Eibach stage 1 lift gen 2
Discussion in 'Suspension' started by Fcampa89, Feb 6, 2023.
  1. Feb 6, 2023 at 10:25 PM
    Fcampa89
    Fcampa89 [OP] New Member
    2019 Tundra Platinum
    None at the moment
    0948BE54-65A8-445D-9A0A-2B3B53C68CA1.jpg Anyone running eibach stage 1 lift?
  2. Feb 7, 2023 at 7:41 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    We don't sell many of them to the Tundra guys. Most who are at that price point are going 5100s, but there's nothing wrong with that kit you've linked. What's your question?
    RobertD likes this.
  3. Feb 7, 2023 at 7:46 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I have it on my 2021. I have been pleased so far.
    Odin43, QuicksandPNW and Fcampa89[OP] like this.
  4. Feb 7, 2023 at 8:20 AM
    Fcampa89
    None at the moment
    Trying to see what kit is better for this price range.
  5. Feb 7, 2023 at 8:24 AM
    Fcampa89
    None at the moment
    For the 5100's will i need to buy coils separate?
  6. Feb 7, 2023 at 8:34 AM
    memario1214
    Colton
    Missoula, MT
    Yes and/or no. The 5100s are intended to reuse your OEM spring from the shocks currently installed on your truck. However, you have the option to pair them with a lift coil from ARB or Eibach to provide your lift. For the money we still hold that the Eibach kit is a good one. Won't try and talk you out of it.
  7. Feb 7, 2023 at 8:10 PM
    Fcampa89
    None at the moment
    With a kit like this will I need to install a diff drop?
  8. Feb 9, 2023 at 3:09 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Such a killer kit, sold a bunch of these kits over the years on the forum here.
    Best bang for the buck kit on the market in my opinion.
    5100s are good, yes. Downside you'll have to disassemble stock units, re-use top mounts and bushing, or buy new ones, then assemble with stock springs, adjust by pre-loading the stock spring which will only decrease ride quality and offroad performance. The labor time associated with that can bump up quickly either for yourself or the shop you work with.
    We offer the Eibach kit in house here as a pre-assembled unit to make it as user friendly as possible - simply unbolt the old, bolt in the new call it a day.
    **Note - rear shocks are listed as backordered right now but I will just get them from my secondary warehouse for you. DM me if you have questions or need help ordering :fistbump: discounts ready for the Tundra members
    QuicksandPNW, JLS in WA and WFD473 like this.
  9. Feb 9, 2023 at 7:49 PM
    Fcampa89
    None at the moment
    I ended up ordering this kit! coming in tomorrow so hopefully Saturday i can install it at work.
  10. Feb 9, 2023 at 8:52 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I’ve had these for for almost three years now. I’ve been happy with them. Lot of bang for the buck.
    Toytec Lifts and Fcampa89[OP] like this.
  11. Feb 10, 2023 at 8:49 AM
    Toytec Lifts
    Denver, CO.
    Awesome news man!! DM me your order number, Ill see what else I can throw in for ya swag wise :fistbump:
  12. Feb 10, 2023 at 9:26 AM
    myfirsttundra1
    myfirsttundra1 New Member
    2023 Platinum crewmax
    can I reliably fit 285/75r18 with this kit on stock trd off road wheels?
  13. Feb 10, 2023 at 9:41 AM
    JLS in WA
    You can lift the front up to 2.5-3” with this on the highest clip setting. Per other threads, this will accommodate that tire size.
  14. Feb 10, 2023 at 10:54 AM
    QuicksandPNW
    QuicksandPNW New Member
    Kevin
    Washington State
    2020 Quicksand Tundra SR5
    Bed Rail System Tonneau Cover
    This is most likely the kit I will be going with once I have funds to upgrade my 2020’s suspension. Out of curiosity, how many hours on average should it take a shop to install?
    Toytec Lifts[QUOTED] likes this.
  15. Feb 10, 2023 at 11:36 AM
    Toytec Lifts
    Denver, CO.
    On average should be around 6-7 hours with alignment on that kit to be installed.
    QuicksandPNW[QUOTED] likes this.
  16. Feb 10, 2023 at 11:59 AM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    My neighbor and I did the Stage 2 in my driveway in about 4-5 hours, with neither of us having worked on a Tundra before. Second time around would be about 3 hours.
  17. Feb 10, 2023 at 2:47 PM
    JLS in WA
    I did mine by myself, in the driveway. I did not buy the pre assembled kit. I finished in about 9 hours, but I also replaced leaf springs.
    With pre assembled I would think 4-5 hours, easy. 6ish with an alignment sounds right.
    QuicksandPNW likes this.
  18. Feb 10, 2023 at 4:03 PM
    Js1732
    Js1732 New Member
    I have been running them for about a month on my 2015 and very satisfied. A lot of different routes to go and just making a decision is the hardest part of it all. No buyers remorse from me.
  19. Feb 10, 2023 at 4:08 PM
    SR5style
    SR5style New Member
    2019 MGM SR5 4wd Crewmax
    I got the stage 1 installed a few weeks ago. It replaced a coil spacer. Ride quality is much better, and I have no complaints.
  20. Feb 11, 2023 at 7:26 AM
    Kung
    KG, VA
    @memario1214 - two questions for you:
    1. I've got a 2020 with the TRD Off-Road package. Would the 5100's be an improvement over what comes w/the TRD Off-Road package?
    2. Given most of my driving (90%) is on-road, with 10% on gravel and the occasional off-road venture, I'm assuming either this or the 5100's would be sufficient. Safe assumption? I also wouldn't have any issue throwing Toytecs at it either. LOL
    Edited to add: Actually, given what was written above, about reusing the factory springs, I'm thinking it might make more sense to just purchase something like the Eibach 2.5" lift kit. All I want is 2-2.5" of lift for a slightly more aggressive stance (and clearance) and a bit more capability.
  21. Feb 11, 2023 at 8:34 AM
    BrunoTheRescuePup
    SW Portland Metro
  22. Feb 11, 2023 at 10:29 AM
    Kung
    KG, VA
    How is it when you do go off road at all (gravel roads/bumps/etc.)? It's not like my current setup is terrible; but by the same token, if I'm going to drop $2-3K or so on tires, a lift, possibly new rims, etc., I want to make sure it rides well on and off road. :)
    RobertD likes this.
  23. Feb 11, 2023 at 12:15 PM
    JRS
    JRS New Member
    2012 DCLB
    The stage one and two will be similar ride quality. Stage two gives you a more robust assembly with the obvious threaded adjustability. I went stage two for those reasons alone.
    Off road capability likely isn't 'much' better than any other standard 2" offering. Eibach has a lower spring rate which will make things a bit smoother/plus. But really, you get more performance from the tires, which all of these cheaper 2" kits make room for. 37s aired up on a rocky section vs aired down makes far more difference than the damping rates of Bilstein vs Eibach.
    For your description, go with an Eibach kit assuming you don't want to haul ass down trail. I simply can't keep up with a buddy who has a hybrid Jeep Wrangler with 37s and adjustable 2.5" dampers which were revalved by Accutune. His vehicles soaks up hits at a level which a fixed 2" simply cannot.
    JLS in WA and Kung like this.
  24. Feb 12, 2023 at 7:19 AM
    Kung
    KG, VA
    I don't - e.g., I occasionally go off-road but it's usually purpose-driven, and not at all hauling ass off-road when I do. 95% or so of my driving is on pavement with a moderate amount of (crappy) gravel roads.
    All I really want is a bit of a lift, a bit more capability/smoother ride, which it sounds like the basic kit will do. I appreciate your input. :). And yeah, you'e right on the tires - I had Michelin LTX AT/2's, and replaced them with Yokohama Geolandars. I was shocked (and not really in a good way) how much it changed the driving dynamics of my truck.
    JRS[QUOTED] likes this.
  25. Feb 13, 2023 at 5:05 PM
    Fcampa89
    None at the moment
    I did mine myself at work with alignment. Took about 4-5 hours. Ride quality so far is really good! I did the 3in. I’m gonna have to redo the alignment. Noticed the front wheels have more of a positive camber.
    Ace96 and Mfanatic22 like this.
  26. Feb 13, 2023 at 5:10 PM
    Fcampa89
    None at the moment
  27. Feb 17, 2023 at 6:35 AM
    memario1214
    Colton
    Missoula, MT
    Apologies for the delay here! Was out in the sticks so we're just getting back to the grind.
    @JRS has some good feedback for you above
    1) Yes - Pretty much any "performance" shock is going to be an improvement in what comes with a stock TRD OR, especially if you are trying to get a lift. That said, you're definitely going to feel increased firmness in the suspension overall. Where a performance shock shines is when you get any sort of roughness in the road.
    2) Correct. If you're just bumbling around then something a little more mild is usually sufficient as long as you're not asking it to go 50mph down washboards.
  28. Feb 17, 2023 at 7:03 AM
    Kung
    KG, VA
    Excellent. I definitely understand that I'll feel increased firmness - actually that's part of what I want. On-road, while the TRD Off-Road shocks are a huge improvement over the OEM offering on my previous '13 F150 (those shocks *SUCKED*), I can still feel what I'd call the 'jittering' when I hit small bumps in the road. I'd rather just get the bumps over with via a firmer suspension. LOL
    I did end up purchasing the Toytec/Eibach 2.5" lift kit. Granted almost nothing is going to smooth out 50MPH washboards (which, uh, I've never asked my truck to do *cough cough* :wink:) but in the end all I really *need* is a bit smoother ride, 2.5" of lift, and slightly increased capability as opposed to what comes with the stock TRD Off-Road package, all of which it sounds like the Toytec/Eibach will do. I appreciate the input and assistance. :)
  29. Feb 17, 2023 at 7:44 AM
    JRS
    JRS New Member
    2012 DCLB
    Just to close out the thread and make sure this doesn't confuse future readers, I was referencing damper body sizes. I wasn't explicit and it could be misread as 2" lift.
  30. Feb 21, 2023 at 11:41 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    I have the pro truck set at 2” front and rear. Am I safe to avoid the diff drop or is it recommended. I see above 2” it’s recommended
