Side mirror wiring schematic 2021 tundra
Discussion in 'General Tundra Discussion' started by Finley18, Feb 6, 2023.
  1. Feb 6, 2023 at 8:34 AM
    Finley18
    Finley18 [OP] New Member
    2021 Tundra 1974
    I'm looking for the wiring schematic color code, driver's side mirror.
  2. Feb 6, 2023 at 8:48 AM
    Taco-Spike
    Two Trucks
  3. Feb 6, 2023 at 9:24 AM
    Finley18
    2021 Tundra 1974
    I thought I was in the 2021 Tundra discussion. I'm looking for through the door pin connector wire color code for my mirror.
  4. Feb 7, 2023 at 6:03 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    While I'm used to 1st Gen EWD's and their EWD's only require one document, the 2021 requires numerous docs. My suggestion is to go to @RainMan_PNW thread in the Electrical Forum here and at least download the 3 red arrowed docs. Thru those you will find the N5 connector and it's associated pin #/color.
    Ultimate TUNDRA Wiring Diagrams Collection | Toyota Tundra Forum (tundras.com)
    Thru a project @RainMan_PNW was working on regarding a 2021, the below pic was posted of the N5 Connector showing pin #'s and usage.
    Rainman's 2021 Lunar Rock TRD Pro Build
    N5 connector....
    Perhaps knowing more of what you are attempting, other info can be provided.
    Finley18[OP] likes this.
  5. Feb 7, 2023 at 6:21 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That pinout is what I finished with in my mirror install.
    In a 1794 or Platinum (seat memory), that pinout is not the same.
    OP - BubbaW has you on the right track though. You’ll need the 2021 wiring diagrams. Start with the schematic for Remote Control Mirror (with memory), but that doesn’t show every wire (other systems also connect to the mirrors). That will lead you to connector N5.
    Looking in the Connector Details, you’ll find N5 and all of the systems it is shown in. Go back to each of those system diagrams to chase out the rest of the wires.
    RobertD likes this.
  6. Feb 7, 2023 at 1:56 PM
    Finley18
    2021 Tundra 1974
    Thanks, the wiring details worked and I found the problem.
    BubbaW likes this.
