Transmission advice
Discussion in '2.5 Gen Tundras (2014-2021)' started by 4tBeta, Feb 8, 2023.
  1. Feb 8, 2023 at 4:21 PM
    4tBeta
    4tBeta [OP] New Member
    2015 Toyota Tundra SR5
    Okay so I recently picked up my first Tundra 2015 5.7l 4x4 my question is do you guys just drain the fluid and refill with new fluid or do I drop the pan drain, change filter, gasket, and refill or do transmission flush, filter, gasket and refill. Now I have always driven older used Chevy's drove for years and never touched the transmission not even check the dipstick and never had a problem BUT this truck was a big upgrade so
  2. Feb 8, 2023 at 4:32 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I do not flush but instead drain and refill with Toyota recommended ATF. Also be careful dropping the pan - the through bolts on the pan can snap off if not removed carefully. You can read more about both of these items on this forum.
  3. Feb 8, 2023 at 4:54 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    chugs likes this.
  4. Feb 8, 2023 at 5:00 PM
    blenton
    blenton New Member
    I also do not drop the pan, but opt for a drain and refill every 30k. This exchanges about 4 quarts, which is about 1/3 of the total fluid capacity. There isn’t really a serviceable filter in the transmission like most domestics; it’s just a screen so whether or not it needs to be replaced is debatable.
    Seeing as you just acquired the vehicle, I would recommend doing a drain and fill with every oil change for the next three oil changes. Or do it three times at 1000 mile intervals. There is a specific drain and fill procedure that is simply but must be strictly adhered to.
    I’d also look at the differential and transfer case oil. They are easy to do.
  5. Feb 8, 2023 at 5:02 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Drain and fill every 30 to 60k miles and you'll never have a problem.
    Tsm503 likes this.
  6. Feb 8, 2023 at 5:04 PM
    4tBeta
    Okay so do I need to drop the pan or do I not need to drop the pan do I just drain the fluid and then put new fluid in or do I have to drop the pan change the filter and gasket and everything and put new fluid like I'm looking for what you guys would advise I got 120,000 km I live in Canada and as far as I know nothing has been done
  7. Feb 8, 2023 at 5:05 PM
    4tBeta
    Okay thanks guys I appreciate it
  8. Feb 8, 2023 at 5:06 PM
    MadMaxCanon
    If you do drain and fill regularly you should never need to drop the pan. The filter is more of a strainer and guys who have opened theirs after 200k miles say it looks brand new.
  9. Feb 8, 2023 at 5:20 PM
    Joe333x
    Joe333x Member
    Boston
    You definitely did not read the link I posted but luckily people like to answer the same questions over and over again on here lol.
  10. Feb 8, 2023 at 5:24 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Drain and fill every 40k and you will be good
