Toyomafia - The Clubhouse. Balls and Burgers Summer 2025
  1. Feb 7, 2023 at 4:53 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  2. Feb 7, 2023 at 4:53 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
  3. Feb 7, 2023 at 4:55 PM
    Tripleconpanna
    You shouldn't drink and miter saw :cool:
  4. Feb 7, 2023 at 4:56 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  5. Feb 7, 2023 at 5:02 PM
    Azblue
    The Dirty T ( ^_^)_且
    Na, drink up. Just make sure that you first remove any pesky safety guards or covers.
  6. Feb 7, 2023 at 5:03 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The one for the table saw is in a pile of parts somewhere. Can’t see shit with them on.
  7. Feb 7, 2023 at 5:03 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Make sure to wear your safety squints as well
  8. Feb 7, 2023 at 5:05 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    gosolo, Odin43, Outbound and 10 others like this.
  9. Feb 7, 2023 at 5:06 PM
    Azblue
    It's like when I weld. I always make sure to wear my safety sandals, tank top, and shorts.
    gosolo, Outbound, jewsNbrews and 9 others like this.
  10. Feb 7, 2023 at 5:07 PM
    I’m still healing from a welding spatter wearing shorts like a month ago!
  11. Feb 7, 2023 at 5:09 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    I think you should open it with said mitre saw and post a vid.
  12. Feb 7, 2023 at 5:10 PM
    Azblue
    I always will finish a welding project and then a few days later wonder how in the hell I was able to sunburn only my inner right arm enough to peel.
    Then it kicks in, and I'm oh, yeah, arc burn.
    gosolo, RainMan_PNW, Outbound and 7 others like this.
  13. Feb 7, 2023 at 5:13 PM
    Yep every time, usually it’s like 4 days later and it’s like why is my arm blistering??? I’m a troglodyte!!!!
    gosolo, RainMan_PNW, Outbound and 5 others like this.
  14. Feb 7, 2023 at 5:17 PM
    Azblue
    Maybe next time I'll think ahead and put some sunscreen on before I weld. I guess I could wear a long sleeve shirt, but then that means I'd have to go buy one.
    gosolo, Odin43, RainMan_PNW and 6 others like this.
  15. Feb 7, 2023 at 5:19 PM
    You don’t have any business casual long sleeves? Retire one, or don’t and wear it to work on Monday hahah
  16. Feb 7, 2023 at 5:32 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    My long sleeve “work” shirts would be fun once a spark hits them. I imagine some kind of scene from Fire Marshal Bill
  17. Feb 7, 2023 at 5:33 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Side note....I'm never doing it with melted chocolate again! Fool me once...
  18. Feb 7, 2023 at 5:34 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Oh, you're calling it "free" now?
    Just because money isn't exchanged....doesn't mean it's free.o_O
  19. Feb 7, 2023 at 5:37 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I fight more with bacon grease splatter than weld splatter
  20. Feb 7, 2023 at 5:45 PM
    I cook bacon shirtless as well
  21. Feb 7, 2023 at 5:48 PM
    Little project I wrapped up today. We have to dip tube bundle heat exchanger in this chemical every summer, so I welded some stuff up to hold a beam that a trolly and winch ride on to help us dip and drip. My vertical passes sucked ass, but I did ok on everything else, it will hold, so that all that matters
    5FDF79F6-5445-4F47-8165-3FCFFA42ED14.jpg 1BD218FF-CF64-4C80-8E0B-95F7E580B6F7.jpg F98280B1-F49F-439B-8081-983032067C16.jpg 69C0F03E-DB6A-42F8-811B-403B454C00E5.jpg 250C5ECC-BCC4-4815-BB48-66A091759D42.jpg 9F1AB61E-56D9-47F0-9D05-4C321100832D.jpg
  22. Feb 7, 2023 at 5:50 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Oh.... yes. Just no shirt. Same here
  23. Feb 7, 2023 at 5:51 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    At first I was thinking of industrial size in used to seeing and was thoroughly and extremely impressed.
    Now I'm just thoroughly impressed.:thumbsup:
  24. Feb 7, 2023 at 5:57 PM
    Industrial sized heat exchangers?
    Yeah these aren’t to yuge, but big enough to not want to lift. The chemical we use is crazy, it’s food safe, but what it does to calcium and scale is insane and scary to watch!
    My first year we didn’t have spares so we had to shut down steam and water for a few hours while we drained it, pulled it, take to the dip tanks and then come back and install. Now we bring a clean one and swap it out in a hour(not to mention all the sediment we stir up in the stowage tanks and then the building pisses brown water for a day hahah)
  25. Feb 7, 2023 at 6:01 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    So are these heat exchangers being used to heat water? Not sure what application this is used on for the residential side
    Beach Toy and Cpl_Punishment like this.
  26. Feb 7, 2023 at 6:08 PM
    Yeah Domestic hot water, and most of the water is from a well, so lots of sediment
    we also have separate heat exchangers for building heating water, closed loop so hopefully not as bad(we haven’t done those since I’ve been there….)
  27. Feb 7, 2023 at 6:11 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Gotcha. I know heat exchangers are typically pretty efficient and all....which is why they're great in an industrial application.
    I bet it running well water through it can be a mess tho. My parents had a shallow well on their property growing up. Our white shirts were yellow within about 3-5 washes. Smelled good and clean. Just stained with hard water. Drank that straight from a water hose and it's still some of the best water I've had:D
  28. Feb 7, 2023 at 6:13 PM
    TaquitoBandito
    Joel (AKA Bif)
    You happen to have an extra bedroom? :)
    Azblue and TRDFerguson like this.
  29. Feb 7, 2023 at 6:15 PM
    biebs96
    PA
    I love beer/tool photos
  30. Feb 7, 2023 at 6:16 PM
    Azblue
    I sit on my ass while my wife cooks bacon, then I eat it.
