1st Gen ABS Brake Line Help!
Discussion in '1st Gen Tundras (2000-2006)' started by evanhmn, Jan 31, 2023.
  1. Jan 31, 2023 at 11:07 AM
    evanhmn
    evanhmn [OP] mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    Hi all!
    I finally installed new UCAs, SPC :), and the installation process went beautifully until I stripped the head off of the bolt holding the ABS Line to the UCA. First, it was not tight, then a quarter turn later the head was gone. Currently, it is being held to the control arm with about 4 zip ties as I just drive to and from work (~2 miles). However, I want to find a way to fix this. I have had to drill out 10 too many stripped bolts off this hunk of metal, so any alternatives would be greatly appreciated.
  2. Jan 31, 2023 at 11:22 AM
    Do you have a tap and die set?
    evanhmn[OP] likes this.
  3. Jan 31, 2023 at 11:23 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I did the same thing about a year ago. I put a stainless steel zip tie around it like you've done there, with the intention of coming back to drill and tap the original mounting spot. I'm sure I'll get around to it one of these days but so far it hasn't failed me.
    Actually, mine broke off on the spindle but the same idea...
  4. Jan 31, 2023 at 11:27 AM
    evanhmn
    State of Taxes
    I do not, however, my dad probably does with his 20-year garage collection of tools and rubbish. So just make a new thread on the control arm? Drilling, screwing and deleting parts of the engineering on my truck/truck parts makes me anxious, but I suppose one itsy bitsy hole wont hurt.
  5. Jan 31, 2023 at 11:35 AM
    You don't need to drill anything, really. You may just be able to re-tap it to the original OEM thread.
    If not, go to the next logical thread upward (even if it means moving up one metric size) and install the proper bolt. Easy peasy. You may want to do the other side the same, even though it's not busted.
    Just make sure whichever tap you find to use, that it's not to large for the bracket. Been there, done that. If it is, a uni-bit to open it up works wonders.
    Next time, less ugga-duggas, and use a light threadlock like Permatex Blue if you're worried about things backing out.
    evanhmn[QUOTED][OP] likes this.
  6. Jan 31, 2023 at 11:53 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Those are SPC arms. They should already have a pre-tapped hole for the ABS buuuullllshhiiitttt. I would just get a new bolt from any hardware store. It should be an M6x1.0 or an M8x1.25.
  7. Jan 31, 2023 at 12:11 PM
    evanhmn
    State of Taxes
    Yes, it does have a pre-tapped hole, but that hole is filled with the bolt body of the bolt I stripped the head off of.
  8. Jan 31, 2023 at 12:19 PM
    Ah. I must've mistaken you above. You stripped the head off the bolt. Head is rounded, or head snapped off? I thought you were saying you cinched the bolt down, and it started spinning freely.
  9. Jan 31, 2023 at 12:21 PM
    Since I'm bouncing for a bit, if the head is just rounded and a pair of vice grips locked down on it hard won't work, go on scAmazon and buy a RocketSocket kit.
    Avoid the generics. Watch the ProjectFarm videos on extractions for details on the kits scAmazon has.
  10. Jan 31, 2023 at 12:21 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Ah, I see. You'll have to extract it if you wanna use it.
  11. Feb 9, 2023 at 9:59 AM
    evanhmn
    State of Taxes
    So I went ahead and got a set of Ez-Outs from the hardware store, drilled down a bit into the threaded bolt, tapped the Ez-Out in, gave it a twist and the bolt screwed right out. Happy Yappy! Thanks all for the help.
    shifty` likes this.
