TRD rims 17 on first gen
Discussion in '1st Gen Tundras (2000-2006)' started by Spread5150, Jan 28, 2023.
  1. Jan 28, 2023 at 7:26 AM
    Spread5150
    Spread5150 [OP] New Member
    Dave
    2000 Tundra 4x4 SR5 V8 2019 Tundra TRD Pro 1994 Toyota Pickup 4x4
    I have 2000 4x4 SR5 access cab. Made some changes to the ride with a 2.5 lift/jba arms in the front a block in the rear.
    I am looking at putting some TRD pro wheels on a this setup. 17s from a new Tacoma /4Runner.
    I read through a lot of threads on the matter and I do know they fit but the back spacing is a little funky.
    Those that have them from what I can tell are pretty conservative on the tire size but then they don’t have the lift.
    Well I found a set that has
    34/10.5./17 tires
    Any idea if these would fit/not rub ?
  2. Jan 28, 2023 at 7:29 AM
    Spread5150
    Dave
    These are the wheels in question
  3. Jan 28, 2023 at 7:58 AM
    Spread5150
    Dave
    This is how it currently sits on 265/65/16
    mcharfauros likes this.
  4. Jan 28, 2023 at 11:58 AM
    I'm on 33x10.5x16 with about 2.5-3" lift and it only rubs turning left through bumps, and that's only because my caster is off. I'd so go for it and trim/hammer what you need.
  5. Jan 28, 2023 at 12:03 PM
    Spread5150
    Dave
    Man thanks for the reply. What rims are you rocking and or what’s the backspacing
  6. Jan 28, 2023 at 6:48 PM
    Casper421
    In the woods
    06 DC
    This is an 03 sequoia with 17” TRD wheels and worn down 285/70r17’s. It has 3ish inch lift front and rear but does have wheel spacers. We’re gonna test fit some 35/12.50’s but I think they’ll rub the pinch a ton. He’ll probably end up with 285/75’s like me.
    The 34/10.5 shouldn’t come close to the uca. It might rub some on the pinch weld and front bumper. Depends on how much you’re willing to cut and hammer.
    abcinv likes this.
  7. Jan 28, 2023 at 7:38 PM
    Spread5150
    Dave
    The UCA is all I’m really worried about. I don’t have a stock front bumper. Lots of room on the front end and of course turning I worry. Willing to lose the mud flaps.
    Dont want to get into wheel spacers
  8. Jan 28, 2023 at 11:13 PM
    I'm on stock wheels.
    abcinv likes this.
  9. Jan 29, 2023 at 8:35 AM
    Spread5150
    Dave
    It looks really good. I think w the offset of the rims in question I might have issues without a spacer
