Is there a solution for 5 to 6 lug wheels?
Discussion in 'Wheels & Tires' started by IowaGuy, Feb 6, 2023.
  1. Feb 6, 2023 at 11:27 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am seeing a lot of newer 6-lug Tundra wheels for sale on book of faces marketplace. I guess these are coming off 2022 trucks and newer as people replace their wheels with aftermarket. Is there a viable solution for putting 6 lugs on a 5-lug truck? I am guessing not really since they would have to be out further and the offset. Some of these take-offs are decent looking and not too bad priced.327773205_6521550624527312_7548330234266895024_n.jpg
  2. Feb 6, 2023 at 11:32 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You'd have to call a wheel spacer manufacturer and see if they could do a custom set for you.
    Our First gens have something different about the lug studs versus the third gen. I think lug stud diameter? Regardless, some dude went through the trouble of having custom spacers made so he could run third gen wheels. You'd have to do the same.
    I think he said he spent somewhere close to a grand including buying the rims/tires used?
    Maybe @shifty` could dig that thread up. I can't search worth half a fuck on my phone.
    FrenchToasty, des2mtn and Taco-Spike like this.
  3. Feb 6, 2023 at 11:37 AM
    Buy a 1st gen or a 3rd gen, problem solved
    Mfanatic22, Tundra2, Mater and 4 others like this.
  4. Feb 6, 2023 at 11:40 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    The only feasible way is with conversion spacers. I doubt that there are commercial spacers available for this specific conversion, so it will have to be a custom made set. It's possible, but you might pay more for the spacers than for a whole new set of aftermarket wheels.
    FrenchToasty, shifty` and des2mtn like this.
  5. Feb 6, 2023 at 12:38 PM
    You're talking about this thread: https://www.tundras.com/threads/3rd-gen-wheels-on-1st-gen.108450/
    These 2 threads also have info, not as significant. It's a common question, I found the answer in 20sec using Search, even with it kinda blowing goats on this platform:
    https://www.tundras.com/threads/retro-fitting-3rd-gen-tundra-rims-on-my-06.117875/
    https://www.tundras.com/threads/6-lug-to-5-lug-adapters.56558/
    But basically @Boerseun gave you the tl;dr right there ^^
  6. Feb 6, 2023 at 1:22 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Short answer: No. lol
  7. Nov 16, 2023 at 6:30 PM
    Azzotrix
    Azzotrix New Member
    2007 Red Tundra TRD Limited
    ive got the new TRD wheels on mine, picked them up with tires and all. Only 3500 miles for $500. bought these hub centric spacers on ebay:
    https://www.ebay.com/itm/1663775390...ldLPjbbQKy&var=&widget_ver=artemis&media=COPY
    They clear perfectly with no leveling kit.
    So far i have had no issues at all.
    Boerseun likes this.
  8. Nov 16, 2023 at 6:37 PM
    Azzotrix
    Azzotrix New Member
    KNABORES likes this.
  9. Nov 16, 2023 at 6:43 PM
    Azzotrix
    Azzotrix New Member
    Also just wanted to point out that i did torque to spec and re-torque after 5k miles with medium thread lock.
  10. Nov 16, 2023 at 6:56 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    artsr2002 likes this.
  11. Nov 16, 2023 at 7:00 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  12. Nov 16, 2023 at 7:14 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I wonder if the 3rd gen axle would fit under the second gen truck. Then you could find a wreck…
    Azzotrix likes this.
  13. Nov 16, 2023 at 7:34 PM
    Azzotrix
    Azzotrix New Member
    Not sure where you are getting that number?
    It was $150 for a full set of 4.
  14. Nov 16, 2023 at 7:41 PM
    Azzotrix
    Azzotrix New Member
    I see now, weird error.
  15. Nov 17, 2023 at 5:12 AM
    IowaGuy
    In Process
    Thanks, now I am back to decision making
    It looks like the spacer bolts onto the current lugs and then there is a cover ring that goes over that and the 6 studs?
  16. Nov 17, 2023 at 11:15 AM
    Azzotrix
    Azzotrix New Member
    Yes there is 2 pieces, it is a cool design. Very well built in my opinion.
  17. Nov 17, 2023 at 11:29 AM
    Azzotrix
    Azzotrix New Member
    First layer can bolt on with included lug nuts. the thread is the same for both trucks and the spacer (14x1.5). The cool part is that, when you put that first piece on, the nuts sit flush in the holes almost perfectly. Which actually makes it more safe because when you put the next piece on, it sits flush on top of the other one and the other nuts which prevents them from backing off. Same thing applies with the second piece as the wheel sits on top of the allen bolts preventing them from coming out.
    It helps eliminate the risks associated with having more bolts that can come loose.
    FYI you will need extra lug nuts. I would try and get the factory 3rd gen ones.
    Leo's first likes this.
  18. Nov 17, 2023 at 6:57 PM
    IowaGuy
    In Process
    How much farther will these stick out or what is the difference in offset?
  19. Nov 17, 2023 at 9:15 PM
    Azzotrix
    Azzotrix New Member
    2 inches further out
  20. Nov 18, 2023 at 7:47 AM
    IowaGuy
    In Process
    I am trying to find the offset on the newer tundra wheels and how much farther they would stick out.
  21. Apr 7, 2024 at 8:24 PM
    twest0310
    twest0310 New Member
