Latest rattle in my dash was the passenger side air duct.
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Jan 26, 2023.
  1. Jan 26, 2023 at 5:17 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I finally took off the trim cover between the glove box and the top of the dash that the passenger side air vent is attached to. I felt around in there and found the air duct was rattling and hitting the dash. I shoved some foam between the duct and the dash and it all seems good now. I am the OCD rattle and noise king and this one was driving me bonkers to where I was looking for it every evening after work. Hopefully this helps someone else.
  2. Jan 26, 2023 at 5:23 PM
    Rocko9999
    Rocko9999 New Member
    Good job in finding it. How hard was it to remove the panel?
  3. Jan 26, 2023 at 5:39 PM
    IowaGuy
    In Process
    The piece popped off with a little force. I used a plastic trim remover and started on the vent end by the door. The vent with the louvers comes off with the piece.
    Rocko9999[QUOTED] likes this.
  4. Jan 26, 2023 at 5:52 PM
    I have a rattle on my driver's side. It sound like it's near the dash speaker. Any ideas?
  5. Jan 26, 2023 at 6:34 PM
    Kung
    KG, VA
    Could be the dash speaker cover itself. Mine is rattling like crazy when it's cold...but if my son merely applies a bit of force to the dash speaker cover, it stops. Fix will likely be to buy a new dash speaker cover for dirt cheap. LOL
  6. Jan 26, 2023 at 6:39 PM
    It's tight. It almost sounds like it's down below the speaker. I can't close to the dash to listen for it when I'm driving lol.
  7. Jan 27, 2023 at 3:16 AM
    IowaGuy
    In Process
    My dash tray cover was vibrating a bit. It is the little plastic type insert that covers the center tray in the dash. I used some double sided gorilla tape to hold it down on the edges. Yours might not have that with the speaker?
    I usually end up tapping in the plastics everywhere to try and find noises. Most of them come from loose trim pieces and noises can really act like a ventriloquist in the cab. My seatbelt take up pieces on the center pilar were really loose and were one source. The pillars on each side of the dash are also notoriously rattley ( new word).
    1lowlife likes this.
  8. Jan 27, 2023 at 8:38 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Glad you found it and didn't need to take it in, lol.
  9. Jan 27, 2023 at 8:47 AM
    Rocko9999
    Pull the cover, place felt tape on all plastic/plastic connections. Put the cover back.
    Kung[QUOTED] likes this.
  10. Jan 27, 2023 at 9:15 AM
    pursuit2550
    pursuit2550 New Member
    My truck always gets squeaks during winter. Luckily, it’s only cold in S.Fl like a week in the whole year.
  11. Jan 27, 2023 at 9:27 AM
    Taco-Spike
    Two Trucks
    That's where it is on my Tacoma.
  12. Jan 27, 2023 at 12:43 PM
    IowaGuy
    In Process
    Yup, that would be me. My wife snoring at night turns me into a crazy person!
    sask3m[QUOTED] likes this.
  13. Jan 28, 2023 at 8:09 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I'm the same way, that's why I thought the joke was so funny, lol.
  14. Jan 28, 2023 at 10:48 AM
    Trentimus
    Trentimus New Member
    Trent
    2019 Tundra Off Road
    Nfab bars, undercover armor cover, hottails
    Always start by tightening the firewall cover in your engine bay.
  15. Jan 28, 2023 at 12:45 PM
    I'll mess with it after I'm done with my current projects in work. I can duplicate it my pushing down on the dash in the corner where it meets the bottom of the A pillar.
  16. Jan 29, 2023 at 8:30 AM
    IowaGuy
    In Process
    What are you calling the firewall cover?
  17. Jan 29, 2023 at 9:47 AM
    Trentimus
    Trent
    Good point not sure I am right on that description. This thing is held in by screws with a Phillips head tightening these a bit, 99% of my dash rattles went away.
    A guy posted about it on Reddit one night, I did it and it worked brilliantly.
    IowaGuy[QUOTED][OP] likes this.
  18. Jan 29, 2023 at 10:03 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    I found a thread the other day mentioning passenger side rattle, but I can't find it. They mentioned a bolt behind the glovebox being loose could potentially be a problem. I took mine apart, but it was tight, so I'm continuing the hunt.
    I'm thinking it may be the fuses in the kickplate for my tailgate lock. After reassembly (and putting some tape around one of the two fuse holders) it seems to be a bit better. I too suffer from the rattle though, and it drives me nuts. Mines a vibration that occurs at certain RPMs.
  19. Jan 29, 2023 at 12:26 PM
    IowaGuy
    In Process
    I am not finding and screws in mine but instead it has metal clips. A while back I took it off to put the hardware screen on the vents for mouse mitigation. Today I went and tightened things up a bit as the passenger side near the hood hinge was a bit loose and didnt pass the tap test. I put a bolt in the end hole vs the plastic push pin.
    The filter vent cover in the glove box was also making a bit of a rattle and I ended up putting some adhesive backed rubber over it.
    Trentimus[QUOTED] likes this.
