Rear bumper shifted or hit and run?
Discussion in '2.5 Gen Tundras (2014-2021)' started by DvilleMafia, Apr 15, 2020.
  1. Apr 15, 2020 at 5:39 PM
    Ericsopa
    Ericsopa Old man and the sea
    Just what I thought, too. Looks like the bumper hit the body, scratched the paint, then sprung back out a little.
  2. Apr 15, 2020 at 5:42 PM
    linwozzle
    linwozzle New Member
    Linden
    2014 SW Tundra Platinum 4x4 CM
    Either someone hit you or you hit something. It doesn't look bad at all after pulling it
  3. Apr 15, 2020 at 5:54 PM
    Donn
    Donn New Member
    Donn
    Tundra 2017
    BDS LIFT ICON SUSPENSION
    Use a come along simple and easy fix
  4. Apr 15, 2020 at 5:55 PM
    sunnysideTRD
    sunnysideTRD New Member
    Sunny
    2019 Tundra TRD Pro Voodoo Blue
    Standard 2019 TRD Pro but will be a project car and add as I go
    yep, mine was same. easy fix..just pull it back into place
  5. Apr 15, 2020 at 6:47 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If your truck was black you could just smash the gas pedal from a stop and the bumper would correct itself.
    Science
    Tundyfundy and socaltundra951 like this.
  6. Apr 15, 2020 at 7:32 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    How did you adjust it? Mine is off too.
  7. Apr 15, 2020 at 9:10 PM
    15whtrd
    15whtrd Mr. Blonde
    Loosen all six bed bolts and it will float around. Just take measurements.
    Tundyfundy likes this.
  8. Apr 16, 2020 at 8:13 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Late to the party....
    my wife backed into my tundra’s rear bumper not long after I got it. After freaking out, I looked hard at the result.
    As noted by several, you can loosen the bolts under the bumper. That will allow quite a bit of articulation of the bumper ends. I was able to get mine back to straight and square easily. I had no paint damage. I did have to pull my driver side end off and use a body hammer to straighten a minor dent. I used a sand bag and gave it a few careful strikes and the dent all but disappeared.
  9. Feb 2, 2023 at 12:20 AM
    _steezysr5
    _steezysr5 New Member
    Instagram _steezyse Eibach pro lift stage 1 3.5/1.5 Rough country shims/block Methods nv305 double black 18x9 +25 Bfg ko2 35 12.5 Alpharex pro series headlights/taillights Lasfit ls plus series led Armordillo Hood Grille Insert with Led Lights Bakflip mx4 tri fold tonneau cover 5 inch iboard running board Pedal commander RCI Transmission and catalytic converter shield Nameplate overlays 5% tint all around Titan wheel spacer 1 inch Weather mats by 3dmatsusa Rydonair 7 inch Gplus third brake light Paint-matched hood bulge, grille surround, front and rear bumper overlays from Ecoological (midnight black metallic) Mbrp dual rear exit exhaust (mimics trd exhaust sound) yet to install, currently just a muffler delete
    Have had my truck for 6 months now and I just noticed it last week same issue but mines only come close to paint and doesn't look like it has been pushed up, yeah that long. gonna give this a try. I was hoping to find this thread when I searched I'm glad I did and glad you figured it out! though still, I'm curious to know if those 6 bolts precisely go in a hole in the frame how were able to pull it back into place? arent those connection points really tough to move? how much play does the bumper have to begin with that its able to be pushed back that much without anything being bent while secured on by 6 bolts? did you find anything else that got bent or misaligned other than pulling back the bumper away from the frame?
  10. Feb 2, 2023 at 9:23 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Bed is fine. I just need to adjust the bumper. I replaced a damaged end cap and have a bigger gap between it and the bed. At first I thought it might be the end cap itself but the plastic on top of the bumper looks perfect.
    15whtrd[QUOTED] likes this.
