Ride quality of 20 in. SL tires vs 18 in. E rated
Discussion in 'Wheels & Tires' started by IowaGuy, Jan 28, 2023.
  1. Jan 28, 2023 at 7:39 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I currently have 275/7018's in E rating and Billstein 5100's with 1.6 up front. Would 20 inch rims with an SL tire ride better or about the same? I would be giving up the heavy sidewall but also loosing some of the cushion from 18 to 20.
  2. Jan 28, 2023 at 8:02 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    My P rated tires on 20s ride significantly softer than my Dad’s truck on E rated 18s. He does a lot of towing on gravel roads and that’s the only way to stop from getting flats all the time. The extra preload on the 5100s for the lift will also makes things considerably stiffer.
  3. Jan 28, 2023 at 8:02 PM
    ETX41
    ETX41 New Member
    I’ll say this I went from sl tires on my wife’s 4Runner to e rated 10 play BFG All terrains and I literally cannot tell the difference! Didn’t even lose any MPGs. Matter of fact gas mileage is even a little better.
  4. Jan 30, 2023 at 8:53 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Buy a lottery ticket if those tires are the same size as the SL set. Your results are the opposite of anyone else that has reported, as well as physics.
    Just busting your balls. Ride quality is subjective, so that could go either way.
  5. Jan 30, 2023 at 9:45 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I get better MPG with 35x13 E rated ATs than the crap Bridgestones that Toyota put on my truck. I always get a lot of grief when I mention that...
    Tires with a lower load rating and lighter construction should ride better and get better MPG (all else being equal), but construction details and rubber compounds can make a bigger difference. My ATs do not ride softer, FWIW... but I prefer how they feel.
    Lower profile tires will not ride rougher in general, but you have a greater chance of rim strike. MPGs aren't hurt by lower profile either, actually there is a small benefit.
