Toytec + Icon Lift Numbers
Discussion in 'Suspension' started by WreckedRooster, Jan 12, 2023.
  1. Jan 12, 2023 at 5:53 AM
    WreckedRooster
    WreckedRooster [OP] New Member
    Jake
    Went with Toytec 2.5's in the front set at 2.5" of lift and did the full Icon RXT leaf pack in the rear (minus the additional spring) which should do 1.75" of lift in the rear. Also running toytec 2.0 shocks in the rear. Here are my measurements:
    Driver front: 24.5
    Passenger front: 25.5
    Driver rear: 25
    Passenger rear: 25.75
    All measured from the center of the hub to the fender. Why are the numbers all over the place?
  2. Jan 12, 2023 at 6:01 AM
    These trucks are notable for having a driver's side lean. Some trucks get it, some do not. They also have a variance in front end height. You can take 3 trucks with the same trim level and model year, and all 3 will sit at different heights. If it's not drastically noticeable by eye, I wouldn't worry about it. There are too many factors and almost impossible to get it exact on all 4 corners.
    Toytec Lifts likes this.
  3. Jan 12, 2023 at 6:04 AM
    WreckedRooster
    Jake
    Thank you for the information (and your service). I had some lean in my Tacoma but it wasn't this bad and it was all in the front. Adjusted the coilovers to get it back even which I can do on this truck as well with it being a full inch of difference side to side in the front. Kind of clueless on the rears though.
  4. Jan 12, 2023 at 6:35 AM
    Thanks. Once you get the front leveled out, then you can see how the rear looks. Toytec does have some leveling options for the rear. They have what they call an axle shims.
  5. Jan 12, 2023 at 7:01 AM
    WreckedRooster
    Jake
    That's perfect! Thanks for the link. I don't even like my windows rolled down at different heights (I have issues, I know). Plus I want to keep some rake for when I tow. Thanks again!
  6. Jan 12, 2023 at 7:09 AM
    No problem at all!
  7. Feb 7, 2023 at 8:09 PM
    Mstaz
    Mstaz New Member
    OP, how are you liking this toytec setup? I’ve been looking at going this route as well.
    Vr0ck likes this.
  8. Feb 8, 2023 at 2:31 PM
    WreckedRooster
    Jake
    I like it. I'm still trying to get the side to side measurements dialed in but that's not Toytec's fault.
  9. Feb 9, 2023 at 10:35 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
  10. Feb 9, 2023 at 10:42 AM
    WreckedRooster
    Jake
  11. Feb 9, 2023 at 11:23 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Don't use the shims on the coilovers, it'll void the warranty on the coilovers. You have the ability to adjust the coilovers, send it :fistbump:
    Usually 1/4'' of pre-load adjustment will perk that front end up about 1/2'' in height:broccoli:
  12. Feb 9, 2023 at 11:37 AM
    WreckedRooster
    Jake
    Thanks for the reply. The issue i'm having is, as I'm adjusting one side, the other side is negatively affected to where I go and adjust it and then i'm off on the other side. And around and around I go. I've been making the adjustments after driving it each day. Made 3 so far and am still off side to side. Really chasing my tail on this for some reason. With 22" from center being factory, I'm trying to get it to 24.5" on both sides. I'll get there eventually I'm guessing, then I can focus on the back matching with the Icon springs.
  13. Feb 18, 2023 at 3:20 PM
    SanDiegoSlovak
    SanDiegoSlovak Junior Woodchuck
    San Diego, CA
    2008 Double Cab SR5 4x4
    Eibach Pro Truck Coilover Stage 2, RCI skids (engine, transmission, rear diff), Demello Hybrid Sliders, Morimoto XB headlights
    Factory is 22 inch for front and 24.5 inch for rear hub to fender? I read elsewhere that the factory rake is 2.5 inch.
    WreckedRooster[OP] likes this.
  14. Feb 20, 2023 at 10:01 AM
    Toytec Lifts
    Denver, CO.
    This is correct
