Ac making noise
Discussion in 'General Tundra Discussion' started by Giants3890, Jun 13, 2021.
  1. Jun 13, 2021 at 7:59 PM
    Giants3890
    Giants3890 [OP] New Member
    14 tundra
    Noticed my ac light was blinking. The blinking stopped but there is a bad noise coming from the compressor only when the ac is on. It does make cold air but the noise worries me. The clutch still spins freely when truck is off. Tried removing and Putting back the relay and did nothing. Any help is much appreciated
  2. Jun 14, 2021 at 6:49 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    If you are getting a light and hearing a noise i would definitely take it to a shop and have it looked at.
  3. Jun 14, 2021 at 8:00 AM
    Giants3890
    14 tundra
  4. Jun 14, 2021 at 11:00 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    yes, most likely the aftermarket one would work.
    Lots of youtube videos for the clutch on the compressor (not toyota specific) but you'll get the idea.
    I'd start there. Otherwise you'll be vacuuming the R-134a out (most likely at a shop unless you have refrigerant recovery gear), then you'll need to replace the dehydator assembly, finally you'll consider n2 pressure testing hte system to verify leak free, vacuum that stuff out and then finally load freon and oil per specs.
    Not impossible, but you need to license to work with the R-134a (freon) or you could be EPA fined.
    I'd try to verify its the clutch and replace that assembly before i'd go after the compressor.
    Good luck.
  5. Jun 21, 2021 at 5:15 AM
    Giants3890
    14 tundra
    Update—— swapped out ac compressor for new aftermarket one off rock auto. Between the part and the gas total price $230. Everything is working great now. The noise was the compressor not the clutch. Assuming something inside just wore down. 130k miles.
    2mchfun likes this.
  6. Jun 21, 2021 at 7:44 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    Glad you got it fixed.
  7. Feb 4, 2023 at 8:46 PM
    Jamesd546
    Jamesd546 Cliffard, the Big Red Truck
    James
    Bone Stock 2007 Tundra Crewmax Limited
    My blank canvas for the overland build
    Reviving this thread before starting another...
    just got back from a trip from Sacramento, CA to Bend OR and back. Two times I stopped to let the dog out before he...not important...I left the truck running to keep the GF warm. I started hearing the screeching noise and killed the engine. Popped the hood, didn't see anything out of the ordinary so I restarted and watched the clutch engage but come to a loud stop then the clutch disengage and leave the AC light flashing. Bad compressor? The truck just turned 58k today on the way back...
  8. Feb 4, 2023 at 9:30 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    This is interesting, I've got about 5 times your mileage and lived in the hotest environments and its still chugging along... knock on wood, lol.. I'll put it on my list. For a replacement I would pit online dealership costs vs rock auto or local shop cost... Replaced my radiator, buying from local stealership... rockauto was about $386, Oreilly and autozone showed about the same price. Called the parts guy at said dealership and he was talking about $490 pretax. I asked them for a price match online and he sent me a link to their online website as its different now... $230 later I got an OEM replacement radiator, with the extra change I saved I bought some coolant, we can call it free...
  9. Feb 4, 2023 at 9:34 PM
    blackdemon_tt
    I will take that back, lol, its $420 online local to my stealership.
