  1. Feb 2, 2023 at 11:29 AM
    centex
    centex New Member
    Best description ever.
  2. Feb 2, 2023 at 12:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    ~420 with a 32 gallon fill-up (when it says it is empty and time to refuel). There's 6 gallons of reserve in the 38 gallon tank.
    RobertD, PermaFrostTRD and the red like this.
  3. Feb 2, 2023 at 12:14 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Must be why I kind of enjoy my times in Austin...
    Yeah, it's not all good. And I don't actually live there. But I also don't actually live in Portland and there are places that I really enjoy and have a good time in Portland as well.
    It's all what you make of it...I've actually never been to a place that I didn't try to find at least something worth seeing or experiencing. New Orleans is probably the closest I've come to what I would consider a "scourge" when I visited, but even there I managed to have a good time.
  4. Feb 2, 2023 at 12:19 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Thanks!
  5. Feb 2, 2023 at 12:31 PM
    New Orleans is like a trashy hooker. But you already said that.
  6. Feb 2, 2023 at 12:40 PM
    Kung
    KG, VA
    I routinely get 480-500 or so, I tink.
  7. Feb 2, 2023 at 12:42 PM
    AZBoatHauler
    So.Arizona
    And @Azblue just booked his next trip.
  8. Feb 2, 2023 at 12:43 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Just start typing 'Keep Austin...' in your Google search bar and see how it auto-completes. Tells you all you need to know, and leaves the decision of good or bad to you.
    Definitely go.
    RainMan_PNW and Tripleconpanna like this.
  9. Feb 2, 2023 at 12:44 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    Bourbon blues on the street, loose and complete
    Under skies, so smokey blue green
    I can't forsake a dixie dead-shake
    So we danced the sidewalk clean
    My memory is muddy, what's this river that I'm in?
    New Orleans is sinking, man, and I don't wanna swim
  10. Feb 2, 2023 at 12:52 PM
    PermaFrostTRD
    Northern NY
    Agreed. I would say that just about every city in the country has run through the cycle once or at last has pockets of it that have, while other pockets may be back a few stages or more. Kind of makes the exploration fun, imo. Though, tents belong in the woods, not on concrete. So that's like final Boss Portland, aka Tacoma, WA.
  11. Feb 2, 2023 at 12:55 PM
    the red
    Epoxied a nut for the lower driver's grab handle bolt as it seems they stopped welding one in place for after 2013. I painted them a couple days back. Eventually want to do the rest and the headliner in black as well. Really appreciate those of you who let me know this can be retrofit. What have you guys done for this nut?
  12. Feb 2, 2023 at 1:00 PM
    centex
    centex New Member
    I’m at a 1/4 tank on my 38gal tank and I’ve gone almost 300 miles on it.
  13. Feb 2, 2023 at 1:27 PM
    Azblue
    The Dirty T ( ^_^)_且
    :anonymous:
  14. Feb 2, 2023 at 1:34 PM
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
    clip U style nut. like these
    https://files.ekmcdn.com/adl2013/im...h=9999&v=e04e0053-ad54-4eb8-b879-50859df20776
  15. Feb 2, 2023 at 2:14 PM
    bfunke
    bfunke Tundra Curmudgeon
    I used to like Austin for the music scene, bars on Sixth and Barton Springs/Zilker Park. Then the tech companies came from the Republik of Kalifornia creating traffic jams and expensive housing. That said Franklin’s BBQ is still one of my go to places.
  16. Feb 2, 2023 at 2:18 PM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    Urban wilderness… trd pro grille installed! Running boards installed! Done for a bit now until I get some Toyota LED headlights.. or Morimoto’s $$$$$
  17. Feb 2, 2023 at 2:23 PM
    Kajunxplorn
    Kajunxplorn New Member
    2021 Silver Limited CM TRDOR
    I finally had the lift and tires installed after purchasing the truck a year ago and the lift 10 months ago. I’m still debating on installing the CB+2 or purchasing the 1 inch block from Eibach to complete the lift. The truck looks so much better than the 32inch tires that came with it.
    superdenk, mcp, Toyotoholic and 11 others like this.
  18. Feb 2, 2023 at 2:46 PM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    What lift amount did you go with in the front?
  19. Feb 2, 2023 at 3:00 PM
    Kajunxplorn
    I did Eibach pro truck lift with it’s stock settings from them. I forgot to measure before and after, but I think it’s set at 2 inches. The rear suspension is stock for now with Eibach shocks. And, I went with 275/70 Wildpeaks.
    SR5style and RustyShackle323 like this.
  20. Feb 2, 2023 at 3:02 PM
    bfunke
    I like the look of the TRD Pro with silver sky
  21. Feb 2, 2023 at 3:10 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I’ve found tents on the concrete in every city I’ve been in since 2018. It’s not a problem anyone seems really dedicated to solving unfortunately. Not that there’s an easy and humane solution.
  22. Feb 2, 2023 at 3:11 PM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
    Me too!! Such a clean look!!
    Kajunxplorn likes this.
  23. Feb 2, 2023 at 3:22 PM
    Azblue
    Oh, there are easy ways. Some may not consider them "humane", but at this point IDGAF.
  24. Feb 2, 2023 at 4:30 PM
    Dsptundra
    Austin TX Area
    I moved from the Portland area to the Austin area. Austin is much better than Portland on many fronts. Portland lost its luster several years ago and is being run into the ground by the leadership.
  25. Feb 2, 2023 at 4:35 PM
    SR5style
    SR5style New Member
    2019 MGM SR5 4wd Crewmax
    Did you do the stage 1 or the stage 2?
  26. Feb 2, 2023 at 4:46 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Agee.
  27. Feb 2, 2023 at 4:51 PM
    Velocity72
    Upstate SC
    2021 Platinum
    In my experience, the Wildpeaks will do you proud. I’ve got 40k on mine and they look like they have 30 more to go.
  28. Feb 2, 2023 at 5:01 PM
    Kajunxplorn
    I read nothing but good things about them.
    I did the stage 2.
  29. Feb 2, 2023 at 5:59 PM
    centex
    centex New Member
    Austin is heading that way. Hopefully the new mayor isn’t such a POS as the last one. Used to be a fun town I never worried about walking around in. In the last 7 years we’ve had a friend murdered by the homeless and another attacked.
    Tundrastruck91 and trevorklat like this.
  30. Feb 2, 2023 at 6:01 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Got the wiring in place for my rack lights 88FD35D3-027D-409D-9968-057630D13B61.jpg8399FC0F-8E06-41FB-BBE9-0A91B585D550.jpg9278C74E-F743-486A-9345-977C5FD0039B.jpg
