Tow Mater
Discussion in '2.5 Gen Builds (2014-2021)' started by Mater, Apr 24, 2020.
  1. Jan 26, 2023 at 7:03 PM
    #151
    Mater
    Mater [OP] New Member
    SD
    2016 MGM Platinum
    Had a little bit of an issue with the weboost bouncing around up there.
    https://youtube.com/shorts/hFOjDWw_JZQ?feature=share
    I half expected this to happen given its position and orientation. The play doesn’t seem to be coming from the plastic gears as I expected but from something inside the housing. Also doesn’t help that it’s situated right above the fairing so any wind coming over gets directed right at it. This was the solution I came up with and it seems to have worked. Zero movement in the stowed position at 75. The antenna wiggles a tiny bit (you can wiggle by hand) in the upright position but I’m confident that has to do with a tiny bit of play between the threaded part of the shaft and where the nut bottoms out. I thought I had put enough washers on there to take up the slack but didn’t. Didn’t feel like pulling the whole cable back through the nut and motor unit just to gain another 1/16th of an inch.
    F5C4C30C-3BB0-4036-BECF-B4FB26C60694.jpg 5B1FF46D-57A3-44F5-8345-13609385E575.jpg
  2. Feb 3, 2023 at 10:14 PM
    #152
    Mater
    SD
    2016 MGM Platinum
    Got my front license plate mounted today.
    Probably should have just left it off. Originally tried an M5 rivnut but it wouldn’t hold. So mistakenly went with the old bolt and nyloc route. After getting the first bolt started there was no turning back or I was living with a dangling license plate. You can see from the first photo that I dropped two washers and a nyloc. From the second photo you can see on the far left how rounded over my winch mounting bolts are (given the length of supplied warn bolts they couldn’t make the turn into the hole without help from a BFH). In the back you can see the remnants of black gorilla tape that held the top left license plate M4 nut and washer. Took me a good 25 mins to get 7mm wrench free from the tape. Got two on and called it good.
    Two takeaways from today. 1) If I ever need to service my winch those holes will be plasma’ed and made bigger to easily get those bolts out and 2) if I were to win the lottery I would have a nut and bolt supplier show up weekly to restock so I always have the proper nut/bolt for the job. That.. in addition to having a new pair of socks every day. 7C5545A4-2264-4BB2-B0BA-FF02147F6192.jpg2F00B99F-DDDD-4062-A619-CECF0732F6B4.jpg
  3. Feb 8, 2023 at 12:49 PM
    #153
    Mater
    SD
    2016 MGM Platinum
    Spent my lunch break in the parking lot of an industrial hardware store getting the proper hardware and raising the fridge slide. Something I didn’t account for was the aluminum supports bending around the bed ridges when everything was tightened down. Everything seems pretty tight and secure but I’m going to keep an eye on it.
    25DE78D3-5010-4B91-8B49-061AE9AECE07.jpg 67530BB7-4BDB-4CD7-B9AC-719E9D9BE4D0.jpg
    haven’t tested (or measured) to see if my fridge will clear the cover or if the slide will clear the MH but hoping it will on both accounts.
    In other news, my 2 y/o daughter walked into my bumper last night. Luckily, there was no damage to the bumper. Daughter is ok, got a little bump on her head and tiny cut. She’s tough; she’ll be alright.
    In all seriousness though, I did have that concern when installing my bumper. It sits proud of the fenders and obviously the tow hooks protrude out too. Will have to have a chat with the kids today about it. Had an incident when I was a kid where my cousin did something similar and split his hand completely open on a bumper.
    HF small pelican case should be arriving today so I can install my water pump into it. Here are the parts that have arrived thus far for my hot shower system. Need Ironman to have a sale so I can purchase my water tank.5FB6F3EA-062B-4AA2-8F2C-687EDE4ABADD.jpg9D9540AC-722F-4582-AF79-D85BD25106CF.jpg20CE3DFF-3CC2-456B-89DE-470232015E76.jpg
    JCBerb, bulldog93, SAGE63 and 3 others like this.
  4. Feb 8, 2023 at 3:14 PM
    #154
    SAGE63
    San Diego County
    How many gallons is your water tank going to be?
    Do you have a mount for the small lp tank?
    JCBerb and Mater[QUOTED][OP] like this.
  5. Feb 8, 2023 at 3:48 PM
    #155
    Mater
    SD
    2016 MGM Platinum
    13g’s. And thanks for asking this. Logged onto Ironman and saw it was on sale. Picked it up!
    and just going to mount a quick fist to the bed wall currently is my plan. We’ll see how well it holds. Can’t remember if it was @des2mtn or someone else who suggested this.
    You have any suggestions for a mount @SAGE63
    bulldog93, Wallygator and des2mtn like this.
  6. Feb 8, 2023 at 3:51 PM
    #156
    SAGE63
    San Diego County
    no... still looking for a rack bracket to mount mine
    Mater[OP] likes this.
  7. Feb 8, 2023 at 3:52 PM
    #157
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I haven't used Quick Fists, but I've had this PowerTank mount bookmarked for awhile https://www.amazon.com/Power-Tank-BKT-2285-Propane-diamater/dp/B004M9KX52
    https://powertank.com/products/bkt-2285
    Wouldn't be hard to replicate this if you've got the tools I'd think
  8. Feb 9, 2023 at 2:08 PM
    #158
    Mater
    SD
    2016 MGM Platinum
    Started the install of the water pump. Waiting on the tank to plumb everything up. Still trying to figure out the quick connects and make it so the shower head can quick connect to the pump, but also quick connect to the water heater which would quick connect to the pump.6247C6C3-DF07-4F07-8C76-765295E7A286.jpgCE494EA4-49AF-4F98-8F80-DEE4CFD4809D.jpg0945CD5E-ECCE-4E63-BB01-DF307255B4A5.jpg
  9. Feb 10, 2023 at 1:18 PM
    #159
    Mater
    SD
    2016 MGM Platinum
    73E95173-B1F9-4B08-B30B-BAFE0E793658.jpg 9BADF892-26F1-454B-B467-D4A2E1F37F57.jpg D7031827-2369-473E-BB9F-EA41239F886E.jpg
  10. Feb 10, 2023 at 4:07 PM
    #160
    Wallygator
    Oh that's nice!!:hungry::cheers:
  11. Feb 11, 2023 at 6:48 PM
    #161
    Mater
    SD
    2016 MGM Platinum
    Received these badass stickers today thanks to @TRDFerguson !
    plan is to use the solar power sticker to use for a connect/disconnect switch for the dc-dc mppt. Got to thinking and may also use the inverter sticker to control a relay for so it doesn’t parasitic drain my aux battery. Hasn’t been an issue yet but never know. Thanks again, Jake!
    Got a little more work done today. Was able to figure out how to mount the water tank, got the pump all plumbed up to the spigot thing, wire in the pump, and ran two legs of 16-2 from the switchpro to passenger side rack. These will serve as: comm neg., rack lights left, rack lights right, chase lights.
    hope to do a dry run of the shower system tomorrow.
    EDE6BC70-0BDE-43D4-B583-E7D8EE54BEC2.jpg9CB415AE-1562-4D59-B565-5900EAA85567.jpgF099A546-59F0-4B6F-9BDD-98FE228621D0.jpg8FE804E9-C436-4CF2-9AAA-0B33235EAEDE.jpg541C2C47-730B-453C-A220-0F4176B9F8D8.jpg
  12. Feb 11, 2023 at 6:50 PM
    #162
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If you’re not putting wires into those open ports in that 4-way connector at the pump, make sure you get solid plugs for them.
    Looking good so far!
  13. Feb 11, 2023 at 6:52 PM
    #163
    Mater
    SD
    2016 MGM Platinum
    lol
    Nice eye o_O. Plugged the other side but forgot to plug this side. Will run out after the kids go down and plug em :thumbsup:
  14. Feb 11, 2023 at 7:06 PM
    #164
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    :cheers:
  15. Feb 16, 2023 at 6:31 PM
    #165
    Mater
    SD
    2016 MGM Platinum
    Camp lights are pretty much wired up. Just need to tie them into the SP under the hood. Hopefully will be fairly easy with one leg for switches 5(left),7(right) connecting to the rack lights and the other leg going to the bed rack. Pump is all plumbed up but need to go into my electrical sub panel and connect the circuit (I think). I flipped the switch after wiring up the pump and didn’t hear anything. Maybe because there wasn’t any water to the pump. I know they’re automatic pumps but figured I would have heard at least a click. Hope to get it sorted tomorrow. CBEE9113-CC4E-4AF6-A229-9CBB19F64586.jpg B4A67FC7-806E-4D4E-BBFB-BFF1B3F84E2E.jpg 363A8D65-586B-4AE5-83DE-EFB715DB1847.jpg
    I also had to retake the first photo because I forgot to put in the buttplugs like I told @RainMan_PNW i would. Put them in and resnapped the photo.
    https://youtube.com/shorts/JYRoZnDdxQ4?feature=share
  16. Feb 17, 2023 at 10:16 AM
    #166
    Mater
    SD
    2016 MGM Platinum
    Daily haul from the Harbor
  17. Feb 17, 2023 at 6:39 PM
    #167
    Mater
    SD
    2016 MGM Platinum
    Wallygator and TRDFerguson like this.
  18. Feb 22, 2023 at 11:49 AM
    #168
    Mater
    SD
    2016 MGM Platinum
  19. Feb 22, 2023 at 1:17 PM
    #169
    SAGE63
    San Diego County
    Jason does good work.... Tires tonight? did he cut or fold the pinch weld? he folded mine.
    Mater[QUOTED][OP] likes this.
  20. Feb 22, 2023 at 1:29 PM
    #170
    Mater
    SD
    2016 MGM Platinum
    He does and a very efficient worker that’s for sure. I believe he cut mine. Was making a PPT presentation so didn’t really get to follow along. Haven’t had a chance to check but I should be able to tell when I inspect this afternoon.
    no tires tonight. Scheduled to arrive at discount on Saturday so will be next week most likely
    So what the next step for you..New gears and engine mounts; you’re trucks gunna feel brand new..
  21. Feb 22, 2023 at 1:49 PM
    #171
    SAGE63
    San Diego County
    solid mounts in...gears 17 march. can't pay for lockers yet... not much actually left to do. maybe a secondary up front and double shear kit for shock towers
  22. Feb 22, 2023 at 1:52 PM
    #172
    SAGE63
    San Diego County
    btw the truck shop has a really nice beefy spindle gusset solution.
  23. Feb 26, 2023 at 5:43 PM
    #173
    Mater
    SD
    2016 MGM Platinum
    Mounted a quick fist to hold my propane tank. Does a good job keeping it to the wall, but doesn’t prevent it from flipping up when going over a bump. Going to put a D-ring on that bed bolt. Put a bungee through the top of the tank to the D ring should hopefully prevent the flip up
  24. Feb 27, 2023 at 4:46 PM
    #174
    Mater
    SD
    2016 MGM Platinum
    Got the jack handles mounted
    And then this happened
    to
    7DA82E62-7B73-4CC7-90B1-4B6A46C6F982.jpg 65A673DA-E4F2-4EE1-AF74-507A06F6F846.jpg
  25. Feb 27, 2023 at 5:33 PM
    #175
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Wallygator and Mater[QUOTED][OP] like this.
  26. Feb 28, 2023 at 7:08 PM
    #176
    RainMan_PNW
    Casey
    Clark County, WA
    She don’t fit in the garage no more…
    I keep thinking about mounting a track to the “front” of my canister for shit like that
  27. Feb 28, 2023 at 7:15 PM
    #177
    Mater
    SD
    2016 MGM Platinum
    Yup, pretty much wasted space. Easy to remove everything quickly if needed using rivnuts. Hope to get the jack tucked in nicely behind the fridge. We will see..
  28. Feb 28, 2023 at 7:36 PM
    #178
    RainMan_PNW
    Casey
    Clark County, WA
    Rivnuts cleared the open cover just fine?
  29. Feb 28, 2023 at 7:45 PM
    #179
    Mater
    SD
    2016 MGM Platinum
    Yup. I used 10-24’s. They’re pretty small to begin with and after collapsing I’d bet they don’t stick out more than 1/4”
    edit: could also pop the top off yours and retract it just to be sure. Only thing is if you pop the top off you’ll probably ruin those little black plugs. Could swing by and and grab you 4 more if needed.
  30. Feb 28, 2023 at 8:02 PM
    #180
    RainMan_PNW
    Casey
    Clark County, WA
    I need to pop mine off anyway. Pretty sure my drain holes are partially plugged and need to clean them out. I did it every couple years with my previous one. I also need to mess around with test fitting the Voodoo rack brackets with the TCUSA cover
