Blown engine
Discussion in '3rd Gen Tundras (2022+)' started by northerntundra1, Oct 29, 2022.
  1. Jan 7, 2023 at 9:28 AM
    #121
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Well at least you have sense hummer
    I realy hope this plays out well for you in the end
    ATV25 likes this.
  2. Jan 7, 2023 at 11:10 AM
    #122
    moonrover
    moonrover New Member
    2022 Tundra SR5 TRD OR
    GL OP, if you do end up getting rid of your truck, have you thought about what would you go with? That is a crazy failure to happen and I am not sure I would trust a dealer putting back my pickup after that.
  3. Jan 7, 2023 at 12:43 PM
    #123
    northerntundra1
    northerntundra1 [OP] New Member
    alex
    2022 tundra
    I have a suspicion that most vehicles after 2018 are going to be problematic as emissions standards are way too strict now. I dont know if its that or the build quality going downhill due to covid but most of the people around me experiencing issues with their vehicles or equipment have the newest model year stuff. I may go for a tacoma or a chevy with the 5.3 that has cylinder deactivation
    moonrover[QUOTED] likes this.
  4. Jan 7, 2023 at 12:47 PM
    #124
    northerntundra1
    alex
    2022 tundra
    Although if they give me an extended warranty I may keep it and see how it goes. I'll have to have a chat with the toyota service manager about the oil though. I don't think a turbo charged engine should have 0w20 in it, like ever.
  5. Jan 7, 2023 at 12:52 PM
    #125
    Kap1
    Kap1 New Member
    San Francisco, CA
    Why not 0-20 oil? That's what they specify in the manual and they won't budge on that...
    =JSG= likes this.
  6. Jan 7, 2023 at 1:24 PM
    #126
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    The question is not so much the weight rating of the oil, but it’s viscosity index. I have been using synthetic oils in my vehicles since living in Fairbanks in the mid 70’s. After changing my oil in mid winter at -35F, the 10w30 came out of the can like honey. The next oil change I used Conoco DN600 10w30, the only synthetic I could find. It was essentially the same viscosity at -30F as at 300. Synthetics have a very high viscosity index, that’s why they a specified in most new vehicles because they can have a positive impact on fuel economy and have longer change intervals. The only trucks I never used synthetics in were my diesel trucks. The drain interval was such that it was just too expensive.
    Tom
  7. Jan 7, 2023 at 1:25 PM
    #127
    northerntundra1
    alex
    2022 tundra
    So I know personally of 3 other gen 3 tundras now that spun bearings. keep in mind I haven't been told at all what happened or what they are even guessing it could be. My personal experience has always been that spun bearings are usually heat related. Meaning my bearing overheated due to lack of oil delivery. Turbo charged applications produce a lot of heat. if you ever see guys slap a turbo on their engine They run thicker oil to account for the extra heat. take that into account and now also consider this is a pickup truck ment to pull a trailer or haul a skid on the back and actually work. it's going to get treated a bit harder than the same turbo 3.5 In an suv. The manufacturers oil standards are set for fuel economy and emissions. engine wear and longevity are really low on their list nowadays. this truck should be running 5w30 and have 7000km oil change intervals. Not 0w20 and 10000km. But ill just keep following their guidelines because that worked out so well for me the first time.
    JpHTX, AZBoatHauler and in_the_mud like this.
  8. Jan 7, 2023 at 1:52 PM
    #128
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    Totally agree.
  9. Jan 7, 2023 at 3:07 PM
    #129
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Boosted versions of Mustang go from recommended 5-30Wgt to 5-50wgt weight full synthetic. For sure, a lot of stress at those power levels and heat.
    Shark Bait and batman900 like this.
  10. Jan 7, 2023 at 6:09 PM
    #130
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    Knew this truck was going to be a gaggle phuck soon as I saw digi camo fender flares.
    How did they go from this
    To this
    Damn shame
    OnThaLake and Terndrerrr like this.
  11. Jan 7, 2023 at 7:55 PM
    #131
    Kap1
    Kap1 New Member
    San Francisco, CA
    :rant:
  12. Jan 14, 2023 at 10:14 AM
    #132
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I did the same, and then at 5k too and every 5k since. It's the easiest and least expensive way to be sure you give your motor a great start and solid break in, no matter what "recommended intervals" are
    TXBrit, Larly5000, Kap1 and 2 others like this.
  13. Jan 14, 2023 at 10:27 AM
    #133
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    I changed my break in oil at 1500 miles, I’m now at 2800 miles and so far so good, but I’m gonna drive it how I like and hope that it treats me well, I personally don’t see how a 0w20 oil is too blame, it does hold quite a bit of oil to account for the heat, but I’m not an engineer either
  14. Jan 14, 2023 at 2:10 PM
    #134
    blanchard7684
    blanchard7684 New Member
    Any further details?
    1 failed connecting rod bearing only?
  15. Feb 1, 2023 at 4:05 AM
    #135
    Tundra9271
    Tundra9271 New Member
    2023 Tundra SR5 4x4 DC Lunar Rock TRD Sport
    Reading about the engine seizing up, Toyota not knowing how much these Turbos consume oil, and the recommendations in this thread makes me slightly paranoid. I am planning to fly into a state and pick up my Tundra. It is about a 14 hour trip back to home, about ~1000 miles. Will the Tundra get too hot and burn through that oil more quickly if I try to make the trip in one shot without stopping (except for gas of of course).
  16. Feb 1, 2023 at 4:29 AM
    #136
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Look at the crank: every big end and main bearing location has turned blue.
    Crank is shot along with 66.67% of the connecting rods. Or it could be selective heat treatment: the rod caps aren't showing any color.
    It matters not... I'm de-rating the 3rd gen to "do not buy" status.
  17. Feb 1, 2023 at 4:49 AM
    #137
    blanchard7684
    I think it is heat treatment. Seen that color pattern many times in the counterweights. Good observation.
  18. Feb 1, 2023 at 5:27 AM
    #138
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Should we release the bees?
    hagrid[QUOTED] likes this.
  19. Feb 1, 2023 at 5:31 AM
    #139
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Deploy tickle-bees without delay, plz.
    Leo's first likes this.
  20. Feb 1, 2023 at 5:32 AM
    #140
    10TundraSR5
    Tennessee
  21. Feb 1, 2023 at 5:32 AM
    #141
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    The 3rd gen is great and everyone should own one…. Potential new truck owners should definitely consider a new tundra over all 3.0 duramax and 6.6 gas HDs in the next 3-5 years….
    :anonymous:
    ATV25 likes this.
  22. Feb 2, 2023 at 7:36 AM
    #142
    mass-hole
    mass-hole New Member
    Saw a great video on the updates to the LZ0 duramax vs the LM2. Its a pretty sweet engine.
  23. Feb 2, 2023 at 9:56 AM
    #143
    Kap1
    Kap1 New Member
    San Francisco, CA
    Here's one for you: https://youtube.com/watch?v=nBBUQJKTaiM&si=EnSIkaIECMiOmarE
    Henry1jg likes this.
  24. Feb 2, 2023 at 2:10 PM
    #144
    Tundra9271
    Wow! Everything explained in the first 5 minutes. I’ll watch the rest, but I’ll need to figure out the right plan for my 14 hour trip back home.
    thanks, Kap1, for digging that up and sharing!
    Update:
    I’m thinking about stopping at least an hour every 4 hours on the way from a 1000 mile trip. Would that be “babying” it enough during the break in period?
    Kap1[QUOTED] likes this.
  25. Feb 2, 2023 at 7:07 PM
    #145
    Kap1
    Kap1 New Member
    San Francisco, CA
    Yep yep, the car nut says not to drive it at same rates continously... Nor can you drive it too fast as it's not broken in yet.
    Good luck!
  26. Feb 2, 2023 at 7:13 PM
    #146
    Eddy20
    Eddy20 New Member
    IMO the 2021 are going to be worth big bucks going forward. Just like my raptor I sold to buy my Tundra; my Raptor was the last V-8 MY2014.
    IsaiahCanada likes this.
  27. Feb 2, 2023 at 7:45 PM
    #147
    Breathing Borla
    AZ
    not really, as gas prices stay high and the trend is more technologically, the appeal of 13 city , 17 highway won’t help
  28. Feb 2, 2023 at 7:56 PM
    #148
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Agree re gas prices - For some, time is more valuable than money. I'm happy to trade a few MPG for reliability.
    My F150 was in the shop 5 times over 5 years for problems. It also had an electrical gremlin that was never solved (dead battery 2-3x a year).
    My Ram 1500, 10 times in 2 years.
    Tundra - 0 (knock on wood)
    Really feel for this OP and the situation he's in. If God forbid my Tundra grenaded or was totaled, I have to decide between the 3rd gen Tundra, a used second gen, or a new domestic HD.
  29. Feb 2, 2023 at 8:07 PM
    #149
    Leo's first
    Groton ma
    Does the tt v6 get much better?
    I read a lot about 3rd gen owners complaining about mpg
  30. Feb 2, 2023 at 8:46 PM
    #150
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I hope you were joking, but in case you weren't... no.
    What I did with mine was take backroads that weren't busy, and constantly varied the throttle and speed. It's not very much fun. I did floor it a few times though after 500 miles, which was fun. It runs great, isn't noisy, gets great MPG (relatively) and doesn't use any oil, so I don't think I hurt it.
    Kap1 likes this.
