In Need of Opinion
Discussion in 'General Tundra Discussion' started by Gtoairboat1963, Jan 26, 2023.
  1. Jan 26, 2023 at 9:13 PM
    Gtoairboat1963
    Gtoairboat1963 [OP] New Member
    Kerry
    2002 Toyota Tundra
    New to this forum, I have a 2002 tundra V6, anyway, I pulled a misfire code on #4 cylinder about 2 months ago, after changing all the plugs and plug wires, code went away, running great. Here’s my question…
    when the motors cold, it fires right up, when warm it seems to take a few ignitions strokes to fire. Any and all suggestions will be greatly appreciated-KO
  2. Jan 26, 2023 at 9:25 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    1- change the title. "Help", "Need help", and other nondescriptive "help" titles are reserved for people that need help such as stuck/broke down/wrecked in remote areas without assistance close by or a means to self recover.
    2- when you crank it when warm, does it crank at normal speed, or is it slower than cold cranking?
    gosolo likes this.
  3. Jan 26, 2023 at 9:29 PM
    Sunnier
    Sunny
    San Diego, CA
    Yes, please edit your title so people know it’s not an S.O.S. (you’re not stranded and gonna die if we don’t help you move your truck off the levy).
    gosolo likes this.
  4. Jan 27, 2023 at 6:38 AM
    Gtoairboat1963
    Kerry
    2002 Toyota Tundra
    Windsor, I have made changes to the title, in answer to your question, no it cranks at normal speed, sometimes fires right up, other times it takes a bit, but when it fires it runs fine. It almost feels like a fuel issue
    Windsor and GODZILLA like this.
  5. Jan 27, 2023 at 7:13 AM
    NCrunner2012
    NCrunner2012 New Member
    Steven
    2007 Tundra Limited 4x4
    I've experienced this with my 4.7 4runner. I would look to the fuel system. When was the last time the fuel filter was changed? What is the fuel pressure?
    For me it ended up being low fuel pressure and a new pump solved my issue.
  6. Jan 27, 2023 at 8:08 AM
    Gtoairboat1963
    Kerry
    2002 Toyota Tundra
    Thank you, the filter is where I will go next
  7. Jan 27, 2023 at 2:27 PM
    Windsor
    Homeless in Oregon
    Some.
    You may be bleeding off pressure. I would start by doing a pressure test.
  8. Jan 27, 2023 at 6:55 PM
    Gtoairboat1963
    Kerry
    2002 Toyota Tundra
