on that one :bananadead:) and I got the “never do your transmission fluid” talk.
    The guy was saying they never recommend changing with the “world standard” fluid as they’ve seen it cause problems. “They like it unchanged”
    This doesn’t exactly align with my understanding, which is: start your trans changes around 60k and stay on em. BUT, if it’s never been changed and you’re up at 150k or whatever just leave it as it can do more harm than good.
    Thoughts?
  5. Feb 3, 2023 at 2:52 PM
    #65
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    Even though I find this guy more annoying than nails on a chalkboard, here’s how to put your truck into transmission fluid check mode.
    https://youtu.be/qvcgIxW9VqA
  6. Feb 3, 2023 at 5:06 PM
    #66
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Only if your positive that you had the right amount to begin with. If the trucks used, you don't know the history and there have been reports of over filled transmissions on 19+ models possibly because they were filling with the amount required if the truck still had a cooler. I have personally done it both ways, when I did my first drain and fill I measured what I took out and put that back in but it didnt sit right with me so I ended up going back and doing the check procedure and I did get a bit out and then felt better that I did it the right way. I think what happens is that people get intimidated by the check procedure so they skip it but once you do it once you'll see its easy and only get faster at it.
  7. Feb 3, 2023 at 5:16 PM
    #67
    pursuit2550
    pursuit2550 New Member
    Since we are talking about trans fluid, I wanted to ask if the tundra needs a trans cooler?
    TTund16 likes this.
  8. Feb 3, 2023 at 6:04 PM
    #68
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Once again Joe is right. Assumption is the mother of all #uck ups. Assuming the fluid level is correct to start with is a mistake. Why take the chance?
  9. Feb 4, 2023 at 6:47 AM
    #69
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    Just had mine done at the dealership. $293 flush using the trans pressure and WS fluid. Had mine done early at 32,000 miles as I towed before installing the cooler at 12,000 miles. I did not buy my truck from this dealership but I like their Service Manager. He's for installing the cooler that is missing on the 19-21's. I do most all of the maintenance on our Toyotas but I figured let the them do it for piece of mind. That price also included a fluid conditioner from BG products. You could save $30 ish off that price if you chose not to use it. Zero problems after 3000 miles since the service. Shifts nice and smooth. Also had my wife's 2018 Highlander done a few weeks ago. We bought it used with 66,000 miles. I had it done the week we bought it.
    Again, zero problems. The Highlander was a bit cheaper at around $275. I plan on having this done every 35 to 40,000 miles on both vehicles.
  10. Feb 4, 2023 at 7:46 AM
    #70
    AZBoatHauler
    So.Arizona
    Wow - incredible price considering it’s about $200 in fluid to do a full change.
  11. Feb 4, 2023 at 8:05 AM
    #71
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    As long as they are both about the same temperature.
    chugs and 2018TundraLimited like this.
  12. Feb 4, 2023 at 5:30 PM
    #72
    Redline870
    Ian
    Central NY
    Agreed, they must have missed my earlier post that my last two Toyota trucks were under filled at the factory and verified by the dealer.
  13. Feb 8, 2023 at 8:14 PM
    #73
    Dottat
    Dottat New Member
    Which dealership you getting that rate for? I'm in York and almost would be interested in driving anywhere in pa that would do that service at that price.
  14. Feb 9, 2023 at 4:30 AM
    #74
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    Williams Toyota Elmira
  15. Feb 9, 2023 at 5:48 AM
    #75
    Wallygator
    How often are you doing it? I'm at 30k now. Was planning to do it at 60k
  16. Feb 9, 2023 at 8:02 AM
    #76
    AZBoatHauler
    So.Arizona
    I’m swapping 4 qts about 1x/yr or 15k miles. Started at 45k. The first drain has been the darkest.
  17. Feb 9, 2023 at 8:09 AM
    #77
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    ditto.
    I do a drain every year. I run 20k a year.
    Wallygator and NWPirate like this.
  18. Feb 9, 2023 at 8:18 AM
    #78
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    So if we installed a trans cooler are we to pin it before doing the drain and fill? I should know as I installed the cooler but I forget.:monocle:
  19. Feb 9, 2023 at 8:18 AM
    #79
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes
    sask3m[QUOTED] likes this.
  20. Feb 9, 2023 at 10:31 AM
    #80
    Dottat
    Dottat New Member
    Well shoot I talked to York Toyota in pa and they are charging me 308$ for a fluid replacement service stating they are replacing 12 qts. At that rate, I think I may just let them handle it. Especially if it really does replace all 12qts.
  21. Feb 9, 2023 at 10:32 AM
    #81
    TTund16
    TTund16 New Member
    Math experts and scientists on this site can explain that what you drain and what you add can be significantly different. It is very hard to exactly match the amounts! For example draining 3.8754 qt. and then adding exactly 3.8754 qt. is VERY challenging and an average DIYer can be off by a factor of 2.
    We've had many examples of DIYers adding 8 qt. of engine oil to the sump after draining 4 qt. of ATF. Good example that it's hard to be exact and math can be confusing like Toyota ATF cooler thing or is it the old "warmer"?
    Rocko9999 likes this.
  22. Feb 10, 2023 at 7:49 AM
    #82
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Just follow the service manual already noted in this thread...it is not rocket science, lol.
  23. Feb 10, 2023 at 8:19 AM
    #83
    Rocko9999
    Rocko9999 New Member
    How are they replacing 12qts? I would want to know their procedure exactly.
    TTund16 likes this.
  24. Feb 10, 2023 at 8:30 AM
    #84
    Dottat
    Dottat New Member
    Yeah that was why i asked how many qts they replace. On the WO they have a line item for a BG3143 ATF fluid kit which is a 3 gallon jug of ATF fluid as well. Totaly cost out the door was $336. I was hoping perhaps a toyota tech saw that and could chime in more. The SA went and asked the tech who did the work on my truck how many qts it would replace prior doing the work.
    Rocko9999[QUOTED] likes this.
  25. Feb 10, 2023 at 9:18 AM
    #85
    matictundra
    Franco
    AZ
    FYI, the capacity is in you manual...I always have 2 qt extras for spillage. What I did is overfill, open the return line, and refill as I started the engine and move thru gears. Of course it took at least 2 people.
  26. Feb 10, 2023 at 11:16 AM
    #86
    TTund16
    TTund16 New Member
    Some places may charge the average consumer for 12 quarts since the owner's manual shows "fluid capacity" is 12 qt.
    and some others argue that 12 qt. on the receipt is a computer generated work # or line item that they have to select to start the work because manual calls for 12 qt. ... and you still have to pay the specified $ for the job as previously agreed and signed and please ignore the "computer" generated invoice. I've seen it many times.
    believe me not but you can't argue with the "computer" :spending::rofl:
    Lesson:
    Ask questions first not after the job is done!
  27. Feb 10, 2023 at 11:51 AM
    #87
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    TTund16 likes this.
  28. Feb 10, 2023 at 12:01 PM
    #88
    Dottat
    Dottat New Member
    Yep.. that's why I asked how many qts they would use. The SA walked into the shop to ask the tech who replied he would be using around 12qts.
    TTund16[QUOTED] likes this.
  29. Feb 10, 2023 at 12:07 PM
    #89
    Rocko9999
    4 for your truck, and 8 to remain on the shelf. ;)
    sask3m, Wallygator and AZBoatHauler like this.
  30. Feb 10, 2023 at 12:09 PM
    #90
    matictundra
    Franco
    AZ
    My tundra doesn't have a transaxle per google definition, lmao!
    chugs[QUOTED] and TTund16 like this.
