Oil Change or not?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by bstringrandy, Jan 31, 2023.
  1. Jan 31, 2023 at 7:14 PM
    bstringrandy
    bstringrandy [OP] New Member
    Randy
    Middleburg, FL
    2021 Tundra TRD Pro
    I need some opinions. My 21 TRD Pro had 12,400 miles on it when I bought it in December 2021. The dealer changed the oil and filter with 0W-20 Mobil One right before I bought it. Now it’s a little over a year later and I have 15,700 miles on it. I put 3,300 miles on it in a year. At this rate, it will be April or May before I get to the recommended 17,400 oil change mileage. I plan on using a local Toyota dealership that I’ve always had good luck with. I know it’s not relevant, but the oil on the dip stick still looks brand new.
    Question, do I change the oil immediately or can I wait until I get closer to the mileage?
    Thanks in advance for the inputs!! :)
    Update: Appointment scheduled! Thanks!! :thumbsup:
  2. Jan 31, 2023 at 8:01 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I’d change it.
    bfunke, GODZILLA, snivilous and 6 others like this.
  3. Jan 31, 2023 at 8:03 PM
    18" TRD Off Road Wheels
    Oil is cheap. Engines aren't. When in doubt, change the oil.
  4. Jan 31, 2023 at 8:41 PM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    The oil is synthetic; it does not spoil in a year. I’d wait till at least 5K.
    bstringrandy[OP] likes this.
  5. Jan 31, 2023 at 8:57 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    5k or every 6 months if you want it to last. Short trips end up with oil accumulating water and gasoline.
  6. Jan 31, 2023 at 9:02 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    If it was me, I would change it.
  7. Jan 31, 2023 at 10:15 PM
    TheBear
    TheBear New Member
    Harry
    New Mexico
    2021 Tundra Limited
    Change it. I do every 5000 or six months, but I tow a trailer. Like some said, oil is cheap but engines aren’t. Do the oil change yourself save money.
  8. Jan 31, 2023 at 11:08 PM
    Rangers
    Rangers New Member
    Joe
    Oklahoma
    2017 Bad Barcelona TRD Pro
    TRD sway bar
    Change it and let the dealer do it. If you decide to get rid of the truck it will look good on the car fax.
  9. Jan 31, 2023 at 11:43 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Change it. It's relatively cheap insurance against an engine failure.
  10. Feb 1, 2023 at 12:41 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Oil Changes: 5,000 miles or 6 months (whichever comes first)
    Transmission Fluid: 60,000 miles or 6 years (Drain and Fill NOT Flush) Toyota ATF WS
    Coolant: 50,000 miles or 5 years (OE Pink 50/50 Super Long Life)
    Differential and Transfer Case: 30,000 miles ***Especially the first 30,000***
    Brake Fluid: Every 3 to 5 years
    Power Steering Fluid: Every 50-70,000 miles (do not use Transmission Fluid)
    Spark Plugs: Every 120,000 miles *** use OE plugs ***
  11. Feb 1, 2023 at 5:40 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Depends a lot on driving conditions. 60k miles of highway in northern Maine - sounds about right. 60k in Houston traffic jerking - over the roof.
    ATF supplies friction modifiers that coat clutch packs. Modifiers wear out naturally with every clutch pack engagement/disengagement. When ATF runs out of modifiers, the wear is accelerated drastically. Clutch pack wear by-products kill valve body.
    Every 2 years, especially in humid climate.
  12. Feb 1, 2023 at 5:45 AM
    Taco-Spike
    Two Trucks
    Brought to you by NIKE
  13. Feb 1, 2023 at 6:48 AM
    bstringrandy
    Randy
    Middleburg, FL
    2021 Tundra TRD Pro
    :thumbsup: Thanks for the inputs! I’ve scheduled an appointment for the normal 15k service plus oil/filter change. I used to be more religious about vehicle maintenance. Before I retired a couple of years ago, I was commuting and always met the mileage goals before the time expired. I learned to take care of your machinery at an early age from my dad. He was a U.S. Navy retired Chief Engineman who worked on everything from small engines to marine diesels that you could walk into.
    mibpf, GODZILLA and Tripleconpanna like this.
  14. Feb 3, 2023 at 4:32 PM
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    If you have documentation that the dealer changed the oil. Why change it so early? Sound like a waste.
    Second thought. As someone posted above. Have the dealer change the oil again. Will show up on the history report.
  15. Feb 12, 2023 at 7:18 AM
    bstringrandy
    Randy
    Middleburg, FL
    2021 Tundra TRD Pro
    Yep. I also want to have my local dealer go through and verify that all recalls are up to date. :)
    JJtruckon likes this.
