Crewmax back interior panel
Discussion in '2.5 Gen Tundras (2014-2021)' started by denali302, Feb 3, 2023.
  1. Feb 3, 2023 at 4:17 PM
    denali302
    denali302 [OP] Meh...
    Michael
    2017 Crew Max
    Has anyone removed this? or possibly have instructions or insights on how to remove it?
    If its not clear, this is the metal panel behind the rear seats in a crewmax (maybe others) - I want to be able to mount some things to it, but want to remove to do so I don't screw all the way through (and get a better fit).
  2. Feb 7, 2023 at 6:28 PM
    denali302
    Michael
    2017 Crew Max
    Nobody. Huh. Bummer.
  3. Feb 7, 2023 at 6:45 PM
    Pretty sure some threads in here describe removing this panel to get to the rear window motor and regulator mechanism.
  4. Feb 7, 2023 at 6:51 PM
    2mchfun
    Have you considered a plywood insert in front of it for a mounting surface? Seen a few go down this road.
  5. Feb 7, 2023 at 6:55 PM
    denali302
    Michael
    2017 Crew Max
    @2mchfun I have - but need a way to secure it - and would likely want to screw/mount to that panel, which is why I’m curious about removal.
    @KNABORES - I’ll do a search for the window motor. I searched initially but didn’t use the right keywords I guess
    2mchfun likes this.
  6. Feb 7, 2023 at 7:10 PM
  7. Feb 7, 2023 at 7:28 PM
    denali302
    Michael
    2017 Crew Max
    Oh man. That’s awesome. My second search also didn’t find it - but that video is great. Super simple. Thanks a ton @KNABORES
  8. Feb 7, 2023 at 7:36 PM
    I’ve been trying to champion the practice of using Google to search for what you want and add Tundras.com to the end of the search. Works like a charm.
    panicman, AGTundra and BlueRibbon4x4 like this.
  9. Feb 8, 2023 at 8:28 AM
    Rocko9999
    Rocko9999 New Member
    https://youtu.be/qOmnuTQZY_4?t=130
  10. Feb 8, 2023 at 8:31 AM
