Machinery restoration
Discussion in 'Sports, Hobbies & Interests' started by Sumo91, Jan 27, 2023.
  1. Jan 27, 2023 at 6:29 AM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Anyone here into machinery and tool restoration?
    I've been slowly building my collection of machines and tools over the years, and I like taking old machines and bringing them back to life. I'm not an expert, and by no means am I putting out museum quality pieces.
    Last year I restored a 1954 Delta Rockwell drill press, and right now I'm working on a 1943 Hendey lathe.
    Will update later this evening, gonna be busy for most the day.
  2. Jan 28, 2023 at 2:31 PM
    Sumo91
    TN
    Here is my 1954 17in Delta Rockwell drill press. I picked it up for $100, and have about $180 of materials into it between a new motor, paint, a couple parts, etc.
  3. Jan 28, 2023 at 3:07 PM
    tommyboyrn
    tommyboyrn New Member
    Tom
    2021 Tundra 1794
    awesome job!!!
    2mchfun and Sumo91[OP] like this.
  4. Jan 28, 2023 at 3:42 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Awesome job. Looks great!
  5. Feb 3, 2023 at 6:58 AM
    Sumo91
    TN
    Progress on the lathe is coming along great. Got the final (3rd) coat of paint on all the small parts laying out yesterday, so about 85% of the lathe is painted and ready to be put back together.
    Here is a bunch of random photos, in no particular order. Just something to show the progress I've been making. If you have any questions about anything feel free to ask.
    20220301_123800.jpg 20230128_184105.jpg 20230130_161824.jpg 20230126_144931.jpg 20230119_165439.jpg 20230109_141921.jpg 20230112_161442.jpg 20230112_182253.jpg 20230112_182259.jpg 20230124_171535.jpg 20230125_165455.jpg 20230130_152524.jpg 20230130_152540.jpg
    FrenchToasty and 2mchfun like this.
  6. Feb 3, 2023 at 7:01 AM
    Outbound
    Aaron
    Northern Alberta
    Nice work! I enjoy watching the old become new again. They don't build tools and machinery like they used to.
    FrenchToasty, 2mchfun and Sumo91[OP] like this.
  7. Feb 3, 2023 at 7:05 AM
    Sumo91
    TN
    You are correct about that. This beast weighs close to 3000lbs. It was bought and owed by the USAF. I was able to get the original info on the purchase order of this lathe. I'll copy and paste it shortly.
    2mchfun and Outbound[QUOTED] like this.
  8. Feb 3, 2023 at 7:06 AM
    Sumo91
    TN
    Hendey lathe No.35392, a 12 x 30, Geared Head model was completed on July 30, 1943. The following information was taken from the original
    Order Form. Information in parenthesis is my addendum.
    Date Ordered: May 30, 1942
    Date Started: September 9, 1942
    Sold to: Finance Officer, Wright Field, Dayton, Ohio
    Ship to: Depot Supply Officer, Army Air Corps Storage Depot, 900 South Broadway, Denver, Colorado
    Wanted: Urgency 328
    Via: Government Bill of Lading
    TO BE INSPECTED BY AIR CORPS
    Description: 12" x 30" - 12 Speed Geared head Lathe CR (Compound Rest) - To swing 14-1/2" (Raised Swing model)
    Oil Pan
    Regular Equipment (as shown in catalog)
    Timken roller bearings on main spindle - Multiple splined shafts
    Taper Spindle Nose (L1)
    Spindle Speeds - 19 to 598 R.P.M.
    High speed reversing Mechanism
    New Style follow Rest (Bridge Type)
    Taper Attachment
    Furnish and Fit 10" 4 jaw independent chuck for direct mounting on #1 Taper spindle Nose
    Drawing-in Attachment and set of 15 #6 Collets from 1/8" to 1" inclusive by 16ths complete with Cabinet (No.68)
    Arranged for vee belt connected motor drive with motor in cabinet leg
    Furnish and fit ball bearing motor, 3HP (changed to 5HP), 220 volts, 3 phase, 60 cycles, 1200 RPM, frame 254
    (changed to 284), together with reversing magnetic starter and push button stations
    There are very few Patterns, Castings or Repair Parts left in inventory for this lathe, but all of the original drawings are still in
    the files, so parts can be made if required.
    FrenchToasty, 2mchfun and Outbound like this.
  9. Feb 3, 2023 at 7:37 AM
    2mchfun
    Good stuff you have going on! You probably already know, but if used for production, the bed rails on the lathe may need to visit a precision grinding service such as Daniluk corp. prior to assembly if you are wanting to do precision work with it. Kinda curious now, do you know how to carbide scrape by hand?
    Sumo91[OP] likes this.
  10. Feb 3, 2023 at 7:53 AM
    Sumo91
    TN
    The bed won't be getting a re grind, I've priced it and its way out of budget. The ways do have some wear, but it shouldn't be anything that will be detrimental to any parts I plan on producing. Everyone has told me these Hendeys can make really precision parts even if they're worn out. Once it's complete and running, I'll start scraping the bed a little at a time. This machine won't see a ton of use, but will be very useful when needed.
    2mchfun[QUOTED] likes this.
