Help identifying part
Discussion in '1st Gen Tundras (2000-2006)' started by 05 tundra ky, Jan 27, 2023.
  1. Jan 27, 2023 at 9:37 AM
    05 tundra ky
    05 tundra ky [OP] New Member
    05 Toyota Tundra SR5 double cab 4x4
    I have a 2005 Toyota tundra double cab SR5 4x4 that I’m working on. I’ve looked on every engine diagram that I can find and I cannot find what these two houses are called. Both hoses have oil seeping out of them slowly. On top of the hoses it has two caps that go over them. I’m trying to find out what they are called so that I can get them ordered and replace it myself. Here’s a couple pictures That I hope can help anybody to identify what this is. The two hoses that I’m trying to identify have red circle around them. They go down towards the bottom of the engine, but I cannot tell if they go into the side of the engine or into the oil pan.
  2. Jan 27, 2023 at 9:41 AM
    Interesting. I thought those lines had no particular purpose as I've never seen anything documented about them myself.
  3. Jan 27, 2023 at 9:42 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I think one of em is the front diff vent.
    KNABORES and bfunke like this.
  4. Jan 27, 2023 at 9:42 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    These should be breathers for the front diff and ADD. Did you service either of them recently or add fluid?
  5. Jan 27, 2023 at 9:43 AM
    Yup. Breather hoses for your 4WD. Maybe your diff is overfilled?
    1lowlife likes this.
  6. Jan 27, 2023 at 9:43 AM
    Damn guys, we're really on top of this one eh? :rofl:
    3 posts basically at the same time, seconds apart.
    PS - welcome to the forum. Another KY member. I love the jelly over there! :bananadance:
    tvpierce and 1lowlife like this.
  7. Jan 27, 2023 at 10:31 AM
    05 tundra ky
    Des2mtn: I have not service my front diff and ADD. My last oil change I saw in the two hoses leaking.
  8. Jan 27, 2023 at 10:32 AM
    05 tundra ky
    Appreciate everybody responding so quickly. And thanks for the help.
  9. Jan 27, 2023 at 11:04 AM
    I would recommend gently pulling on the metal end of those. They will pull out of the rubber tube they're in. Then you can clean them up really good and put them back. I did this to mine.
  10. Jan 27, 2023 at 11:14 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    What them all said
    Should be total of 4….
    des2mtn, digitalferg and shifty` like this.
  11. Jan 27, 2023 at 8:00 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Seems like the rest here have got you lined out. What part of KY are you in? Don't have many first gen guys from KY on here.
  12. Jan 28, 2023 at 9:18 AM
    05 tundra ky
    Nickname Middletown/ J-town
  13. Jan 28, 2023 at 9:42 AM
    NickB_01TRD
    KY
    That's about an hour away. I'm from Etown.
  14. Mar 4, 2023 at 5:19 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Can someone educate me as to what the A.D.D is?
  15. Mar 4, 2023 at 5:46 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    when the t-case engages and starts spinning the the front driveshaft the passenger side axle is disconnected, and the diff can spin freely because its an open diff. The add engages the pass axle so the front diff can do work.
    i'm not positive, but i think the add is there so the tcase can shift on the fly without getting into a bind and when the truck is in 2wd it doesnt waste energy spinning the front driveshaft and diff.
    DarkMint, FirstGenVol and des2mtn like this.
  16. Mar 4, 2023 at 6:07 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    For me it means I don't have to get out of my truck to lock/unlock fnt differential, I get to use the 2wd/4hi button.
    A.D.D. = Automatic Disconnecting Differential
