TRD vs K&N air filter?
Discussion in '3rd Gen Tundras (2022+)' started by worksjo, Feb 7, 2023.
  1. Feb 7, 2023 at 6:26 AM
    worksjo
    worksjo [OP] New Member
    2023 Tundra SR5 Off Road
    Has anyone had experience with the K&N air filter vs the TRD performance air filter? Design wise they basically look the same so I’m wondering if anyone noticed a difference?
    I’ve always used K&N air filters in our cars in the past and been very happy, but the TRD filters are basically the same price and put out specifically by Toyota for this motor so I’m tempted to go that route this time.
  2. Feb 7, 2023 at 6:33 AM
    wedemmoez
    wedemmoez New Member
    2022 Black Tundra TRD Pro
    There is almost no difference between any air filters if you go with a reputable brand, so whichever one you like will be fine!
  3. Feb 7, 2023 at 7:13 AM
    pursuit2550
    pursuit2550 New Member
    Me personally, I stay far away from K&N filters or any oiled filter. Either OEM or AFE dry filter.
    Skidmarcx, FLKX, osu1978 and 12 others like this.
  4. Feb 7, 2023 at 7:23 AM
    TUNDRA-TY
    TUNDRA-TY Winter SUCKS!
    Tyler
    Tricities, WA
    23 SR5 4WD CMSB CSM
    Same exact filter. In fact the Toyota brand filters I got for my new Tundra specifically say clean with a K&N recharge kit...
    ColoradoTJ likes this.
  5. Feb 7, 2023 at 7:47 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    The TRD air filter says to use K&N oil after you clean it
  6. Feb 7, 2023 at 7:52 AM
    Markysharky
    Markysharky New Member
    I put the trd ones in my 2023 SR. Looks just like a K and N except the rubber is red not black. A slightly higher amount of engine noise since the swap. Don’t forget to buy two!
    Yaboy likes this.
  7. Feb 7, 2023 at 8:27 AM
    worksjo
    I just called my dealer and they said they could do them for $38.50ea on an online match so I figure I’ll try the TRD’s
    Markysharky and Yaboy like this.
  8. Feb 7, 2023 at 9:14 AM
    Markysharky
    I paid $65 each from Amazon. Dealership has a good price.
  9. Feb 7, 2023 at 11:03 AM
    worksjo
    I saw the same on Amazon, and started to get worried he was ordering the standard filter, so I called back the part # checked out. :rofl:
  10. Feb 7, 2023 at 11:30 AM
    mass-hole
    mass-hole New Member
    Why does it matter if its turbo'd? A turbo'd engine doenst suck air in any harder than an NA engine making the same power.
  11. Feb 7, 2023 at 12:57 PM
    worksjo
    I know that is a thing for Turbos and to each his own, but I went down the rabbit hole on this before on my Audi S6 which runs fairly high boost, the few actual documented cases on that engine of mass air flow sensor fouling by an oiled air filter were from people who had recharged and over oiled the filter. I mean it’s Toyota selling the part directly with instructions on how to recharge so they can’t that worried about it.
    Like I said to each his own, but while I like the ability to clean and recharge an oiled air filter in a pinch trail/road side if needed. They are fairly cheap and for normal maintenance I usually just replace them.
    Sure, the benefit to an oiled air filter is pretty debatable, I’ve put them on probably 8-10 cars and motorcycles, some with a very noticeable difference some with none.
  12. Feb 7, 2023 at 1:28 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    The only reason I see going for the TRD Filter or K&N Filter is the reusability. Cleaning kit can be bought for $20 at local parts store and has multiple use. The power gain is negligible on stock tune. I may get the TRD filter as my evo also uses K&N filter and I have cleaning kit for it already.
    As for oiled filters destroying MAF. That's mostly due to user error, usually people over oiling the filter when cleaning. I'm running a ExtremeTurboSystem intake on my Evo X which uses K&N Filter for well over 30k miles now and never had any issue with MAF sensor.
    Black Wolf, xwarcat and Hadelson like this.
  13. Feb 7, 2023 at 1:29 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    AFE Dry all day errrrday
  14. Feb 7, 2023 at 4:08 PM
    AWDDude
    AWDDude New Member
    2023 Tundra Limited - Crew Max TRD Off Road 4x4
    Yeah, I very much dislike K&N filters. Take one out of the box and hold it up to the light, there are tons of holes.
    Charvonia Design likes this.
  15. Feb 7, 2023 at 9:53 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    My other Toyo has 277,000 and has had a K&N since it was new. Just replaced original MAF at 272. Still runs strong and doesn’t burn a drop of oil. I must have oiled mine properly.
  16. Mar 3, 2023 at 3:08 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    In addition you can clean your MAF also. For me it’s part of my regular maintenance schedule…
    TundyMcTunra likes this.
  17. Mar 4, 2023 at 11:53 AM
    Jasco1
    Jasco1 New Member
    23 SR5 Crewmax TRD OR Lunar Rock
    This guy is great! He has some very thorough testing. I have watched some of his oil testing videos that left me surprised with the results.
    Mattedfred[QUOTED] likes this.
  18. Mar 4, 2023 at 4:45 PM
    Garrett77
    Garrett77 New Member
    2020 Tundra 4x4 XP Predator
    He's saying both making the same power. A combustion engine is all about moving air, the more air you move the more power you will make. If they're making the same power they're moving the same amount of air.
    Had a '97 Supra turbo I modified from 320 crank hp to 680whp, and it didn't run by MAF it ran by MAP. I lived in Houston at the time, which was the Supra capital of the US back around the turn of century. We all used K&N cone filters, nobody ever sited any issues, only heard good things. UOAs were fine.
  19. Mar 4, 2023 at 5:03 PM
    Garrett77
    Oh, K&N does have both the oiled version and a dry alternative now.
  20. Mar 4, 2023 at 5:53 PM
    Markysharky
    Clean the filter and forget about it. Engine will wear out for other reasons way before. Oiled filters just need to be cleaned more often than a standard pleated filter for proper filtration.
  21. Mar 6, 2023 at 6:35 AM
    osu1978
    osu1978 New Member
    TRD air filter and K&N are basically the same.
  22. Mar 6, 2023 at 7:18 AM
    Garrett77
    I really think this entire "internet hates K&N guts" thing that has gone on for years now is not warranted, just a bunch of people jumping on a bandwagon and virtue signaling. Like people virtue signaling and insisting on changing their fully synthetic oil after only 5k miles of use in normal conditions.
    In searching a little, I did find threads where K&N users demonstrated comparatively poorer filtration results, but for every thread people were bashing K&Ns there were threads like this:
    https://stangnet.com/mustang-forums/threads/k-n-filter-effectiveness-from-oil-analysis.847239/
    Or posts like this:
    https://forums.anandtech.com/thread...ess-at-filtering.2244133/page-3#post-33405862
    Unless you're living in the desert and driving through sandstorms every day, I wouldn't worry about what type of air filter you're using.
  23. Mar 6, 2023 at 7:20 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    why?
    Sierradevil likes this.
  24. Mar 6, 2023 at 9:54 AM
    pursuit2550
  25. Mar 6, 2023 at 9:55 AM
    pursuit2550
    When I didn’t know better I was on the K&N bandwagon. Now you couldn’t give one to me for free.
  26. Mar 6, 2023 at 10:19 AM
    Markysharky
    K and N are fine. Just lets more small particles in and if not cleaned regularly can get clogged up. For a daily driver that’s not over oiled it shouldn’t cause any issues. Unless you’re in the Baja race or always on dirt I wouldn’t worry about that.
  27. Mar 6, 2023 at 10:44 AM
    Black widow TRD
    Manuel
    Didn’t K&N have some marketing back I. The days, that the US Army would use their air filters in their Apache helicopters?
  28. Mar 6, 2023 at 10:53 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Not related to the engine air filter (I prefer dry filter) but the k&n cabin filter is great for critters, if that’s a thing where you’re at. It’s a dry washable filter that has a steel mesh over both sides. Makes it harder for them to chew through. Yup, I know, still have to do the screen under wiper cowl (on my to do list).
  29. Mar 6, 2023 at 11:39 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I wouldn't waste my time with a K&N unless you are working on a performance build. You're not going to see most of the benefits unless you are at WOT often.
    Even if you decide to run one you run the risk of developing MAF issues.
    The added engine wear is a long term problem that will impact some more than others depending on where you live.
    Ultimately it is a trade off better flow vs better filtration.
  30. Mar 6, 2023 at 12:47 PM
    pursuit2550
    I will take the better filtration. Any aftermarket filter will do nothing for performance. Need to remember an engine is a pump. A filter doesn’t magically make it pump more. Forced induction will do that.
