General Supercharger Thread
  1. Jan 31, 2023 at 5:36 PM
    #5401
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I guess it all depends what gauge wire the stock wiring is, and from that you can look at some charts for the gauge and type of wire at a given voltage and determine the amp rating of the wire. If you used a voltage booster you could increase the voltage and thereby reduce the amp draw, but it’s probably cheaper to just run heavier gauge wire like @armyoffoo
    M3Tundra-JK likes this.
  2. Jan 31, 2023 at 5:38 PM
    #5402
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Third question, if you're overdrawing, wouldn't the fuse blow instead if the pump stop working for a moment??
    V10Ace likes this.
  3. Jan 31, 2023 at 5:43 PM
    #5403
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Yes, it should pop the fuse if that happens...but I suspect it's being limited by the voltage regulator to prevent that from happening. This isn't proven, just a thought, but it adjusts voltage to the pump based on engine load. I'm not sure if this is configurable in the tune...at least I never saw it.
    V10Ace and M3Tundra-JK[QUOTED] like this.
  4. Jan 31, 2023 at 5:45 PM
    #5404
    Silver17
    Eastern PA
    I was wondering if that fuel pump module could be part of the problem with the increased amp draw? My fuel pump fuse is 25 amp anyways though so the fuse shouldn’t be the issue.
  5. Jan 31, 2023 at 5:54 PM
    #5405
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    What are your plugs gapped at? I had issues issues with blowout when I moved to the 75mm. It feels similar to a fuel cut when you WOT. I had to gap them down to .021
    V10Ace[QUOTED] likes this.
  6. Jan 31, 2023 at 5:54 PM
    #5406
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Too many unknowns. Between that and the back-and-forth with PS on my system, I just bypassed the whole thing. Dedicated wiring was the easy part really, but getting it into the basket took a bit of work. I used a bulkhead fitting from Summit I believe, had to cut away plastic ribbing on the basket top to install the fitting flush with the top.
    You can see my hack job here:
    And top-side here:
    V10Ace and M3Tundra-JK like this.
  7. Jan 31, 2023 at 6:03 PM
    #5407
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Oem gap, they haven't been pulled. You're running the 450 fuel pump as well aren't you? Did you increase the circuit rating?
  8. Jan 31, 2023 at 6:10 PM
    #5408
    Vizsla
    Vizsla 2 = 2.5
    Don’t think it’s configurable in the tune. Fuel pump control unit maxes out at 90% duty cycle, and iirc that is 9.0v - 14.0v output, so agree with your suspicion.
    armyoffoo[QUOTED] likes this.
  9. Jan 31, 2023 at 6:13 PM
    #5409
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    I am but no I didn’t mess with the circuit at all. I previously had the pump that came with the harrop kit so idk if when I had the shop install that originally if they messed with the circuit rating. But if your plugs are gapped at .043 then that’s probably not enough because the IKH 24 come at .029 and that’s not enough for the 75mm. @Silver17 posted something that DAP put out that said he gaps at .020-.022 for 12psi and so I went to .021 and it fixed it
    HulkSmurf14 and V10Ace[QUOTED] like this.
  10. Jan 31, 2023 at 6:14 PM
    #5410
    armyoffoo
    armyoffoo Member
    Cypress, TX
    You should adjust the gap, it might not be able to jump under boost if it's too large, I have mine at .022.
    V10Ace[QUOTED] and HonorNotInner like this.
  11. Jan 31, 2023 at 6:15 PM
    #5411
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Thank you for the info. Not sure what psi I'll be at with the PS intake as we haven't been able to get into boost really. 12psi also?
    HulkSmurf14 likes this.
  12. Jan 31, 2023 at 6:18 PM
    #5412
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    I would think so or fairly close since I think we are pretty similar elevation.
  13. Jan 31, 2023 at 6:45 PM
    #5413
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Did you guys close up the gap on your oem plugs or go with Denso IKH?
  14. Jan 31, 2023 at 6:51 PM
    #5414
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    IKH. You’ll want a colder plug
  15. Jan 31, 2023 at 7:02 PM
    #5415
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Well.. I'm glad we didn't do any damage! The really fast cut out and back in totally makes sense to be a spark plug issue
  16. Jan 31, 2023 at 7:04 PM
    #5416
    M3Tundra-JK
    Scott
    2005 GX470
    An alternative if you want to play around are the plugs I've used, the Ruthenium HX forced induction specific plugs. A lot of us, including myself, on the Tacomaworld s/c thread run them. Not sure if anyone else here is. But I will be
    trddriver and V10Ace[QUOTED] like this.
  17. Jan 31, 2023 at 7:10 PM
    #5417
    M3Tundra-JK
    Scott
    2005 GX470
    But I think my bigger question would be, aren't the IKH plugs included in the supercharger fit kit? At least with the Magnusun they are
  18. Jan 31, 2023 at 7:13 PM
    #5418
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    No plugs included with the Harrop!
    M3Tundra-JK[QUOTED] likes this.
  19. Jan 31, 2023 at 7:20 PM
    #5419
    M3Tundra-JK
    Scott
    2005 GX470
    Intersting...that's good front page info right there! @snivilous
  20. Jan 31, 2023 at 7:22 PM
    #5420
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    I feel like an idiot considering that wasn't even a thought this whole time. :rofl:
  21. Jan 31, 2023 at 7:29 PM
    #5421
    snivilous
    SW UT
    300k+ Supercharged 2008
    Interesting. If you want I can
    Oooh definitely a good one since I always forget them! I need to make another big update with the last few pages of suggestions.
  22. Jan 31, 2023 at 7:41 PM
    #5422
    armyoffoo
    armyoffoo Member
    Cypress, TX
    More details on my setup:
    Two Walbro 450's using plug w/pigtail from installation kit, wiring from pigtail going through bulkhead fittings terminating in deutsch plugs. From there it's 10 Gauge TXL wiring to another deutsch plug in the engine bay, primary pump positive goes to a fused relay that activates with key-on via the same fuse tap as the intercooler pump, secondary pump positive goes to a fused relay that activates when a pressure switch sees 3 PSI of boost, both negatives and relay negatives terminate at inner fender.
    Pump with installation kit:
    https://walbrofuelpumps.com/walbro-...universal-e85-ethanol-ti-automotive.html.html
    Bulkhead fitting:
    https://www.amazon.com/ATL-Wire-Thru-Electrical-Bulkhead-standard/dp/B0057Y4BEK
    Relay and wiring:
    http://www.radiumauto.com/DIY-Fuel-Pump-Wiring-Kit-P368.aspx
    Pressure switch:
    http://www.radiumauto.com/Adjustable-Pressure-Switch-P921.aspx
    Stock fuel basket modified with dedicated -6AN to 3/8" hose barb for pumps and -6AN to 5/16" hose barb for return as well as two bulkhead fittings for wiring. I added heatshrink to the bulkhead fittings and potted with Toyota sealant to be sure no fuel got by. Probably overkill, but that's the way I do.
  23. Jan 31, 2023 at 8:04 PM
    #5423
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Work off that tuning bill...
    mZiggy, V10Ace and trddriver like this.
  24. Feb 1, 2023 at 2:34 AM
    #5424
    Silver17
    Eastern PA
    Prospeed and evidently Harrop recommend using the stock plugs for stage 1. DAP recommends IKH22 when using standard size pulleys and IKH24s using smaller pulleys. I ran stock on stage 1 and IKH24s on the 80mm pulley. I did not gap the 24s though.
    M3Tundra-JK, snivilous[OP] and V10Ace like this.
  25. Feb 1, 2023 at 3:44 AM
    #5425
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I ran the cooler plugs since untuned. still have the same plugs on the 80mm.
    I have not hit the 3k stutter thing. either I'm different or I still don't know how to run WOT.
    ___
    The bitch gets a new windshield today - Pasadena TX Tornado damage. yes, I was caught in it - within 50 yards.
    Dyno & gauges on Tuesday.
  26. Feb 1, 2023 at 8:26 AM
    #5426
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Stock Raptor R Dyno from Hennessey
  27. Feb 1, 2023 at 8:49 AM
    #5427
    ssmokedz
    Shelton CT
    I wonder what those new Raptor R's weigh.
  28. Feb 1, 2023 at 8:52 AM
    #5428
    ssmokedz
    Shelton CT
    Just looked it up. It's lighter than i thought. Looks to be around 6000 pounds.
    nobodyintexas and Silver17 like this.
  29. Feb 1, 2023 at 8:53 AM
    #5429
    Silver17
    Eastern PA
    All of this can be yours, for just 96 easy payments of $1,145.00
  30. Feb 1, 2023 at 8:55 AM
    #5430
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    If you can get one without a $20k+ adm
